Coolant Leak! ... Solved..... Bad FLAPS pressure cap.
Colorado Yeti
Colorado Yeti is offline
PostPosted: Wed Jun 13, 2018 7:26 pm    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
Aha! Thanks from today's village idiot.
dobryan
dobryan is offline
PostPosted: Wed Jun 13, 2018 7:40 pm    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
We all
wondered the same thing the first time
we saw that FLAPS.
Dave O
The Western Syncro build
alaskadan
alaskadan is offline
PostPosted: Wed Jun 13, 2018 8:48 pm    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
Well that's good to know about Napa, I actually stopped in at the Homer Napa this morning. Said they didn't have one available nearby. I called fellow dub nut here and said he's got a good used oem one I can have so I'm going to go that route. Thanks for the replies.
Paulbeard
Paulbeard is offline
PostPosted: Thu Jun 14, 2018 6:26 am    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
You can test the blue cap at the counter (the countermen may laugh) but if it's not good (not OEM VW or similar) don't buy it.
https://www.youtube.com/watch?v=RT8Ew43mNg4
I see someone found caps for $4…I would be very skeptical those work properly and if they do, for how long. My recently replaced cap was OG — said W GERMANY on it — so it's no great surprise it crapped out after 30+ years of service.
Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
Git 'r DONE!
— dhaavers
cmayna
cmayna is offline
PostPosted: Thu Jun 14, 2018 8:16 am    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
If the bottom cap is the faulty one from FLAPS, it's the same one that I just got from GoWesty. Hmmmm. I also tried the blow/suck test and when blowing into the neck, it is very hard to get air into it. Cannot create a trumpet sound. Another Hmmmm.
'90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig
Colorado Yeti
PostPosted: Fri Jun 15, 2018 6:38 pm    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
Yeah, about that NAPA thing.....POS. Leaked like a submarine with a screen door when it got hot. When I tightened it down carefully a bit more to seat the seal, it stripped.
I guess I am ponying up the $$ for the RMW coolant tank. But at least I will be reassured that I am getting something of high quality and I will not have to worry about cooling system reliability.
Paulbeard
PostPosted: Fri Jun 15, 2018 8:23 pm    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
I wasn't aware they could fail in the other direction (never relieving/venting pressure). Might be worth testing on something that can be measured more scientifically. Mine made a very musical tone…if I could upload videos here I would share it.
Git 'r DONE!
— dhaavers
E1
E1 is offline
PostPosted: Sat Jun 16, 2018 11:48 pm    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
The quality of that video is so astonishing, it's as if I shot it. Laughing Laughing Laughing
‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman
cmayna
cmayna is offline
PostPosted: Fri Jun 22, 2018 6:40 am    Post subject: Re: Coolant Leak! ... Now isn't THAT Special...... Reply with quote
djkeev wrote:
Until better plans can be implemented I got a proper "Blau" coolant cap from Van-Cafe (and an oatmeal cookie!! Finally, back to good cookies ) . Threw away the crappy FLAPS cap that is leaking.
I probably should pull out my pressure tester and verify good before I run it though.....
Dave
So I went online to VanCafe's site and they show the top "Blau" cap. I ordered two. I ended up receiving two of the bottom junk cap. They failed the blow/suck test. They're going back. Also, VanCafe's cookies don't taste as good as they use to....Tsk Tsk
Craig
shagginwagon83
shagginwagon83 is offline
PostPosted: Fri Jun 22, 2018 6:43 am    Post subject: Re: Coolant Leak! ... Now isn't THAT Special...... Reply with quote
Savage! I agree tho
Brandon
Instagram @joannthevan
alaskadan
PostPosted: Fri Jun 22, 2018 8:03 am    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
Well the used one from a friend was shot. Now I'm awaiting one I ordered through O'Reillys. Fingers crossed, but it sounds like I should get another one on the way. But from where? I will post results re the one I ordered. I was in anchorage yesterday and the vw dealership there said they were nla.
cmayna
cmayna is offline
PostPosted: Fri Jun 22, 2018 9:14 am    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
Dan,
If it's that black Dorman one on O-Reilly's site that has "do not open, 15psi" on top, it sure looks like it might work, though I don't know if 15psi is the correct pressure for our rigs.
Craig
alaskadan
PostPosted: Fri Jun 22, 2018 9:36 am    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
I hope so. I thought I'd read somewhere what psi a vanagon system runs. Sure wouldn't want to blow out my tank by running it at a higher pressure than its used to. When ordering that cap at oriellys there were no options of varying psi caps to choose from.
Wildthings
Wildthings is offline
PostPosted: Fri Jun 22, 2018 10:35 am    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
The pressure rating in in the Bentley IIRC. It is something like 16 psi.
Paulbeard
PostPosted: Fri Jun 22, 2018 3:50 pm    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
My local VW dealer (Seattle) says they have lots in their west coast warehouses. About $55, with tax.
I also bought one at Oreilly and had it replaced then returned. You're probably best going with OEM VW, unless this Dorman one tests OK. But then for how long?
Git 'r DONE!
— dhaavers
cmayna
cmayna is offline
PostPosted: Mon Jun 25, 2018 7:33 am    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
OMG!!
I found online a parts place in Arizona who claimed they had the one I wanted. Here's a link:
https://www.autohausaz.com/pn/025121321B
What I got was the cheapy one (lower one in the above pic). When I opened the package and saw a "made in China" sticker on the product's bag, my heart sank.
And get this! This is after I first called them to confirm that what I see pictured on their website is what I'll get. They replied with a "Sir, we only use pics of items we sell". LOL
Yeah, maybe I'll call a VW dealer.
Craig
alaskadan
PostPosted: Mon Jun 25, 2018 8:13 pm    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
Well dang. The oriellys one should be here tomorrow. 55 bucks huh, ouch. Is that a tank and cap? Probably oughta get one coming from them.
Paulbeard
PostPosted: Tue Jun 26, 2018 7:24 am    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
Sorry, just the cap… Crying or Very sad
I think an adapter that screws on the tank and accepts a standard FLAPS radiator cap would be a good idea. Best of both…keep the old tank for visual inspection and use a widely available cap for peace of mind.
Git 'r DONE!
— dhaavers
kamzcab86
kamzcab86 is offline
PostPosted: Tue Jun 26, 2018 7:58 am    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
cmayna wrote:
OMG!!
It states quite clearly at that link & via a Vanagon parts search:
URO Parts Radiator Cap/Expansion Tank Cap; With Nipple; Female Thread
P/N: 025121321B URO Parts
Cross References: RC0003 025121321A 025121321D
Regardless of the photo, what they're selling is a URO brand cap. Confused
~Kamz Anxious
2016 Golf GTI S
Abscate
Abscate is offline
PostPosted: Tue Jun 26, 2018 9:02 am    Post subject: Re: Coolant Leak! ... Solved..... Bad FLAPS pressure cap. Reply with quote
Unused
Return
Only
.ssS!
Page 3 of 4
