alansvwTwinCab Samba Member
Joined: December 28, 2005 Posts: 164 Location: Sydney, Australia
Posted: Mon Jun 11, 2018 11:07 pm Post subject: Adding a USB port |
I want to add a USB port to the dash but would like to keep it looking as close to a factory accessory as possible ..61 ghia Anyone have pics of what they have done?
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Tue Jun 12, 2018 4:56 am Post subject: Re: Adding a USB port |
I added a 12 outlet in my glovebox and use one of those USB plugs that go into that kind of socket.
I have the USB lead poke out of the upper gap around the closed glovebox which is almost directly next to the lip of the dash top. The cable is tucked under the lip all the way along the dash top where it pops out near the outer corner on the drivers side near the GPS attached to the windscreen. The Cable is largely out of sight and doesn’t want to fall out. It is also easy to remove because gap between the dash face and dashtop lip is just small enough.
You can get the socket and USB plug from Jaycar. I got one with three ports and displays the voltage and current.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Posted: Tue Jun 12, 2018 3:41 pm Post subject: Re: Adding a USP port |
I'll check Jaycar out. Thanks |
swanlakers Samba Member
Joined: July 17, 2005 Posts: 370 Location: Lost in space
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Exaktaphile Samba Member
Posted: Tue Jun 12, 2018 5:57 pm Post subject: Re: Adding a USB port |
I saw one where they wired it up under the rear seat and installed the USB jack in the kick panel, near the hump. |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Fri Jun 15, 2018 2:14 am Post subject: Re: Adding a USB port |
like your idea kman |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Fri Jun 15, 2018 4:00 am Post subject: Re: Adding a USB port |
I put mine under the dash (Beetle):
_________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Fri Jun 15, 2018 9:39 pm Post subject: Re: Adding a USB port |
Inside the ashtray.
The ashtray also can be used to make an anti-theft kill switch.
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Steelz21 Samba Member
Joined: January 09, 2017 Posts: 130 Location: Ontario canada
Posted: Sat Oct 17, 2020 7:40 pm Post subject: Re: Adding a USB port |
I put a combination USB/ AUX input in the glovebox.
Amazon. $30 for combination unit and $20 for 12v to 5v converter. |
