cdnltded Samba Member
Joined: March 13, 2015 Posts: 381 Location: Pincher Creek, Alberta
Posted: Sat Jun 16, 2018 7:14 pm Post subject: Re: My project Doom Buggy |
It’s out
And home
joescoolcustoms Samba Member
Posted: Sat Jun 16, 2018 8:29 pm Post subject: Re: My project Doom Buggy |
Congrats!! _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
oprn Samba Member
Joined: November 13, 2016 Posts: 12743 Location: Western Canada
Posted: Mon Jun 18, 2018 3:41 pm Post subject: Re: My project Doom Buggy |
I can't wait to see it in person! |
Posted: Fri Aug 10, 2018 6:41 pm Post subject: Re: My project Doom Buggy |
Well sort of a bad choice of paint. It faded really badly in the sun. Oh well gives me a reason to repaint it this winter. But I finally got the insurance and registration on it.
Took it for a bit of a drive tonight. Still wants to stall when hot. And developed a fairly good oil leak from the head by where the intake bolts on. Hoping it’s just the valve cover gasket
oprn Samba Member
Posted: Sat Aug 11, 2018 4:09 am Post subject: Re: My project Doom Buggy |
Too bad! I liked the purple.
Does that engine have the vacuum retard on the advance pot? As in two vacuum lines going to the distributor. Maybe if it does it is sticking and not letting the advance come back to normal after decelleration.
Just guessing here...
Nice to hear you are driving it! We head for Edmonton today for a family rebellion on the wife's side. 3.5 hours one way and yes we are taking the Buggy. |
62kellison Samba Member
Posted: Sat Aug 11, 2018 4:53 am Post subject: Re: My project Doom Buggy |
did u make a rear seat pad according to the cut outs in the body?.or did u just go with the standard straight across?.my taller daughter sits on the side with the cutouts(extra leg room),and I really want to do that to the other side like u did.congrats on getting to run it!!!.. |
Posted: Sat Aug 11, 2018 7:03 am Post subject: Re: My project Doom Buggy |
oprn wrote: |
No just one vacuum line.
That’s a hell of a drive. Have fun |
Posted: Sat Aug 11, 2018 7:08 am Post subject: Re: My project Doom Buggy |
62kellison wrote: |
Not 100% sure what you mean. But let me explain my reasoning and what I did
I decided that cause I may carry a passenger or 2 in the rear. For more leg room bed use to relocate my battery to under the seat. There was no rear button seat when I acquired the buggy. So after my passenger decision I opted to make a custom rear seat bottom. Most rear seats I have seen the bottom goes right to the middle jump. By cutting it back to the depth of the “battery box” I was able to gain about 8-10” of room for the rear passengers to but their feet without bag to twist and turn them in an uncomfortable fashion.
Hopefully that answers your question |
Posted: Sat Aug 11, 2018 7:11 am Post subject: Re: My project Doom Buggy |
So not only do I have a stalling issue, I know have to rethink my wiring for the front lights. Since I used only one from leaf pack the tire have rubbed the wires for the front signal/park lights. Now either I go and reinstall a couple
Of modified spring packs or I try to reroute my wires at a 90* angle out of the housing. Maybe both as I am sitting on the front snubbers |
Posted: Sat Aug 11, 2018 8:23 am Post subject: Re: My project Doom Buggy |
yes it did answer my question.i am making my seat bottom the same way.only coming out to the battery box cut out.it does give my daughter plenty of rear leg room now.if u got a picture of rear seat pad and area post it up.Thanks... |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Sat Aug 11, 2018 9:02 am Post subject: Re: My project Doom Buggy |
cdnltded wrote: |
I softened the front of mine by removing all of the small leaves in both tubes and keeping the large leaves. Then on the very first hard stop the front tires tore the wires on my front signal lights and hit the fender edges. Added back one set of small leaves in one tube and used 90° connectors on the turn signals and haven't torn any more wires. 12 - 15 psi in the front tires plus a full tank of fuel make for a nice ride.
_________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Sat Aug 11, 2018 3:11 pm Post subject: Re: My project Doom Buggy |
62kellison wrote: |
One from the rear looking forward. One from the front looking rearwards |
Posted: Sat Aug 11, 2018 3:13 pm Post subject: Re: My project Doom Buggy |
Q-Dog wrote: |
cdnltded wrote: |
I was thinking about those 90* connectors. Maybe some silicone to protect from moisture. 🤞🏻 |
oprn Samba Member
Posted: Sun Aug 12, 2018 5:59 am Post subject: Re: My project Doom Buggy |
cdnltded wrote: |
oprn wrote: |
No just one vacuum line. |
Ok, now I am wondering about what your initial advance is and if your idle mixture screw is set right. Maybe a vacuum leak?
You mentioned it happens with a hot engine. Could it be too hot?
cdnltded wrote: |
The trip went well apart from 2 things.
I didn't get the oil filler on properly after topping up the oil level so when we stopped she piddled on the drive way like any good German Shepard. Had to wipe off the fan housing and engine cage. Oops!
On the way home it rained for the first hour. This is not the ideal driving conditions as in the dark the glare of on coming headlights makes it very hard to see the road because of the water mist on the backside of the windshield. Need wipers on both sides it seems! Or give the wife a squeege... |
oprn Samba Member
Posted: Sun Aug 12, 2018 6:05 am Post subject: Re: My project Doom Buggy |
I do very much like your rear seat solution. Ours is very comfortable even for adults apart from room to put your feet.
Question: how did you address anchor points for your rear seat belts? |
oprn Samba Member
Posted: Sun Aug 12, 2018 6:16 am Post subject: Re: My project Doom Buggy |
Q-Dog wrote: |
cdnltded wrote: |
I just finished replacing the rusted out stock front beam with an adjustable one. With the ride height reduced the front rides harsher and feels now like the front tires actually get air time on large heaves at highway speed. It did not do that before.
Initially I was going to remove one set of leaves too but thought I would try the adjustable beam first. The next think I will try is to loosen off the adjustment on one spring pack, set the ride height I want on the other and then tighten the first one at that height. I am hoping it will give me a progressive spring action.
No issues with signal light wiring or rubbing the fenders yet...
Posted: Sun Aug 12, 2018 6:33 am Post subject: Re: My project Doom Buggy |
awesome,thanks.plenty of room!!...I need to do that on the other side as well.(cut out a duplicate hole)... |
Posted: Sun Aug 12, 2018 8:17 am Post subject: Re: My project Doom Buggy |
oprn wrote: |
There is a frame under the rear seat made from 1 1/2” angle. Which is attached to the rear shock mounts and the rear frame horns. If you look back in this thread there is pictures. |
Posted: Sun Aug 12, 2018 8:25 am Post subject: Re: My project Doom Buggy |
oprn wrote: |
Ok, now I am wondering about what your initial advance is and if your idle mixture screw is set right. Maybe a vacuum leak? |
I have never set the time with a timing light. When I originally got the engine running I set it the test light way. It ran so I went with it.
I have had V8s that were really badly out of time and this doesn’t act like that. It will keep running if I keep my foot in the throttle a wee bit. Like the idle is to low. But the issue there is my idle screw is almost all the way in already.
If it does die to restart all it takes is foot all the way into the throttle and hit the key. Fires back up.
I am leaning towards fuel. Maybe the wrong jetting. I am one day gonna get into the carb and check it out |
Posted: Sun Aug 12, 2018 5:57 pm Post subject: Re: My project Doom Buggy |
cdnltded wrote: |
Got my front “sway bar” made and installed. Still need to finish putting the front end back together. One full leaf pack in the lower tube and the bar in the upper. Hopefully the end result works out like the idea in my head. I will post pictures when it’s back on the ground.
Well let this be a lesson to all future builders.
The idea was great. It work for the short time I drove it. But it took to much out of the front end. The front tire rubbed on the front light wiring. I removed the sway bar thing and replace with modified spring packs. I removed the small springs from both packs so now in both tubes I am running only 4 wide springs. Hopefully it gives the ride I am looking for. The height I think is a bit higher then I wanted. But i will live with it as I do not plan on installing adjusters |
