My 66 Squareback 6V dual carb keeps dying
ajl1971
ajl1971 is offline
PostPosted: Tue Jun 19, 2018 7:33 pm    Post subject: My 66 Squareback 6V dual carb keeps dying Reply with quote
Hi guys.
For the past month or so I have been experiencing some problems with my Squareback, after running for few minutes it dies. The longest I drove it was for about 40 minutes and I thought I have fixed the problem. Now I can run it for 5-10 minutes. For the most part car starts right up.
These are the things I have done so far :
- Mechanical fuel pump is working
- Points were changed and calibrated
- Condenser were changed
- Coil was changed
- Distributor cap and rotor were changed
I dont know what else I can do. Here is a little video where you can see the car that was already running and at the end it just dies. It looks like I had flip a switch to turn it off. Lights still on the dash.
Is there anything else (electronically) that keeps the car running.
I do see like a relay and such underneath the backseat.
http://vimeo.com/275442824
Tram
Samba Socialist
Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Tram is offline
PostPosted: Tue Jun 19, 2018 8:51 pm    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
Check for 12v at the coil when it dies. If no power the switch may be heating up and losing contact.
Does it have fuel?
If so, is the ignition coil hot?
How old is the condenser?
Point gap too small?
How long since the last valve adjustment?
Are the chokes opening?
Does it have electromagnetic cutoff jets? If so, are they hooked up and working?
Bryan67 wrote:
To best contact me, please use the EMAIL function in my profile
ajl1971
ajl1971 is offline
PostPosted: Wed Jun 20, 2018 3:35 am    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
Does it have fuel?
Of course
Noy sure but it was replaced
New
017
2 years but only 300 miles driven
I think so because the car starts right up. its only after few minutes the car shuts off
Does it have electromagnetic cutoff jets? If so, are they hooked up and working Im going to check that, not sure yet
BTW car is 6v still
PostPosted: Thu Jun 21, 2018 9:12 am    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
I agree with checking power at the coil.
Does it start right back up or do you have to wait?
This could indicate something is getting hot and failing.
Bobnotch
Bobnotch is offline
PostPosted: Thu Jun 21, 2018 9:18 am    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
Does it have fuel?
I'm glad you decided to post your problem into an open forum. I didn't even think about a possible ignition switch being flaky.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
ajl1971
ajl1971 is offline
PostPosted: Thu Jun 21, 2018 10:07 am    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
Bobnotch wrote:
Does it have fuel?
How do i check a flaky ignotion switch, replacing it ?
ajl1971
ajl1971 is offline
PostPosted: Thu Jun 21, 2018 10:08 am    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
From what I can tell starts right up
Erik G
Erik G is offline
PostPosted: Thu Jun 21, 2018 10:21 am    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
ajl1971 wrote:
Bobnotch wrote:
Does it have fuel?
I would temporarily disconnect the wire at the coil that comes from the ignition (and tape it off). Run a new wire from the fuse box (one thats always hot) with a switch to the coil instead. Flip the switch, use your key to start it, should start right up. Drive it around. If it still acts up it's something else. If it's now fine, it's your ignition switch.
Bobnotch
Bobnotch is offline
PostPosted: Fri Jun 22, 2018 10:12 am    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
Erik G wrote:
ajl1971 wrote:
Bobnotch wrote:
Does it have fuel?
Yup. Exactly how I'd do it.
Tram wrote:
Tram wrote:
ajl1971
ajl1971 is offline
PostPosted: Mon Jun 25, 2018 3:57 am    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
I checked the carbs last night and I do have 2 Solex 32 Pic 3, each one has a cut off valve. Is there anyway to check a cut off valve ?
If one fails, both carbs dies or one just dies and the other carb should still be running ?
Thanks
Bobnotch
Bobnotch is offline
PostPosted: Mon Jun 25, 2018 9:07 am    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
Thanks
Carbs are independent of each other.
Tram wrote:
Tram wrote:
PostPosted: Mon Jun 25, 2018 9:12 am    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
Thanks
The electric cutoff valves? They are independent.
To check them, turn the key to on.
Disconnect the power wire to one of them, then reconnect it.
You should hear a click.
No click = it's bad.
ajl1971
ajl1971 is offline
PostPosted: Mon Jun 25, 2018 8:06 pm    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
Thanks
I heard when a cutoff valve is bad the engine wont idle but the engine should stay on at high rpm. Mine dies because because I cant rev it up.
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Jun 25, 2018 8:40 pm    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
I suppose it's possible a shorting EM jet could bring down the ignition voltage and affect both carbs as well as the spark. I haven't had that happen to me, however.
PostPosted: Mon Jun 25, 2018 10:52 pm    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
Thanks
Yes, it would stall at idle as it would be cutting off the idle circuit for gas.
When the car is revved up, you are "above" the idle circuit.
Bobnotch
Bobnotch is offline
PostPosted: Tue Jun 26, 2018 8:04 am    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
You might want to have a look at this link.
https://www.thesamba.com/vw/archives/manuals/t3dualcarbtuning/index.php
It might help answer some questions, along with helping you set them up to run correctly.
Tram wrote:
Tram wrote:
Erik G
Erik G is offline
PostPosted: Tue Jun 26, 2018 9:27 am    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
It's not very common for them to go bad though. also, they are on the same wire coming from your ignition to your coil which we went over earlier
ajl1971
ajl1971 is offline
PostPosted: Tue Jun 26, 2018 12:31 pm    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
Sorry but what is EM jet
Bobnotch
Bobnotch is offline
PostPosted: Wed Jun 27, 2018 10:21 am    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
Electro Mechanical jet.
Tram wrote:
Tram wrote:
ajl1971
ajl1971 is offline
PostPosted: Wed Jun 27, 2018 4:12 pm    Post subject: Re: My 66 Squareback 6V dual carb keeps dying Reply with quote
OK, I guess my carb has one, I need to know where its.
