ThomasC Samba Member
Posted: Mon Jun 25, 2018 10:33 am Post subject: Why Is There A Drill-Bit Sticking Out Of My Hose? |
I got my new project 1991 Carat and I noticed something odd. There was a drill bit sticking out of a hose? does anybody know what this is or where it leads to? Also, what are these other tanks? I know this is most likely a very simple question, but I can't find anything telling me what these do. Yes, I do have a Bentley, but I want a human to tell me what is what. Any help will be MASSIvely appreciated. I'm very new to all of this, being so young, and I want to learn EVERYTHING about it. Thanks in advance!
_________________ '91 Vanagon Carat Auto
'89 Vanagon White Star Auto SOLD
'89 Cabby SOLD
1970 Standard Beetle
2004 Golf |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2779 Location: North Carolina
Posted: Mon Jun 25, 2018 10:42 am Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
I don't know why there's a drill bit coming out of that hose because I can't tell from your picture where it's supposed to go or what the other end is hooked up to. I'd say that's a really primitive attempt to plug a hose from some reason.
Your other photos:
- plug attached to alternator is a port for a defunct dealer testing machine. It is decorative now.
- The black tower is your crankcase breather. Releases crankcase pressure, oil blows by it you overfill (looking in mirror). Ignore it for now, not initially important.
- The tank with blue cap is your main coolant tank, under pressure, do not remove lid when hot. Looks nice and full that's good.
- The tank with the clear lid is your coolant overflow.
- The dipstick is your dipstick. You use it to check oil.
That's a big ole project you got there. Does it run? _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
SCM Samba Member
Joined: January 26, 2011 Posts: 3101 Location: Bozeman MT
Posted: Mon Jun 25, 2018 10:43 am Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
I have no idea why that hose is plugged with a drill bit or where it should go. Did you follow the other end to see where it ends?
The 3-pronged plug you're pointing to was used for some sort of diagnostic test and is obsolete, no longer used. You can ignore it.
The next photo shows the oil breather tower.
The tank with the blue cap is you coolant expansion tank and should always be totally or almost totally full with anti-freeze. It becomes pressurized so don't open that cap when the engine is hot.
The tank with the white cap behind the license plate is the coolant overflow tank. There's a MIN and MAX line on the right side of it to indicate the proper coolant level. That tank is not pressurized.
That stick-like thing with the loop on the end is your oil dipstick. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
?Waldo? Samba Member
First off, read your owner's manual. It answers a few of your questions and relates a plethora of other useful information.
The drill bit is plugging the hose. I can't say where the hose should go because I cannot see what it is connected to. Pulling the drill bit and seeing if if was connected to the coolant ring or to vacuum would help in determining where it goes.
The 3-pin connector on the alt is for the obsolete dealership diagnostic tool. It does nothing and can be ignored.
The black plastic tower you point to is the crank vent setup.
The tank with the blue cap is the pressure tank (coolant). It should always be completely full.
The tank with the white cap is the "burp' tank (also coolant). You should maintain the coolant level between the marks.
Next up is your engine oil dipstick. Keep the level at the center of the two marks.
Get rid of the K&N filter. They suck at filtering. Get quality paper element filter instead. |
Posted: Mon Jun 25, 2018 11:09 am Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
Alright, I replaced the oil filter, fuel filter, fuel pump, spark plugs, oil, coolant, ATF, drained the gas tank, drained the lines, and I haven't attempted to start it yet, I'm hoping to try that today, but I want to make sure I don't blow anything up so, here's where this odd hose goes? thanks for the replies everyone, It's refreshing how nice the VW community is!
'89 Cabby SOLD
2004 Golf |
SCM Samba Member
Posted: Mon Jun 25, 2018 11:14 am Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
More pictures of the plugged end of the hose aren't going to help. You need to get dirty, crawl around under the van until you see what the other end of the hose connects to. Post a picture of that. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Paulbeard Samba Member
Posted: Mon Jun 25, 2018 11:17 am Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
mikemtnbike wrote: |
You can verify that it works by blowing into that nipple the hose is hooked up to. Fullness of the tank isn't much to go by.
https://www.youtube.com/watch?v=RT8Ew43mNg4 <— see this primer
If it doesn't work, you know how to test any replacement you get, when you get it running.
And get yourself some gloves…saves some time cleaning up afterwards. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers
SCM wrote: |
More pictures of the plugged end of the hose aren't going to help. You need to get dirty, crawl around under the van until you see what the other end of the hose connects to. Post a picture of that. |
Gotcha! I'll start now _________________ '91 Vanagon Carat Auto
'89 Cabby SOLD
2004 Golf |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15129 Location: Syracuse, NY
that is (was) for your cruise control system
the plugged hose would have gone into the back of the actuator that pulled on the throttle for you while in operation.
Abscate wrote: |
Altoona Samba Member
Posted: Mon Jun 25, 2018 11:20 am Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
Looks like the vacuum hose that attached to the cruise control actuator. Obviously, the cruise system wasn't working so they capped it off.
Pretty sure you can just disconnect the hose and forget about it until you want to start digging into the cruise system. |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3414 Location: OR & CA (Oregon/California)
that hose is for the cruise control. |
9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Mon Jun 25, 2018 11:26 am Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
0to60in6min wrote: |
winner winner chicken dinner!!
The part number is for the cruise control vacuum pump
EDIT: darn it looks like I came late to the party ............ again _________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi
Last edited by 9.5isCanadian on Mon Jun 25, 2018 11:28 am; edited 1 time in total |
Posted: Mon Jun 25, 2018 11:27 am Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
Alright, sweet! So no cruise control, but I am good to start the van without cruise control? Thx again! _________________ '91 Vanagon Carat Auto
'89 Cabby SOLD
2004 Golf |
Posted: Mon Jun 25, 2018 11:39 am Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
Sure, why not what's the worse that could happen?
I'll answer that: the fuel lines need to be replaced, they're known to degrade d/t ethanol in modern fuels. If it fires up, great, turn it off and replace all the soft fuel lines from the tank to the injectors, and back. Hard lines are ok to leave. That should be done before the van gets on the road. well, and you need headlights, but guessing you noticed that. If you don't do this, your van could fire up in bad way... _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
Abscate Samba Member
Joined: October 05, 2014 Posts: 22568 Location: NYC/Upstate/ROW
Posted: Mon Jun 25, 2018 11:52 am Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
More importantly, that drill bit tells you the previous owner and all work and maintenance duly performed was of dubious quality _________________ .ssS! |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12103 Location: Port Manteau
Posted: Mon Jun 25, 2018 12:08 pm Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
I swear when I read the title the word was nose. I was expecting a thread full of blood and tales of woe. Disappoint I am. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Mon Jun 25, 2018 12:47 pm Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
Especially since in fact that hose doesn't need to be plugged except to prevent mud dauber packing.. the hose is not connected to nor does it effect engine performance.
Abscate wrote: |
More importantly, that drill bit tells you the previous owner and all work and maintenance duly performed was of dubious quality |
Abscate wrote: |
Posted: Mon Jun 25, 2018 1:05 pm Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
danfromsyr wrote: |
Abscate wrote: |
Ive got it. PO was saving money by using a drill bit instead of a whole drill.
Wouldn't that need to be plugged to prevent a vacuum leak - or are there check valves in line? _________________ .ssS! |
Posted: Mon Jun 25, 2018 1:45 pm Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
Vacuum is generated by the electric pump. CC is a stand alone system unrelated to the engine except for the vacuum actuator (missing here). _________________ Casey--
y u rune klassik? |
Posted: Mon Jun 25, 2018 1:56 pm Post subject: Re: Why Is There A Drill-Bit Sticking Out Of My Hose? |
Zeitgeist 13 wrote: |
Vacuum is generated by the electric pump. CC is a stand alone system unrelated to the engine except for the vacuum actuator (missing here). |
Enlightenment is burst upon me like 1000 supernovae.
Separate CC vacuum - that doesn't suck. Well, it does actually.
Can we tell the next guy who asks what a hose is for, that it is for storing drill bits? _________________ .ssS! |
