Rain's Westy Samba Member
Posted: Fri Jun 22, 2018 12:34 pm Post subject: 1963-1964 1500 CC ( 42 hp ) bus motor build |
I am building an exact correct for November of 1963 1500 cc (42 HP ) bus motor for a restoration of a 64 21 window that had a dealer installed upgrade to a 1500 when the bus was sold new .
I have a few questions for any experts on this specific motor who might have one in their buses .
What are the correct single port intake versions for this bus ? With the speed governor? without? What part # would be embossed on the intake (s)? I guess we can build it ether way since both were available in 1964.
Or did they just use the speed governor delete intake extension and have only one intake?
If you had then optional 12volt system in 1964 what distributor coil would the bus have had ? What generator and regulator and where would the regulator be mounted?
I dug through my dealer parts lists but do not have one updated only to 1964 so I am not sure . progressive changes was not helpful on this question ether .
Any photos anyone could share or post of original correct builds or unmolested early 1500's in their buses would be great !
I was able to locate a correct 1963-1964 unnumbered case with no cam bearings in very good shape for the build and NOS P&L set etc . This should be a fun motor to recreate! I love recreating history !
I am sure I will have a few more questions on this as time goes on . Thanks ! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Fri Jun 22, 2018 5:33 pm Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
I will answer what I can.
Here's the May, 1964 engine from my old low-mileage '64 13-Window
I feel like a US Bus would have the shorter Bus intake and a governor, even though this one does not. It was U.S. spec but was Tourist Delivery so that may be the reason.
I have definitely seen governors dated 1963/1964 (did you know they are dated?)
I'm not sure which intake would be 100% correct but there is a thread here in the Bus FAQ:
https://www.thesamba.com/vw/forum/viewtopic.php?t=221031
A 1500cc Bus would have the regulator mounted on the side panel by the battery, as seen above. _________________ How to Post Photos
Posted: Fri Jun 22, 2018 6:13 pm Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
thank you Everett That is a nice looking engine compartment! Our bus is a SWR / GRAY bus so this photo is exactly what we are striving for . I know the governors were also put on (some)? 40hp's as well as it was listed in the parts list as such .
I have noticed some have dates on them as you describe but I will be leaving it up to the next guy to find a properly dated governor and just use what I have kicking around for now .
Looks like I need 211 129 701D intake
Was the generator and regulator the same used on 12 Volt Porche's ? |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Fri Jun 22, 2018 8:06 pm Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
Early and mid range dated governors are actually quite rare. My bet is not governor. late governor have the stamping DR-1 on them the early ones do not have the -1. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Fri Jun 22, 2018 8:25 pm Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
Interesting Thank you for sharing this tidbit. |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Sat Jun 23, 2018 11:22 am Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
Is there some advantage to having a "no cam bearing" case other than it establishes an authentic date?
I'd be temped to have it bored for cam bearings.Or am I missing something?
Also, did these early engines have the M number stenciled on them?
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Malokin Martin Samba Member
Posted: Sat Jun 23, 2018 11:34 am Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
This wouldn’t be a visible change, and would improve the life of the engine that someone is dropping a good amount of money (or) work on. Same as adding 10mm studs. It would make sense. |
Posted: Sat Jun 23, 2018 12:29 pm Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
10mm studs? You mean head studs? I guess I was under the impression the 8mm skinny ones worked better and made more consistent clamping.
Case savers of course.
Vanagons:
Posted: Sat Jun 23, 2018 1:01 pm Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
I just read up on a few threads on here. 8mm is better apparently. I learned something today! I always assumed bigger was better. |
Posted: Sat Jun 23, 2018 2:17 pm Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
The case and cam journals are in really good shape and with proper oil changes should last a long time . The bus is VERY unlikely to be used as a frequent driver so it seems not worth it to upgrade the cam bearings. I will build it with a HV oil pump . As for the studs, yes the smaller ones are much better but again for an engine that will get little use the OG studs will work fine . It has been case saver though, I have built hundreds of motors over the years and for this sort of application (a stock motor with 83 mm pistons) running a 28 pcit carb with stock1500 jetting and stock exhaust you are not going to have that much engine stress . I am also going to have DPR balance everything so that will add to engine longevity. I am not dooing this motor for my self but for a friend's business that is restoring the bus . I am on a bit of a budget but want it as meticulously correct as I can within monetary limits they have .
Early bus 1500 engines used the same 311- xxx-xxx engine case castings as used in early type 3 cars but with the oil dipstick in the correct place and no place for the type3 oil filler tube ... they are rather unusual now a days it seems ... and not something I ran across very often when I worked as an engine builder ... especially ones with no serial number .
My motor in my daily driver 66 bus is a fully balanced 1600 on a late case, counterweighted forged crank with a type4 oil cooler stuffed in the doghouse, full flow filter ,single port , small studs ... thermostat installed and working , stock carb jetted for lower octane modern gas . not a stock but super reliable motor that runs in the correct operating temp range even on hot days! |
Posted: Sat Jun 23, 2018 3:34 pm Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
Malokin Martin wrote: |
I think they expand closer to the same rate as the cylinders. Repeated heat cool cycles where the cylinders grow but the studs don't eventually hammers out the head spigots. My take on it anyway. I think that is the same reason modern engines use stretch bolts on the heads. Again, just my guess.
Vanagons:
Posted: Sat Jun 23, 2018 4:01 pm Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
Alan Brase wrote: |
Al |
that really makes total sense ... it seems like we needed to deck cases more often that had the larger studs then the small ones . But for an engine that is not regularly driven daily it is less of an issue .The case I have has nice clean sealing surfaces for the cylinders . I have no idea what it's past history is though but it has never been deck resurfaced |
Posted: Sun Jun 24, 2018 9:43 am Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
Alan Brase wrote: |
Al |
Engine M codes, if any were ink stamped onto the fan shroud _________________ Roads Scholar &
Posted: Sun Jun 24, 2018 10:35 am Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
tasb wrote: |
Alan Brase wrote: |
Al |
Engine M codes, if any were ink stamped onto the fan shroud |
INK stamped? Stamped like a rubber stamp, white ink, maybe? I've seen a few. Didn't know when they started that practice. _________________ Al Brase
Vanagons:
velvetgreen Samba Member
Posted: Mon Jun 25, 2018 6:31 am Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
^^ always wondered about that. if mem servers they were in white paint on the back of the shroud. Paint comes off quite easily which might explain why it is not common knowledge |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Mon Jun 25, 2018 8:05 am Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
Rain's Westy wrote: |
I am on a bit of a budget but want it as meticulously correct as I can within monetary limits they have . |
Those are competing interests. I hope that their monetary limits allow for what you want to build and still leave some money to pay you for your labor. _________________ .
Wanted:
mr. lang Samba Member
Posted: Mon Jun 25, 2018 8:34 am Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
If you had then optional 12volt system in 1964 what distributor coil would the bus have had ? What generator and regulator and where would the regulator be mounted? |
As for the coil and in general the electrical system for model year '64 I think i can help:
Not sure how deep you want to go with period correct parts, so I might possible post too much information. Please skip if not needed.
I also posted for the 1.2 ltr 1200 engine and 6V systems to keep all in one post if anybody does need the same information.
distributor
till January '64: Bosch ZV/PAU 4 R 5 MK = Bosch 0 231 139 005 = VW 113 905 205 A
from February '64: Bosch ZV/JU 4 R 3 MK = Bosch 0 231 147 002 = VW 111 905 205 L
period correct spare parts for Bosch ZV/PAU 4 R 5 MK:
points: Bosch ZVKT 4 SORT 3 = Bosch 1 237 013 026 = VW 111 998 057
condenser: Bosch LMKO 1 Z 15 Z = Bosch 1 237 330 044 = VW ?
rotor: Bosch ZVVT 7 Z 10 Z = Bosch 1 234 332 101 = VW 113 905 225
cap: Bosch ZVVS 5 Z 2 Z = Bosch 1 235 522 232 = VW 113 905 207
period correct spare parts for Bosch ZV/JU 4 R 3 MK
points: Bosch ZVKT 8 SORT 4 = Bosch 1 237 013 039 = VW 111 998 059
condenser: Bosch LMKO 1 Z 45 Z = Bosch 1 237 330 069 = VW 111 905 295 A
rotor: Bosch ZVVT 5 Z 7 Z = Bosch 1 234 332 076 = VW 111 905 225 G
cap: Bosch ZVS 74 Z 6 Z = Bosch 1 235 522 027 = VW 111 905 207 C
dust cover: Bosch 1 230 500 017 = VW ?
coil 6V:
Bosch TE 6 B 4 = Bosch 0 221 100 007 = VW 111 905 105 E
coil 6V partly used till February '65:
Bosch 0 221 116 001 = Bosch 0 221 116 001 = Bosch 0 221 116 002 = VW 111 905 105 J
coil 12V:
Bosch TK 12 A 16 = Bosch 0 221 102 016 = VW 122 905 115 B (??? not sure why 122, could be correct, but also be a typo on my Bosch source)
coil 12V partly used till February '65:
Bosch 0 221 117 001 = Bosch 0 221 117 002 = VW 111 905 115
spark plug:
Bosch W 175 T1 EA 0.7 = Bosch 0 241 235 001 = VW N 0178011 = VW 000 057 004
rain protection cap for plug connector:
Bosch WNK 1 Z 16 X = Bosch 1 230 522 011 = VW ???
generator 6V for 1.2 ltr. engine:
till November '63: Bosch LJ/REG 180/6/2500 L 3 = Bosch 0 101 212 001 = VW 113 903 021 B or 113 903 021 H (not sure)
from December '63: Bosch 0 101 212 004 = VW 111 903 021 F
generator 6V for 1.5 ltr. engine:
Bosch LJ/GEG 200/6/2600 L (19/10) = Bosch 0 101 206 067 = Bosch 0 101 206 105 = VW 211 903 021 B
generator 12V for 1.2 ltr. and 1.5 ltr engine:
Bosch LJ/GEG 450 M 12/3700 FL (19/10) = Bosch 0 101 206 064 = Bosch 0 101 206 106 = VW 113 903 031
regulator 6V:
Bosch RS/VA 200/6/3 = Bosch 0 190 350 008 = VW ?
Bosch 0 190 350 029 = Bosch 0 190 350 030 = VW 311 903 801
regulator 12V:
Bosch RS/VA 450 M 12 A 5 = Bosch 0 190 350 015 = Bosch 0 190 350 034 = VW 113 903 803
starter 6V for 1.5 ltr. engine:
Bosch AL/EGF 0,6/6 L 5 = Bosch 0 001 310 007 = Bosch 0 001 310 008 = VW 311 911 021
starter 12V for 1.5 ltr. engine:
Bosch AL/EEF 0,8/12 L 1 = Bosch 0 001 208 006 = Bosch 0 001 208 017 = VW 113 911 023
oil pressure switch:
Bosch SH/LO 10/13 = Bosch 0 344 101 013 = VW 113 919 081 =
Bosch SH/LO 10/14 = Bosch 0 344 101 014 = VW 113 919 081
As you can see, some parts have two similar Bosch numbers like Bosch 0 001 310 007 = Bosch 0 001 310 008
The reason is that the aftermarket got the parts with the Bosch number only.
To confuse us, the VW factory got the part with the aftermarket Bosch number and the VW number on it, but Bosch intern, they used a different number.
So you can find the same part with or without the VW number, but with the same Bosch number.
I've written all the numbers, because Bosch sometimes made exceptions to this.
What's a HV oil pump ? high volume ? on a single relief ? that will be restored ? not a good idea except you are talking about a 26mm cb maxi pump _________________ 1966 Bus | 1969 Bug | 1976 Passat LX two-door | 1984 Golf 2 C (daily driver)
There are three kinds of people: those who can count and those who can't
Und läuft ... |
Posted: Thu Jun 28, 2018 10:12 am Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
mr. lang wrote: |
distributor
coil 6V:
coil 12V:
spark plug:
regulator 6V:
regulator 12V:
What's a HV oil pump ? high volume ? on a single relief ? that will be restored ? not a good idea except you are talking about a 26mm cb maxi pump |
thank you for all this data... it is really helpful!
As for the oil pump I am talking about the standard one most people use now with slightly larger gears then stock that fits this case ... not the really big one . |
Posted: Thu Jun 28, 2018 9:32 pm Post subject: Re: 1963-1964 1500 CC ( 42 hp ) bus motor build |
Alan Brase wrote: |
tasb wrote: |
Alan Brase wrote: |
Al |
INK stamped? Stamped like a rubber stamp, white ink, maybe? I've seen a few. Didn't know when they started that practice. |
The first M code for an engine in a bus occurred in mid 1958 with the option of having a rpm governor installed= M 178. These were pretty rare as you might imagine. i've seen a few examples and the stamp was placed on the front, rear and both sides of the fan shroud, early on. That way when the engine was on the assembly floor the line crew knew that engine was going into a special ordered bus from any angle. Later on the stamp may have just been on the rear of the fan shroud facing the rear of the bus. They weren't intended to last past the factory floor.
