fredc125 Samba Member
Posted: Fri Jun 22, 2018 11:16 pm Post subject: Creating shock towers..... |
I'm upgrading the king pin front torsion beam on my sandrail by going to coilovers, big tires and through bolts. I've had to remove the existing shock loops from the frame as they were way to small and in the way. My question is: Since there are no shock towers on the beam it would seem plausible to just install a taller set of loop towers, but it seems like i could make set of "warrior" like towers and weld them directly to the frame instead of loops and instead of mounting towers to the beam. It would be super cheap and easy. Any reason not to do this ? |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5418 Location: Holland, MI
Posted: Sat Jun 23, 2018 5:55 am Post subject: Re: Creating shock towers..... |
Nope, it would work great. Just grab some 1/4” plate and go to town.
If you make the upper shock mount point 12” above the upper tube, you can run 8” travel shocks.
Just go easy and slow when welding them to the upper tube. It is easy to cook the bearings if you put too much heat into it too fast. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Sat Jun 23, 2018 9:20 pm Post subject: Re: Creating shock towers..... |
Thank you for your feedback. |
dustymojave Samba Member
Posted: Sat Jun 23, 2018 11:01 pm Post subject: Re: Creating shock towers..... |
And be very sure to "cycle" the suspension with through rods installed, arms, spindles and tie rods assembled, without springs but WITH shocks, before you final weld the new upper shock mounts. The upper shock mounts should be pretty much in the same location as they would be if you had a Warrior coilover beam.
And be sure to have the shock mount bolts parallel to each other top and bottom, just like stock link pin front ends have. I just saw a buggy a few days ago with the mounting bolts at 90° to each other. That's a good way to break stuff. _________________ Richard
SoCalBajas Member
Dark Earth Samba Member
Posted: Sun Jun 24, 2018 8:12 am Post subject: Re: Creating shock towers..... |
fredc125 wrote: |
but it seems like i could make set of "warrior" like towers and weld them directly to the frame instead of loops and instead of mounting towers to the beam |
Vanapplebomb wrote: |
Just go easy and slow when welding them to the upper tube. It is easy to cook the bearings if you put too much heat into it too fast. |
You want to weld the "warrior" style shock towers to your 1 1/2" tube frame, not to the front suspension beam, right ? _________________ My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ |
