herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Sat Jun 23, 2018 2:14 pm Post subject: 28 PICT: Oring needed on starter? |
Dismantled my 28pict for cleaning.
I'm in doubt about the piston that moves this little arm:
This is a small piston moved by depressure, its function is to eliminate starter action (when engaged) when gas pedal is depressed, probably to avoid an excessive enrichment under load.
The piston was stuck and the small duct was obstructed, so I cleaned all.
My question: this item:
has a groove... should it be filled with an oring? I did not found worn orings but I don't know if it has been removed or corroded into fuel.
An oring should be useful because on the left part there is depression, and the piston should work sealed.
But an oring could cause an excessive resistance to starter movement...
Any opinion?
Thank you |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34018 Location: Conejo Valley, CA
Posted: Sat Jun 23, 2018 3:29 pm Post subject: Re: 28 PICT: Oring needed on starter? |
Doesn't look like it:
p.s., For the USA folks, in Europe the carburetor choke is often referred to as the starter or strangler. |
Denny B Samba Member
Posted: Sat Jun 23, 2018 5:52 pm Post subject: Re: 28 PICT: Oring needed on starter? |
Is #187 an O Ring? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sat Jun 23, 2018 6:01 pm Post subject: Re: 28 PICT: Oring needed on starter? |
Denny B wrote: |
No, it is the plug at the rear end of the bore for the piston. _________________ In Stereo, Where Available! |
ddweave Samba Member
Joined: October 26, 2016 Posts: 4 Location: Waterloo, IL
Posted: Sat Jun 23, 2018 6:12 pm Post subject: Re: 28 PICT: Oring needed on starter? |
When you say starter are you referring to the choke? |
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Sat Jun 23, 2018 7:32 pm Post subject: Re: 28 PICT: Oring needed on starter? |
In other countries that is a term they use for choke. The "T" in PICT stands for "thermostarter"
And there is no O-ring on that piston.
_________________ Andy T.
Posted: Sun Jun 24, 2018 3:59 am Post subject: Re: 28 PICT: Oring needed on starter? |
Sorry for my mistake, in Italy we use "starter" for the carburetor enrichment; the word "starter" sounds as an english term so I thought it was OK in an US forum.
The thing I supposed had to be an o-ring is the item n.151 in the KtPhil's design.
Thank you glutamodo, the pictures you post seems to indicate that no oring is required.
BUT... I have time so spent some time to mount one oring
I had to modify a little the oring to permit a good piston moving.
The first impression: now the starter (the automatic chocke!) has a little difficulty to "engage" the cold position... I wil test a few days then decide if remove or mantain the oring.
This is an opportunity to look at the piston working without the final cover, verifying if it moves and has some utility.
I will post my results.
Thank you,
Simone |
Posted: Sun Jun 24, 2018 4:30 am Post subject: Re: 28 PICT: Oring needed on starter? |
VW replaced that choke pull-off design pretty quickly for a reason I think, they came up with something better, both with a better heating element and a better, more easily serviced pull-back diaphragm setup.
I went to a PICT-1 top on my 28PICT carb decades ago.
Yes, that piston is pretty much a metal plug in a metal shaft and any kind of gunk in there will impede its movement. I think an O-ring might be more detrimental than helpful. _________________ Andy T.
Posted: Sun Jun 24, 2018 11:49 pm Post subject: Re: 28 PICT: Oring needed on starter? |
OK, thanks to all.
I removed the o-ring on the chocke pull-off piston because the heated spring is not strong enough to engage the chocking when cold.
Then made my test and all seems to work: with engine running and chocke 'on' (detached the connector to keep it on) the valve is visibly pulled by the piston when rpm are increased. |
Posted: Mon Jun 25, 2018 4:44 am Post subject: Re: 28 PICT: Oring needed on starter? |
Sounds good then! _________________ Andy T.
Posted: Mon Jun 25, 2018 6:18 am Post subject: Re: 28 PICT: Oring needed on starter? |
Yes, all seems to work.
I used a different way to remove the plug: instead of drilling it, destroying the item, I simply pushed the leg of the piston outward, a little force has been enough to make the plug "jumping" out of its seat. |
KTPhil Samba Member
Posted: Mon Jun 25, 2018 8:25 am Post subject: Re: 28 PICT: Oring needed on starter? |
herbie1200 wrote: |
If it comes out that easily, it may not be sealing well, so a light bead of gas-tolerant sealant along the perimeter may help it work most effectively. |
Posted: Mon Jun 25, 2018 10:40 am Post subject: Re: 28 PICT: Oring needed on starter? |
Yeah it's not like VW didn't specify that the end cap of that "cylinder" should be installed with "sealing compound". _________________ Andy T.
