How can I use a Hazard switch as a Fog light switch
JR_76BayMicro
JR_76BayMicro is offline
PostPosted: Wed Jun 20, 2018 8:23 pm    Post subject: How can I use a Hazard switch as a Fog light switch Reply with quote
Hello All ,
been looking for ages for a 111-959-631 fog light switch with no luck so started thinking if I could use a spare Hazard switch which I have to operate the fog light relay . I've got a 111-953-235F . Looking at the connectors and running over them with a multimeter I've worked out that I have continuity between terminal 30 & the one marked with a + when the switch is pulled out . Any idea how I can get the bulb to illuminate when the switch is on ? . Can I go from the + to either the L or R or 49a through the bulb to 31 ( ground ) ? , there appears to be a circuit following this path with my multimeter . Will this work or am I going to set fire to my loom ?
Thanks
John Re
Melbourne Australia
Tcash
Tcash is offline
PostPosted: Wed Jun 20, 2018 8:46 pm    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Try jumping "+" to 15 and grounding 31.
Click on pic
JR_76BayMicro
PostPosted: Wed Jun 20, 2018 8:51 pm    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Thanks for getting back to me Tcash , I'll mock it up & try it out
Ta Mate
John Re
Melbourne Australia
JR_76BayMicro
PostPosted: Wed Jun 20, 2018 9:16 pm    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Hooking a little 9v battery to the loose spare switch I get :
+ to 30
- to 31
switch pulled out
getting 9V at "+"
jumping from "+" to 15 , no lamp
jumping "+" to "L" or "R" or 49a , lamp on
thoughts ?
John Re
Melbourne Australia
Tcash
Tcash is offline
PostPosted: Thu Jun 21, 2018 6:49 am    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Then you can use one of the three L,R or 49 to illuminate the light with no problems.
GD
Tcash
Bleyseng
Bleyseng is offline
PostPosted: Thu Jun 21, 2018 7:04 am    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Use a rear window defogger switch and if you don't have one order one from Ken at thebusco.com
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
jtauxe Premium Member
jtauxe is offline
PostPosted: Thu Jun 21, 2018 7:18 am    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Bleyseng wrote:
Use a rear window defogger switch.
^ This. The rear fog relay switch works just great, unless you want the two-stage fog light switch. There used to be a guy (in Greece?) who sold nice reproduction fog light switch bezels, but I think he's done.
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Jeff Geisen
Samba Chaplain
Jeff Geisen is offline
PostPosted: Thu Jun 21, 2018 4:59 pm    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Her name is Eleny, I am happy I bought several. Amber they are.
I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab
JR_76BayMicro
PostPosted: Thu Jun 21, 2018 5:55 pm    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Thanks for the confirmation Tcash , I'll proceed with the spare hazard flasher switch option . Thanks to all others for your idea's , just need to get a replacement bezel / lens now
Ta
John Re
Melbourne Australia
jtauxe is offline
PostPosted: Fri Jun 22, 2018 6:52 am    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
No, no. Not the hazard switch. Use a defogger switch. Seriously, that is the way to go. There are threads about this. (Search fog lights.)
And if Jeff has "several" bezels, maybe you could talk him out of one, and you would be all set.
John
http://vw.tauxe.net
JR_76BayMicro
PostPosted: Fri Jun 22, 2018 10:27 pm    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
All good jtauxe , I already have the spare hazard switch . PM sent to Jeff
Thanks for all your help
John Re
Melbourne Australia
chimneyfish
chimneyfish is offline
PostPosted: Sat Jun 23, 2018 5:49 am    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
BusOK in the Netherlands have original NOS fog light switch lenses for the T2 style switch. There is also a used switch up for sale on there:
https://busok.nl/catalogsearch/result/?q=mistlicht
You could also message Eleny (Topaz) in Greece as mentioned above, and see if she and her husband have any of the repro T2 fog lenses left. I see she last logged on in May:
https://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=164699
1965 Type 1 Deluxe (1200cc)
1976 Type 2 T2b Microbus L (1800cc Type 4)
Previously...
1972 T2 Camper (Devon), 1988 Golf, 1972 Type 1, 1984 Polo, 1972 T2 Camper (Danbury)
JR_76BayMicro
PostPosted: Sat Jun 23, 2018 9:23 pm    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Thanks for the tip Chimneyfish , on it now
John Re
Melbourne Australia
JR_76BayMicro
PostPosted: Mon Aug 06, 2018 3:52 am    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Hello Chimneyfish , finally got a used lens from BusOK ( Netherlands ) , it was pretty faded so I decided to try and repaint it . 1st stop was a Hobby shop to get a few items , step by step photos
happy with the result , I may clear over it
Thanks everyone for your sage words
John Re
Melbourne Australia
hopkin Premium Member
hopkin is offline
PostPosted: Mon Aug 06, 2018 4:20 am    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Looks good, I wish I'd seen your post earlier....
Hella makes a fog light switch, seen here on my dash with an amber lens (also comes with red and green lens):
Here's a link:
http://www.sierramadrecollection.com/Hella-Fog-Light-Switch-p26508.html
I ordered a replacement lens from ECS Tuning for a different look:
Here's the link:
https://www.ecstuning.com/Search/SiteSearch/9116132340201C/
1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car)
JR_76BayMicro
PostPosted: Mon Aug 06, 2018 4:52 am    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Thanks Hopkin , I'm way down the rabbit hole on this one but I'll forward your suggestions to a friend that may want to install a switch as well
John Re
Melbourne Australia
telford dorr
telford dorr is offline
PostPosted: Mon Aug 06, 2018 11:45 am    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
The indicator is connected from 49a to 31 (with the switch pulled out).
Power to 30
Lamps to "+"
Tie 49a to "+"
Ground to 31
If you have high current fog lights, you might buffer the switch with a relay, as it was only designed to operate four stop lamp type bulbs.
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
pittwagen
pittwagen is offline
PostPosted: Mon Aug 06, 2018 4:44 pm    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Defogger switch with new knob and insert. It has been installed for 7yrs or so and works just fine. FYI.
JR_76BayMicro
PostPosted: Mon Aug 06, 2018 5:30 pm    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
Hello Telford Dorr , yeah I'm using the switch to operate a relay only
Thanks
John Re
Melbourne Australia
chimneyfish
PostPosted: Thu Sep 20, 2018 11:43 am    Post subject: Re: How can I use a Hazard switch as a Fog light switch Reply with quote
JR_76BayMicro, sorry only just read this, that is excellent work restoring that lens, and that Tamiya tape looks good stuff, I learnt something new there!
Previously...
