Dimensions for seal between gas tank and the body
74 Thing
74 Thing is offline
PostPosted: Tue Jun 05, 2018 8:19 pm    Post subject: Dimensions for seal between gas tank and the body Reply with quote
Does anyone know the width and thickness of the foam seal that goes between the gas tank and the body?
FJBLF
FJBLF is offline
PostPosted: Sun Jun 17, 2018 10:18 am    Post subject: Re: Dimensions for seal between gas tank and the body Reply with quote
Don't know the thickness but these guys sell them... hope it helps
https://airheadparts.com/vw-part/gasket-fuel-tank-to-body-fiber/
74 Thing
74 Thing is offline
PostPosted: Mon Jun 18, 2018 6:18 am    Post subject: Re: Dimensions for seal between gas tank and the body Reply with quote
I ended up using a 1" wide closed cell roll of foam from HD it was only a few dollars and available locally.
Zylinderkopf
Zylinderkopf is offline
PostPosted: Mon Jun 18, 2018 6:51 pm    Post subject: Re: Dimensions for seal between gas tank and the body Reply with quote
If you use the really thick stuff you end up having trouble getting the four gas tank bolts back on. I cut up a cardboard box from amazon...worked great!
1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to."
andk5591
andk5591 is offline
PostPosted: Mon Jun 18, 2018 7:48 pm    Post subject: Re: Dimensions for seal between gas tank and the body Reply with quote
I use generic hardware store weatherstrip. Depends on what is in my box as to what I use. I like the medium density gray stuff - about 1/2" wide and about 1/4" thick for beetles. But if I am out, I will use the lighter stuff. Its really not that critical.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
kubelmann
kubelmann is offline
PostPosted: Tue Jun 19, 2018 4:47 pm    Post subject: Re: Dimensions for seal between gas tank and the body Reply with quote
I use the same rubber trim that goes on the door tops. Looks super but it does require a small section is removed underneath to establish the ground connection for the fuel gauge...
Al Capulco
Al Capulco is offline
PostPosted: Tue Jun 19, 2018 11:52 pm    Post subject: Re: Dimensions for seal between gas tank and the body Reply with quote
I have a solid rubber gasket under my gas tank and my gas gauge works perfect. My gas tank is ground through the 4 hold down clamps.
kubelmann
PostPosted: Wed Jun 20, 2018 8:47 am    Post subject: Re: Dimensions for seal between gas tank and the body Reply with quote
POR 15 inisde/outside of tank created the need to clear an area for ground ~as usual~ a self created problem. Clamps jit the edge trim not the tank...
