LisaS Samba Member
Posted: Mon Jun 18, 2018 5:58 pm Post subject: Hook-up Box Replacement |
I'm ready to install my new GoWesty hook-up boxes. I thought I'd start with the easiest one first--the city water. Not so easy, because some beefy-pawed German torqued the 90 degree brass fitting onto the hookup box. How have others removed this without tearing everything I need to pieces? |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Mon Jun 18, 2018 6:01 pm Post subject: Re: Hook-up Box Replacement |
1st post. Welcome. Maybe you could gently loosen the other end from the faucet and take the whole thing off the van to get better leverage. Be careful with the other end too because that plastic is brittle. |
LisaS Samba Member
Posted: Mon Jun 18, 2018 6:16 pm Post subject: Re: Hook-up Box Replacement |
Thank you. I'll try that tomorrow. |
Altoona Samba Member
Posted: Mon Jun 18, 2018 6:41 pm Post subject: Re: Hook-up Box Replacement |
If you are replacing the box, go ahead and tear it to pieces! |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3796 Location: VA/TN
Posted: Mon Jun 18, 2018 7:31 pm Post subject: Re: Hook-up Box Replacement |
I think the 120v is the easiset. Make sure you test for leaks before you actually put hookup box back on side of van. _________________ Brandon
Instagram @joannthevan |
kamzcab86 Samba Moderator
Posted: Mon Jun 18, 2018 8:25 pm Post subject: Re: Hook-up Box Replacement |
I removed the hose from the faucet and 90° elbow, then pulled the box completely (followed by the hose out through the cabinet... didn't use city water and converted the hook-up to solar connection). _________________ ~Kamz
2016 Golf GTI S
LisaS Samba Member
Posted: Tue Jun 19, 2018 9:22 am Post subject: Re: Hook-up Box Replacement |
We may end up doing the solar conversion somewhere down the line, but are just trying to get everything working first. We may decide we don't need city water (not many campgrounds have water hookups anyway.) |
