Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9954 Location: Huntington Beach, CA
Posted: Sun Jun 17, 2018 12:52 pm Post subject: Re: 1600 dual port running on 2 cylinders |
For the intake nuts I use a 1/4" drive 13mm swivel socket by Snap On. They have the "short" socket on a really tight swivel. Makes it super easy!
I ran into this issue. It was an aftermarket alt stand cast too short. Owner was against changing the chrome out for stock. So, I installed around 5 paper gaskets to just clear. I think I filed the end casting down on the head mating side several strokes of a files worth. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9755 Location: Oregon
Posted: Sun Jun 17, 2018 1:15 pm Post subject: Re: 1600 dual port running on 2 cylinders |
Thank you again. I appreciate the support.
Cusser, it's not for a lack of tools. I have plenty. It's just that the swing radius in the engine compartment is rather tight. Thus the need for the two different configured wrenches.
VWjimbo, I'm just a garage mechanic. So the Snap-On truck does not stop at the end of my driveway. I'm not trying to be a smart-a$$. It's just the reality of things here. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sun Jun 17, 2018 1:40 pm Post subject: Re: 1600 dual port running on 2 cylinders |
No worries! You sound more experienced than just a hobbiest, so I was assuming you may have at one time invested in tools. I still hit up the Snap On guy here locally, for repairs mainly. But ever once in a while for a new tools. For what it is worth, that 13mm swivel makes easy work of the fuel pump, the generator stand, dual carb manifolds and a few other spots that are tight. If you do get your hands dirty enough, money well spent. _________________ Jimbo
TDCTDI wrote: |
Posted: Sun Jun 17, 2018 1:50 pm Post subject: Re: 1600 dual port running on 2 cylinders |
VW_Jimbo wrote: |
No worries! You sound more experienced than just a hobbiest, so I was assuming you may have at one time invested in tools. I still hit up the Snap On guy here locally, for repairs mainly. But ever once in a while for a new tools. For what it is worth, that 13mm swivel makes easy work of the fuel pump, the generator stand, dual carb manifolds and a few other spots that are tight. If you do get your hands dirty enough, money well spent. |
Thank you!
Yes at one time I was a line mechanic for a small independent shop in Idaho Falls, Id.
At that time I did indeed invest in quality tools.
Problem statement. Wife #2 took everything I owned, right down to my cowboy boots while I was working in Europe for an extended period of time. Long sorted story...........
Every time I have to buy a new tool, I get a little angry at the fact that I already had a good quality one that I am replacing with an HF tool. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sun Jun 17, 2018 4:11 pm Post subject: Re: 1600 dual port running on 2 cylinders |
VW_Jimbo wrote: |
Thank you!
Every time I have to buy a new tool, I get a little angry at the fact that I already had a good quality one that I am replacing with an HF tool. |
I knew that there was something there, inbetween your words!
Sorry brother! I have also found life to have its crappy times. No fun.
Be thankful that your knowledge is still intact and your skills can not be taken from you. Life is just testing your resilence. It keeps testing me as well. My last fight, ended after brain surgery, leaving me with no short term memory, at the age of 26! So, stay positive, there is always something better up ahead!
There are ALOT of good tools for sale at swap meets. You may be able to find one at one of those venues. Just a thought. Or buy a really cheapo wrench and bend it! _________________ Jimbo
TDCTDI wrote: |
Posted: Sun Jun 17, 2018 4:19 pm Post subject: Re: 1600 dual port running on 2 cylinders |
There is a pawn shop up the road that hates small tools. Yet they buy them all the time.
I paw through the boxes of loose tools and once in a while come up with a Snap-On, Craftsman.... tool that will work well for me.
Like the Snap-On 17mm swivel socket that is perfect for getting to the upper left motor mount bolt.
I hear ya. Thank you for the kind words and encouragement. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Tue Jun 19, 2018 4:45 pm Post subject: Re: 1600 dual port running on 2 cylinders (Fixed) |
SO after shredding my forearms trying in vain (or is that vane) to get the end casting in place. I bit the bullet and removed the engine last night.
Funny thing is that once the engine was on the garage floor. I looked at the offending end casting. And I'll be damned! The flippin boot was on the casting correctly. The casting was loosely on the intake port of the head and partially into the boot when I started taking it out.
I guess all of the wiggling worked it in place.
I tightened down the boot and then the end casting.
Reached for my new latest favorite tool. An $18 6v bell housing from the last swap meet I attended. Installed a spare starter and wired up the hot side of the coil. Put some gas in the carb and started it up on the floor.
Wala! It's running on all 4 cylinders.
Problem solved.
Thank you everyone that helped me get this sorted. _________________ I have learned over the years.
Buy Once, Cry Once!
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Tue Jun 19, 2018 4:48 pm Post subject: Re: 1600 dual port running on 2 cylinders |
GOOD! Thanks for the update! _________________ In Stereo, Where Available! |
Danwvw Samba Member
vamram Samba Member
Posted: Tue Jun 19, 2018 8:25 pm Post subject: Re: 1600 dual port running on 2 cylinders |
Yep, I had that same issue on my '74 recently, dead 3-4 due to a leaky manifold to hear gasket. I bought a long HF ratchet tool with a double-jointed/swiveling head and was able to loosen and tighten the front and back manifold nuts without dropping the engine. One of the best cheap tools i ever bought!
Glad you got it fixed! _________________ Eventually, "we are what we pretend to be.
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Tue Jun 19, 2018 8:42 pm Post subject: Re: 1600 dual port running on 2 cylinders |
Everyone has been down that road. Enjoy the ride. Take away the lesson taught and then apply that knowledge in the future! And take a momment to relish in the fact that you did it!!! Nice job man! _________________ Jimbo
TDCTDI wrote: |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Wed Jun 20, 2018 4:36 am Post subject: Re: 1600 dual port running on 2 cylinders |
My procedure for chasing something like this is starter fluid with a straw. I give shots at every joint - including the manifold/head. I do this again AFTER I have installed everything as well. _________________ D-Dubya Manx clone - 63 Short pan,1914.
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1376 Location: Wichita, KS
Posted: Wed Jun 20, 2018 5:58 am Post subject: Re: 1600 dual port running on 2 cylinders |
VW_Jimbo wrote: |
For the intake nuts I use a 1/4" drive 13mm swivel socket by Snap On. They have the "short" socket on a really tight swivel. Makes it super easy! |
VW_Jimbo, is this the Snap-on socket that youre talking about?:
https://store.snapon.com/Shallow-Universal-mm-Chro...42263.aspx
Sounds interesting if if fits well in lot of those tight spots in the engine bay! Do you recommend 10 mm swivel socket as well, maybe? |
vamram Samba Member
Posted: Wed Jun 20, 2018 6:53 am Post subject: Re: 1600 dual port running on 2 cylinders |
Here's the one I use for this:
https://www.harborfreight.com/hand-tools/sockets-r...98484.html _________________ Eventually, "we are what we pretend to be.
Click to view image
Save the Supers!! |
Posted: Wed Jun 20, 2018 3:44 pm Post subject: Re: 1600 dual port running on 2 cylinders |
baldessariclan wrote: |
VW_Jimbo wrote: |
Yep! Although that is a 9mm pictured!
I purchased mine 28 years ago, so...
I have from 6mm to 15mm, set. Money well spent!
The 10mm lets you easily get to the bottom generator fan bolts.
Would not know how to work without these sockets.
Hey, on a side note. You cannot go wrenching on them to tight. They do break, but you do have a lifetime warranty! I have had my 13mm replaced about 30 times! Same with the 10 and 12mm.
Have fun! _________________ Jimbo
TDCTDI wrote: |
