Soul Built Pimpin' Aint Easy
Posted: Sat Jan 28, 2012 12:14 pm Post subject: |
I was able to score a set of 45 Dells for $200. Now that they are in the hands of Art and his team, I think I will come out smelling like roses.
Any idea what to set the advance to on a 2180 for these carbs? |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Sat Jan 28, 2012 2:04 pm Post subject: |
Soul_VW wrote: |
I was able to score a set of 45 Dells for $200. I think I will come out smelling like roses. |
You're a stinker! What a deal.
28 - 32 degrees is the starting area, every engine has it's own favorite timing, you'll just have to adjust and see what it likes best. _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
Posted: Sat Jan 28, 2012 2:27 pm Post subject: |
it must be pointed out that IF the engine is too rich it will "want" more timing.
If you have an engine that runs better on 34 degrees instead of 28, try to pull out some fuel and some timing, and try again. Make little changes, 2 degrees at a time. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
mxracer Samba Member
Posted: Sun Jan 29, 2012 9:04 am Post subject: |
[/quote]
Bigg Tim wrote: |
I don't want to use any vacuum source off the carb. Im asking if I need them at all on the carb since I have one broke off on the other carb. Can I just plug that port? |
Those ports don't actually need to be "plugged". Those are the sync ports for a water/mercury type syncrometer. When they are tightened up snug they are closed. |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Wed Jan 07, 2015 3:45 pm Post subject: |
left_coast*9 wrote: |
Well, picked them up last night. I would not call them cherry, but I suppose they're in good shape. All parts seem to be there. I have not had a chance to go in and look at the internals yet.
All the indentifying info is on the diaphram side of the carbs. The motor's left side carb has a small stamped metal tag on it that says "R6217". Then to the left of that stamped in the casing of the carb body says: "Dellorto Made in Italy". To the right of the tag also stamped in the casing: "DRLA 45S". The other carb's little metal tag says "R6218". It has the same "Dellorto Made in Italy" stamp. On the right of the tag is stamped: "DRLA 45D".
The air cleaners seem to be in real nice shape, as do the filters. How'd I do? Here's some pics:
Just sold my rebuilt 45 dells this afternoon and the person I sold them to inquired about the fact that one is stamped DRLA 45D & the other DRLA 45S. Am I correct in saying that this means one is right handed and the other is left handed as would be expected for a matched set for dual carb application? I ran them briefly on a 2332 and never noticed. |
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Wed Jan 07, 2015 5:52 pm Post subject: |
Italian for Left and Right...
sinistra = Left
destra = Right |
Joined: March 18, 2002 Posts: 593 Location: Peterborough, Ontario, Canada
Posted: Mon May 21, 2018 6:55 pm Post subject: |
Bigg Tim wrote: |
Those ports don't actually need to be "plugged". Those are the sync ports for a water/mercury type syncrometer. When they are tightened up snug they are closed.[/quote]
I have a 40 drla with pressure union ports open like the original poster's carbs pictured... (without the bleeder screw style plugs.)
Would I be best to plug those ports with allen head screws for proper operation?
Thanks! |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Wed Jun 20, 2018 3:18 pm Post subject: Re: Used dual Dellorto 45DRLAs |
What and where is this ACE?
Who is this Art fellow?
Care to share a link? |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Wed Jun 20, 2018 3:25 pm Post subject: Re: Used dual Dellorto 45DRLAs |
Try blackline racing _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
mcdragracer Samba Member
Posted: Sun Jun 24, 2018 2:43 pm Post subject: Re: Used dual Dellorto 45DRLAs |
Also I can handle any of your dellorto repairs and or any questions you might have.
Rick.
[email protected]
Also check out my feedback on the samba |
