ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Fri Jul 06, 2018 8:42 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
Well, being the noob that I am, I have no idea of I did it right but I counted ~5.75:1.
I wasn't able to rotate the selector shaft but I was able to pull it out. I'm not sure how much force is required to rotate it but pliers didn't help. When I put the nose cone back on I made sure all the selector keys were the same height (so it should have been in neutral, right).
I also measured the bellhousing from the base to the starter flange and it measured 3 1/4" which should mean I have a 091 bellhousing and therefore a larger 228mm flywheel and the longer starter, correct? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Fri Jul 06, 2018 8:49 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
SGKent wrote: |
Shane - the case on an 091 is better than the 002. If your 002 works then you can sell it after you find an 091. The best place to have a 091 rebuilt is Eric at Transworks in El Cajon CA, down near AeroMech. That comes from Rick Long when he retired. 091 come up for sale all the time - you just won't know what condition they are in until you either run it or someone like Eric takes it apart. There is one in Elverta in CL right now. Offer the guy $450 and see if he will take that or $100 more since he can't guarantee it works. Lots of sandrail folks buy them. https://sacramento.craigslist.org/pts/d/vw-busrib-transmission/6631355808.html |
I saw that ad, it looks like it's already dropped $50.
Is this the same place? The website says prices haven't been updated since 2007 and it lists the rebuild price of $400 which seems ridiculously cheap.
http://www.transworks.biz/rebuilt.html _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Tcash Samba Member
Posted: Fri Jul 06, 2018 9:06 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
In the Neutral position you should be able to rotate the shaft without too much effort. You may need vise grips to hold the shift lever.
Make sure you can rotate it before you put the tranny in.
That would be Neutral.
Should be. But measure the clutch disc to be sure.
This is a 200mm disc
Posted: Fri Jul 06, 2018 9:19 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
Tcash wrote: |
When I put the nose cone on I inserted the hockey stick into the ball joint.
I measured the clutch disc and it measured 228mm. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Tcash Samba Member
Posted: Fri Jul 06, 2018 10:02 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
If the input shaft is the correct length. Your good to go.
Posted: Fri Jul 06, 2018 10:21 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
I measured 26mm.
So what does all this mean? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Tcash Samba Member
Posted: Sat Jul 07, 2018 7:36 am Post subject: Re: Sealing the nose cone (with steel plate)? |
ivwshane wrote: |
I measured 26mm.
So what does all this mean? |
28-26 I don't think 2mm is going to make a difference.
This means the 091 Bell housing and input shaft where installed on the 002 trans to run on the Type IV engine.
Other than your questionable gearing. Which may not be a factor if you run around town most of the time. The transmission will bolt right up to your Type IV motor.
GD
Tcash |
Posted: Sat Jul 07, 2018 9:49 am Post subject: Re: Sealing the nose cone (with steel plate)? |
Tcash wrote: |
ivwshane wrote: |
I measured 26mm.
GD
Tcash |
Most of my driving is freeway.
Should I check the trans in another gear to see if maybe I wasn't measuring it in fourth correctly?
I would hate to waste money on a transmission if it's not going yield me any gains other than a stronger case (at least for now anyway). _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Tcash Samba Member
Posted: Sun Jul 08, 2018 8:48 am Post subject: Re: Sealing the nose cone (with steel plate)? |
Throw it in and try it?
Good luck
Tcash |
Posted: Sun Jul 08, 2018 6:08 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
Tcash wrote: |
Good luck
Tcash |
Try what? My transmission is good and was working great before I dropped the engine. I'm just trying to make everything right and do this engine drop once. Dropping the engine and trans is not a trivial thing for me so I prefer to take care of everything now.
The question/issue is whether or not my transmission is really a 091 gearing inside of a 002 housing. A 091 transmission inside of an 002 housing, while not as strong, would not be a deal breaker for me. However, if I'm not getting any benefit from having an 002 transmission then I'd rather get it replaced when a 091. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Mon Jul 09, 2018 9:31 am Post subject: Re: Sealing the nose cone (with steel plate)? |
It doesn't look like an 091 carrier installed on an 002 main case, but measuring the thickness of this flange will tell you. The 091 is 10mm thicker than the 002 to accommodate wider 3rd & 4th gears. (Someone else needs to supply dimensions, as I'm far from any cores.)
Even if it's 002, this doesn't mean it hasn't been rebuilt with an 002-style 4.57 R&P. At least half the transaxles floating around have been rebuilt at least once. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Wed Jul 11, 2018 5:45 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
gears wrote: |
Even if it's 002, this doesn't mean it hasn't been rebuilt with an 002-style 4.57 R&P. At least half the transaxles floating around have been rebuilt at least once. |
Thanks. I'm going to assume its not since that part of the transmission has an 002 part #. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Tue Aug 14, 2018 5:36 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
So my refurbished, new to me, 091 came in today! I had a core I got from bustedbus sent to transworks in el Cajon and they were able to get it back to me in a week!
I had to add the nose cone yoke and a throw out bearing. Besides those items is there anything else I should look at and inspect before I install it? What oil should I use and what is the recommended break in procedure (I guess I could call transworks).
Since this will be the first time I've ever installed a transmission, are there any tips or issues I need to be aware of? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Aug 14, 2018 5:58 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
Looks spiffy!, sand the paint off the starter pad while it's easy to get at, spiff doesn't conduct electricity all that well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Tue Aug 14, 2018 7:01 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
Rick Long said Eris is as good as it gets on the west coast for bus transmission rebuilds. Enjoy. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Tue Aug 14, 2018 8:34 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
Hell, I’m even excited and I have no idea why..... _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20279 Location: Sandpoint, ID
Posted: Tue Aug 14, 2018 9:16 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
Just for the record, RTV can be used on both sides of the steel thrust plate. I have done it before, and I am about to do the same thing on the 002 in my 68 single cab. _________________ nothing |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Wed Aug 15, 2018 6:29 am Post subject: Re: Sealing the nose cone (with steel plate)? |
busdaddy wrote: |
Looks spiffy!, sand the paint off the starter pad while it's easy to get at, spiff doesn't conduct electricity all that well. |
I recommend Transworks and Eric is a great guy but he paints the starter pads. I called him about it and he thought I was nuts. He also says GL-5 is fine. I removed the starter pad paint anyway. Then applied conductive grease to it before installing the starter.
Grease
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent Samba Member
Posted: Wed Aug 15, 2018 7:11 am Post subject: Re: Sealing the nose cone (with steel plate)? |
GL5 is fine if he isn't using the moly coated synchros. VW has both moly coated, and the lesser expensive plain brass synchros. You'd have to ask Eric what he used before using GL5 or a synthetic. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Aug 16, 2018 10:40 pm Post subject: Re: Sealing the nose cone (with steel plate)? |
I'm looking at the Bentley, page 6-12 figure 4-1 and it shows rubber stops on the bonded rubber yoke. I know my old transmission didn't have these so I'm trying to source some.
Does anyone have a part number for them or a source?
Also, my limited stop (item 13 on the page) doesn't have grooves like I'm the picture, is that a big deal? Mine is a just a thick piece of rectangular metal. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
