BajaTX Samba Member
Posted: Wed Jun 20, 2018 2:48 pm Post subject: Fix Swing Axle with redux boxes, or swap to IRS? |
I finally got to the location where my new to me '64 Baja is. It has a bus transaxle with reduction boxes(small nut). One of the swing axles pulled out of the trans. I was able to pull the axle tube and redux box. Then I pulled the retainer ring and axle. The thrust washer is in a million pieces. I've got fine silver in all the trans lube. I could clean everything out and put it back together. But I am noticing some other issues with this transaxle. It has the Johnson style no-hop braces. There are some broken welds on the axle tubes where they meet the redux boxes. Brakes on one side are soaked in axle lube. Lots of poorly done work on this Baja. I really just need to get it moving. The engine is in good shape, and everything else is in working order.
Should I clean up this rear and fix the welds, or should I swap to something else. If I switch to IRS CV axle, can I use any of these brake parts? Where can I get a complete used rear. |
BajaTX Samba Member
Posted: Wed Jun 20, 2018 2:58 pm Post subject: Re: Fix Swing Axle with redux boxes, or swap to IRS? |
Also would like to keep my wide 5 wheels. |
BajaTX Samba Member
Posted: Wed Jun 20, 2018 3:40 pm Post subject: Re: Fix Swing Axle with redux boxes, or swap to IRS? |
Axle tube has been bolted and welded to redux box.
BajaTX Samba Member
Posted: Wed Jun 20, 2018 9:15 pm Post subject: Re: Fix Swing Axle with redux boxes, or swap to IRS? |
More info.
I am working on a '64 Baja that has RGBs and small nut axles. It also has a no-hop kit that looks very similar to the Johnson kit. Unfortunately, this transaxle has seen better days. Someone welded the RGBs to the axle tubes and installed bolts in place of the press pins. The welds are broken and the RGBs have some other issues. The reason I started working on all this is because one of the thrust washers broke and the Baja became non-operational as a result. Lots of "silver" in the trans lube I just drained.
I have some other RGBs with axle tubes that are in good shape. I have all of the seals and small parts to put the transaxle and RGBs back together. I don't have the tools or shop to completely rebuild everything. I just need to get this Baja back in action for now.
I don't have a press, but I do have a welder and good fab skills. I am considering cutting the flanges off the transaxle end of the axle tubes so I can install the no hop over tubes. I would use a jig to weld the axle tubes back together. What are your thoughts regarding cutting and welding the tubes instead of pressing them out of the RGBs? How do I determine how much of the RGB flange to remove at the spring plate end? I am thinking I can just cut around the RGB flange without pressing the tube out. I realize this is not the "best" way to do this, but I have to work with the tools and parts I have available to me at this location.
Looking forward to your response.
Thanks,
Tom |
Bad_Decisions Samba Member
Posted: Thu Jun 21, 2018 4:13 pm Post subject: Re: Fix Swing Axle with redux boxes, or swap to IRS? |
I don’t know nearly as much as other people on this site, but I don’t see anyone chiming in so I’ll just give my opinion. From what I’ve read on the forum irs is far better than the swing axle for off road. The swing, i’ve Heard,likes to roll over in hard turns. But I haven’t noticed that in my sand rail which has a swing axle. If it were me and I had the resources I would convert to irs. |
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Thu Jun 21, 2018 5:02 pm Post subject: Re: Fix Swing Axle with redux boxes, or swap to IRS? |
I don't have any practical experience to share. Redux is cool for a buggy with a smaller engine. The bigger engines seem to favor IRS _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Posted: Fri Jun 22, 2018 4:40 am Post subject: Re: Fix Swing Axle with redux boxes, or swap to IRS? |
How are the Redux boxes mounted? They boxes are set wider than standard swing axle mounts.
This may not be an issue with IRS. _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Fri Jun 22, 2018 12:51 pm Post subject: Re: Fix Swing Axle with redux boxes, or swap to IRS? |
my swing axle bus trans RGB buggy wagged it's tail, jacked up the rear in turns, and eventually rolled. you raise the center of gravity on a back engine car, that happens.
An IRS gives you the 002 or 091 transaxle option but you may have to dent your framehorns to make the CVs fit.
the third option would be to cut out the torsion housing and put an IRS torsion housing in. this route presents minimal fabrication and alignment hassles _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
flashho Samba Member
Joined: August 11, 2012 Posts: 240 Location: Mulege, Baja
Posted: Wed Jun 27, 2018 5:23 pm Post subject: Re: Fix Swing Axle with redux boxes, or swap to IRS? |
I have an old funco with RGBs which I race regularly, and win ! lol
I would and will someday, convert to IRS when my budget allows. I will swap out the torsion tube and everything behind it. I run 33s for long courses and 30s for short courses with a 2276 engine and the trans has a super diff. The RGBs present problems in the whoops or if you hit a bump with the rear end compressed, by hitting the brakes or lifting on the gas. The rear end becomes a pogo stick in those conditions and nose dives can happen. It is no fun being a lawn dart. I have 14 inch of frt travel and only 7 in the rear. Plus side.. it will climb anything, it can maneuver thru technical areas easily and it cruises thru sand and silt. It took me a long while to learn to control the rear, for example, if you are sliding out in a turn, lifting briefly will put weight and traction to the rear, if you are pushing in a turn, more throttle will hook up the front. So, if you can convert to IRS, budget wise, go for it. If not, you can have a blast with the RGB set up. There is a long thread on replacing RGB bearings ( a real PIA) with pics of various set ups, that may help with your tube problem. _________________ rant _ classified ads with out pics are almost worthless |
drumbum68 Samba Member
Posted: Wed Jul 11, 2018 1:53 pm Post subject: Re: Fix Swing Axle with redux boxes, or swap to IRS? |
Use this opportunity to convert to IRS.
Welding in pivots allows you to set proper camber when raising the rear end and installing a bus trans. |
