Horn Ring Component?
GregKnod
GregKnod is offline
PostPosted: Sun Jul 01, 2018 6:09 pm    Post subject: Horn Ring Component? Reply with quote
Want to confirm if this item is from the horn ring or in that section of the car. It fell out during the disassembly.
'73 Westy Weekender sharing the garage with a '66 Ocean Blue Beetle (daily drivers are out in the weather)
hitest
hitest is offline
PostPosted: Sun Jul 01, 2018 6:34 pm    Post subject: Re: Horn Ring Component? Reply with quote
With no sense of scale- I'd guess if it's sitting on a hand towel then it's a horn wire anchor plate. It should have been held with a screw.
FU#5
mukluk
mukluk is offline
PostPosted: Sun Jul 01, 2018 6:53 pm    Post subject: Re: Horn Ring Component? Reply with quote
Looks like the plate the turn signal switch set screw threads in to, holds the switch in place on the steering column tube.
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Sun Jul 01, 2018 7:08 pm    Post subject: Re: Horn Ring Component? Reply with quote
yep for the turn signal set screw
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
RareAir
RareAir is offline
PostPosted: Sun Jul 01, 2018 9:31 pm    Post subject: Re: Horn Ring Component? Reply with quote
X3
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
GregKnod
GregKnod is offline
PostPosted: Sun Jul 01, 2018 9:45 pm    Post subject: Re: Horn Ring Component? Reply with quote
Cool - thanks.
hitest
hitest is offline
PostPosted: Mon Jul 02, 2018 10:01 am    Post subject: Re: Horn Ring Component? Reply with quote
Good to learn ! Cool
FU#5
