jtrashy Samba Member
Joined: November 27, 2005 Posts: 129 Location: SF, CA
Posted: Tue Jul 03, 2018 12:33 pm Post subject: Rear brakes after new shoes need pumping |
replaced the shoes/springs, didnt open and mess with any of the brake hydraulics. adjusted the shoes to barely rub with drums on.
the brake pedal doesnt have much resistance unless i pump it a few times, do i need to bleed them even though I didnt change anything with the hydraulics???
Thanks. |
SCM Samba Member
Joined: January 26, 2011 Posts: 3115 Location: Bozeman MT
Posted: Tue Jul 03, 2018 12:38 pm Post subject: Re: Rear brakes after new shoes need pumping |
jtrashy wrote: |
Thanks. |
You shouldn't need to. Perhaps the shoes aren't adjusted outward enough. How does the E-brake feel? _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Tue Jul 03, 2018 12:45 pm Post subject: Re: Rear brakes after new shoes need pumping |
thats what i thought.
e-brake not connected cuz missing a plastic piece mid connect. |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4348 Location: United States, Iowa
Posted: Tue Jul 03, 2018 1:08 pm Post subject: Re: Rear brakes after new shoes need pumping |
from a few old posts re this same kind of issue?
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=60
By Terry K:
Here's an old school operation that may give you a hand in getting the proper peliminary adjustment,and allowing the entire brake shoe to make contact with the drum.
Radius the shoes to the drum first.
What this means is prior to mounting the shoes,& the drums you lay the shoes into the inside of the drums and make sure the entire face of the shoe is making contact with the drum.
If not ( and ths sure sounds like what you have going on here ) sand, grind the face of the shoe so all of it evenly makes contact with the inside of the drum.
quoted from ragnar, with GOOD visuals of what this means..:
ragnarhairybreeks wrote: |
I bought these shoes from my FLAPS a while back. IIRC, they were Beck-Arnley labelled shoes. One shoe longer than the other, and upon a cursory examination they fitted fairly well to the drum.
alistair |
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
Posted: Tue Jul 03, 2018 1:49 pm Post subject: Re: Rear brakes after new shoes need pumping |
jtrashy wrote: |
The shoes themselves need to be adjusted then if required, the e-brake. This is shown in Bentley. Of particular importance is the small gap shown between e-brake lever and part that operates the shoe(s). I found a shoe measurement tool to be quite useful to get initial adjustment.
If the pedal needs to be pumped it could be a shoe(s) adjustment issue or issue at master cylinder.
If there's any doubt about how the hardware was assembled, there are images here showing factory assembled new brake back plate, hardware, shoes etc.
Neil.
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
