drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Sun Nov 16, 2014 12:23 pm Post subject: |
The wheel should be balanced in 2 directions, around the circumference and also side to side. Putting weights only on one side of the rim can really screw with the side to side balance.
Next time you are at the tire shop watch them balance tires on the spin balancer and you will see the readout tells the technician where weight is needed and which side of the wheel it needs to go on. On some of the better machines it also tells how close to the center of the rim it needs it needs to go. So the weight doesn't just go on the inside, it could go on the inside of the inside, or farther out towards the bead. _________________ Mother Nature is a Mean Evil Bitch! |
moab762 Samba Member
Joined: October 09, 2014 Posts: 518 Location: El Segundo, CA
Posted: Sun Nov 16, 2014 12:24 pm Post subject: |
drscope wrote: |
Next time you are at the tire shop watch them balance tires on the spin balancer and you will see the readout tells the technician where weight is needed and which side of the wheel it needs to go on. On some of the better machines it also tells how close to the center of the rim it needs it needs to go. So the weight doesn't just go on the inside, it could go on the inside of the inside, or farther out towards the bead. |
These balance beads are sounding more attractive all the time. |
Asleep@thewheel Samba Member
Joined: December 13, 2015 Posts: 68 Location: Ridin' with Bob
Posted: Fri Jan 22, 2016 10:22 am Post subject: Re: Wheel Balancing |
Old thread . Just wondering if anyone tried using the computer balance after adding the beads and what the result was? |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Fri Jan 22, 2016 3:58 pm Post subject: Re: Wheel Balancing |
Asleep@thewheel wrote: |
From what I've read these do not work with computer balancing , not really sure why. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun Jan 24, 2016 10:01 am Post subject: Re: Wheel Balancing |
You can computer balance first, THEN add beads as a supplement.
But once they are in... you cant speed/computer balance the wheels.
Reason...The beads can't disperse fast enough in the short time a balancer measures a wheel..
If beads (or liquid) are inside a wheel and placed on a balancer and spun, the balancer will measure inconsistent weight amounts and locations as the beads (or liquid) is trying to disperse during the measuring..
It just wont work...
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Murdlem Samba Member
Joined: February 06, 2004 Posts: 512 Location: Port Angeles, Washington
