67ctbug Samba Member
Posted: Fri May 11, 2018 1:15 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
EMPIImp69 wrote: |
I'd fill in the gaps with by welding more before any seam sealing. Body mount could eventually crack the way it looks now. |
I'll fill it in a bit more... This repair is one of the pains of a '67, I had to modify a 68+ wheel well to get the proper stamping which meant moving the mount. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Posted: Fri May 11, 2018 8:52 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
And my welder ran out of gas today... might be getting a bigger tank. 2 months with this one and it's already empty. I guess I have been doing a lot of welding. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Sat May 12, 2018 2:41 am Post subject: Re: Restoring My New (to me) 1967 Bugii |
Regarding the tank. It doesn't have to be a bigger one. Just an extra one's a good idea too. I was looking for a welding gauge on Craigslist or eBay and found one that also came with a new tank. All for $50. Really comes in handy. |
Posted: Sat May 12, 2018 6:34 am Post subject: Re: Restoring My New (to me) 1967 Bug |
Yeah, but I rent(?) my tanks. I paid upfront and just pay for gas now. They said anytime I want, I can pay extra and start getting a bigger tank. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sun May 13, 2018 3:21 am Post subject: Re: Restoring My New (to me) 1967 Bug |
You own the tank if you paid an initial upfront payment. I do the same thing through tractor supply. They have multiple stores in my area.If they would happen to not have the size I use in one store I look on their website for which store it's available. As long as the tank is up to their standard they exchange. I get a different tank every time instead of waiting for a fill. The extra tank I bought they exchanged no problem and it's in there system. I would just ask where you buy the welding gas if they would take a stray one in there exchange system. |
Posted: Sun May 13, 2018 9:44 am Post subject: Re: Restoring My New (to me) 1967 Bug |
I swap tanks out too, instead of filling. I get them from airgas, so I doubt I could take it to tractor supply or get another one in their system. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sun May 13, 2018 4:18 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
What am I supposed to do with the wiring loom when I replace the driver side channel? Does it run along side it? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
REDKAFER Samba Member
Posted: Wed Jun 13, 2018 7:54 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
As far as I know, yes. I used a couple dots of adhesive paste to hold the harness in place. I fastened it to the heater channel under the lip where the sheet metal is spot welded together (might be a DANSK-specific feature, not sure), not the pan, and it will eventually be protected by the carpet and far enough out of the way its highly unlikely it will even ever be stepped on much less damaged. |
Offroader5 Samba Member
Joined: June 16, 2016 Posts: 27 Location: Apache Junction, AZ
Posted: Thu Jun 14, 2018 12:19 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Wow. Just looking at your pics of all the welding/replacement, it makes me feel lucky that my 67 is rust free. Don't know if I would want to do all this work. |
Posted: Thu Jun 14, 2018 12:46 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
REDKAFER wrote: |
Perfect, thanks, I'll do that.
Offroader5, you are lucky, you definitely don't want to do all this. Rust repair is a good skill though. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sat Jun 23, 2018 4:11 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
Alright I need some help, is this supposed to be perfectly straight?
It’s the rear quarter panel. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
EA812 Samba Member
Joined: December 07, 2008 Posts: 1223 Location: North central, CT
Posted: Sat Jun 23, 2018 4:42 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
EA812 Samba Member
Posted: Sat Jun 23, 2018 5:31 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
EA812 wrote: |
The gap from top to bottom should be the same yes. |
Are we talking about the same thing?
this is what I’m questioning. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
EA812 Samba Member
Posted: Sat Jun 23, 2018 6:32 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
EA812 wrote: |
The door gap between the two should be the same but it looks like the right shape in the last picture. |
Not the door gap, but the shape. When I put the plank on there, it is perfectly flat. No curve. I want to make sure that is right. The door gap on this side needs to be adjusted. The other side is like this too, I just want to make sure nothing is messed up. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
EA812 Samba Member
Posted: Thu Jun 28, 2018 7:54 pm Post subject: Re: Restoring My New (to me) 1967 Bug |
I put a straightedge to mine it looks more gentle of a curve than yours, but before you break out the bondo i think you should test-fit your running board and fender and see if it looks like they will install and fit decently.
If so, I really have to say that while the shape may not be spot-on, slathering your car with body filler is usually a poor answer to a not-that-big-a-deal situation. A little imperfect sheet metal is totally normal for a 51 year old car, where as a pound of "wavy gravy" body filler makes it look like the owner is embarrassed that their VW has a life story...
Apologies if that sounds judgy, I've just walked that path before and there is some regret... |
Posted: Mon Jul 02, 2018 5:14 am Post subject: Re: Restoring My New (to me) 1967 Bug |
I confirmed with another friend that it is supposed to be flat. If I were to put filler on though, I was only going to use a little. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
