notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Wed Jul 04, 2018 12:07 pm Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
Now were talking. Sweet shots of the goodies _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Squeeze Cheese Samba Member
Joined: August 18, 2015 Posts: 268 Location: Atlanta, GA
Posted: Thu Jul 05, 2018 1:58 pm Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
Okay, last photo post. Just some leftover interesting bits and oddities, and some questions I still have about this bus.
Possibly a "rare" part? Headrest delete plug, part# 211.881.863:
A peek behind the front kick panels:
Behind a door card, showing uncut original vapor barrier:
Here's what remained of the original front seat horsehair padding! The rest was crumbled onto the seat pedestals.
Interesting there's two tow hooks, my other buses only had one?
Some shots of the BA6 heater, belly pan removed, which I have yet to remove and inspect for reliable use. You may also notice what I'd consider a very well applied, durable, and effective undercoating:
Questions. What's this cleat for? It's too high for the stool straps to loop through.
I don't know how to date old tires. No way its possible these are originals, 43 years old and still holding air? (Yes I know they're not safe either way!) They are Michelin XZX 185 SR 14 "Made in W. Germany".
btripp noted that the refrigerator is unlike the model in his federal orange 75' We're thinking it may a Euro or Canada spec. Anyone have this one? It has just one combination on/off/thermostat knob inside.
Anyway, I'd like to thank you all for reading, commenting, and enjoying this unique survivor I'm just lucky to have. Like I said, please let me know if you can offer any insights, have any questions, or would like to see anything else. _________________ 78' Dakota Beige Westy. “Skills” EJ25 engine conversion w/ zero mile factory short block, Delta 1000 cams, heater core and modified Gilmore AC. Matt Steedle 091 transaxle upgrade w/ 4.14 ring and pinion, Folts aluminum gear carrier. General Grabber AT2s on stock wheels. Solar powered aux battery w/ inverter. |
busdaddy Samba Member
Posted: Thu Jul 05, 2018 2:16 pm Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
Try sitting your dash table on those cleats on the side of the fridge and sink cabinets _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
furgo Samba Member
Joined: September 06, 2016 Posts: 944 Location: Southern Germany
Posted: Thu Jul 05, 2018 2:18 pm Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
Interesting. I had never seen the polystyrene foam panel there. I now understand the few remaining bits of it behind my kick panels. Actually on the floor, as there weren't any remains still attached to the chassis after all these years.
What was the function of the polystyrene there? Sound dampening? Insulation?
Also, looking at the one-way screw terminal block behind the headlight bucket, it would seem a PO did a modification there perhaps? _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate |
Posted: Thu Jul 05, 2018 2:27 pm Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
furgo wrote: |
Also, looking at the one-way screw terminal block behind the headlight bucket, it would seem a PO did a modification there perhaps? |
Yea, that foam is actually glued on there, and obviously before the dash is installed because you'd never get it out in one piece without removing everything first. It's for sound and insulation, but they used the styrofoam rather than fiberglass to minimize moisture.
I don't know if the headlight mod was a PO, factory, or dealer upgrade, but it's for the H4 headlights which I suspect were installed when the bus was in Germany in 1975, since they were legal and available in Europe. _________________ 78' Dakota Beige Westy. “Skills” EJ25 engine conversion w/ zero mile factory short block, Delta 1000 cams, heater core and modified Gilmore AC. Matt Steedle 091 transaxle upgrade w/ 4.14 ring and pinion, Folts aluminum gear carrier. General Grabber AT2s on stock wheels. Solar powered aux battery w/ inverter. |
furgo Samba Member
Posted: Thu Jul 05, 2018 3:12 pm Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
Perhaps that wire is for the city lights?
I keep looking at that picture and comparing it to the one I took from my bus a while ago, same angle.
Another thing I noticed is that below the windshield washer fluid reservoir, on its bracket, there is what seems to be an 8-way connector. I don't have it on my bus, and I can't find it in the wiring diagrams either. The only such connector listed there is T8, behind the dash. I wonder what yours is, as it would seem to be original.
http://www.vintagebus.com/wiring/bus-76.jpg
http://www.vintagebus.com/wiring/bus-76-key-1.jpg
http://www.vintagebus.com/wiring/bus-76-key-2.jpg _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Posted: Thu Jul 05, 2018 3:34 pm Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
That's the harness for the belly mounted BA-6 heater.
The wires into the headlight buckets do look like city lights, although VW didn't do it since it's stuffed through a hole drilled in the back of the bucket, is there even a grommet on there? Factory ones had the wire in the harness, that one looks like they pulled the wire off the back of the signal and rerouted it to the headlight. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Jareb Samba Member
Joined: October 09, 2007 Posts: 1 Location: Treasure Coast, Florida
Posted: Thu Jul 05, 2018 4:08 pm Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
I've been a member here for 11 years and have never made a post. I just lurk, read and learn. This bus is worthy of my first post. All I can say is "Wow, just Wow"! |
Abscate Samba Member
Posted: Thu Jul 05, 2018 8:00 pm Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
Is that178 date code
Week 1 , 1978 ? _________________ .ssS! |
sunny74 Samba Member
Joined: November 13, 2017 Posts: 41 Location: Wisconsin
Posted: Fri Jul 06, 2018 4:35 am Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
That is really something special. Awesome! |
thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Fri Jul 06, 2018 4:57 am Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
Squeeze Cheese wrote: |
These are common on Transporters. All middle and rear seats in the back had them unless headrests were installed from the factory or dealer. Yours might have been installed to "delete" the headrests in the front since there's so much Euro spec stuff on the bus
_________________ '73 Transporter 1.7L Dual Carb
notchboy wrote: |
You ran over some #Vanlife'ers hopes and dreams? |
60vwnewengland wrote: |
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri Jul 06, 2018 5:14 am Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
Yes, I also get first week 1978 on the tires...
My 1973 bus has most of the styrofoam front clip panel...
The headrest plugs seem more common than the actual set of headrests. I went to the trouble of collecting a complete (7) set of headrests for mine out of the junkyard.
This whole thread has been a real treat! |
911GT2 Samba Member
Joined: January 19, 2013 Posts: 180 Location: Nederland
Posted: Fri Jul 06, 2018 5:32 am Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
jtauxe wrote: |
Just... wow. A time capsule indeed.
Get that thing back into a garage or something, now! Do not let it sit outside in the sun and rain and treesap. Ideally, this would be in a museum, or a VW showroom, or something. It should be preserved.
I agree with the sentiment that you are the current caretaker, or custodian, of this rare piece. That's how I feel about my buses.
I have a similar radio in the '75 single cab. Mine was spec'd on the M-codes as a Blaupunkt Ingolstadt, and I managed to source one from Germany. It also has the MMMUU buttons.
And... about the low mileage. I wonder how many of these there are. I just sold a 1972 Sportsmobile with 55,000 miles on it, and while it was nice and had a lot of original stuff on it, it was not factory fresh like the one you have there. It sat out in the sun for years, and it shows. |
No please don't store it especially not in a museum! Use it like it's intended to. But with respect and keep her Original! |
curtp07 Samba Member
Posted: Fri Jul 06, 2018 6:12 am Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
Exact same layout as my orange 75. _________________ Subaru |
Posted: Sun Jul 08, 2018 11:26 am Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
Wasted youth wrote: |
Yes, I also get first week 1978 on the tires... |
Amazing. 40 years and they still hold pressure. Thanks! _________________ 78' Dakota Beige Westy. “Skills” EJ25 engine conversion w/ zero mile factory short block, Delta 1000 cams, heater core and modified Gilmore AC. Matt Steedle 091 transaxle upgrade w/ 4.14 ring and pinion, Folts aluminum gear carrier. General Grabber AT2s on stock wheels. Solar powered aux battery w/ inverter. |
Tcash Samba Member
Posted: Sun Jul 08, 2018 3:32 pm Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
hazetguy wrote: |
Thanks for all the engine pics.
I find it interesting that there is a heat dump tube on the right flapper box, but not one on the left.
I did not catch this earlier... I thought the heat dump tubes were 1978 only. My 1977 and 1973 do not have them, anyway. My '78 does, so can someone clue me in on this? |
Hoody Samba Member
Posted: Sun Jul 08, 2018 10:54 pm Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
I am pretty sure that cleat you inquired about was to secure the Westy stool. Not the between the seats storage box but an actual stool that they came with. Judging by the looks of the bottom of that heater box it appears as though the PO decided to go over a large rock he shouldn’t have. My guess is the heat dump tube got mangled and rather than fix it or replace it he just removed it. You are also missing the uber important bracket-hanger for the rear of the heater box. |
Posted: Mon Jul 09, 2018 12:13 pm Post subject: Re: Brilliant Orange Time Capsule: A 39K mi bus and its OG/NLA parts |
Yea, you saw the ones on the tin, I'll have to take a look behind the wheel for that one. Any others? Isn't there a VIN marking somewhere in the undercarriage? _________________ 78' Dakota Beige Westy. “Skills” EJ25 engine conversion w/ zero mile factory short block, Delta 1000 cams, heater core and modified Gilmore AC. Matt Steedle 091 transaxle upgrade w/ 4.14 ring and pinion, Folts aluminum gear carrier. General Grabber AT2s on stock wheels. Solar powered aux battery w/ inverter.
Last edited by Squeeze Cheese on Mon Jul 09, 2018 12:33 pm; edited 1 time in total |
