The Stupid Question Thread
Page: Previous  1, 2, 3 ... 373, 374, 375 ... 513, 514, 515  Next
Globespotter
Globespotter is offline
PostPosted: Thu Jun 28, 2018 12:56 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Wildthings wrote:
Globespotter wrote:
So the engine on my 77 Westy is out for a rebuild. Any advice on what to do while it is out?
I have already replaced the fuel filler and vapor lines. Thinking I'll pull the sender and fix it. Any other tasks while I'm in there?
Reseal your tranny if it has not been done in a while. Also install a shift bushing kit while the tranny is out.
Tranny is not out. Just engine.
1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
1971 SB Survivor Story: https://globespotter.com/
Road Trip Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=511800&highlight=
My 77 Westy Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=647114&highlight=
http://vw-mplate.com/mcode.php?lang=EN&id=30990
https://vw-type2-id.xyz/mplate/72067382
Wildthings
Wildthings is offline
PostPosted: Thu Jun 28, 2018 1:00 pm    Post subject: Re: The Stupid Question Thread Reply with quote
It takes little time to pull the tranny while the engine is out, while you can not remove the tranny while the engine is in. Good time to clean and repack the CV's as well.
The seals are cheap.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Fri Jun 29, 2018 10:41 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Cleaning the transaxle is MUCH easier with it out, and a clean transaxle runs cooler and therefore lasts longer. +1 vote for "do it!"
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
alman72
alman72 is offline
PostPosted: Fri Jul 06, 2018 5:35 pm    Post subject: Re: The Stupid Question Thread Reply with quote
what is the quality go-to for push rod seals?
cv66seabear
cv66seabear is offline
PostPosted: Sat Jul 07, 2018 6:39 am    Post subject: Re: The Stupid Question Thread Reply with quote
Quick questions re: clutch cable replacement- So far, I've heard to grease the entire cable and grease just the part that goes through the Bowden tube.
Which is correct? If I grease the length am I just asking for the grease to pick up dirt and gunk?
Replace the Bowden tube everytime or just if it appears damaged?
Thanks!
KentWI
"Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy"
Tcash
Tcash is offline
PostPosted: Sat Jul 07, 2018 7:28 am    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks!
KentWI
The clutch cable experiences tension through out the entire cable. The greatest tension being experienced in the rubbing surfaces i.e. tubes, pulleys. To add to that, the cable rust.
The cable should be Lubricated with a Penetrating protective lube its entire length.
Then apply a top coating lubricant to the high friction areas i.e. tubes and pulleys.
A little reading
https://www.machinerylubrication.com/Read/372/wire-rope-lubrication
The Bowden tube is a wear item. If it shows no signs of wear run it again. But if it shows any wear at all replace it.
GD
Tcash
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Sat Jul 07, 2018 7:36 am    Post subject: Re: The Stupid Question Thread Reply with quote
If the bowden tube looks aged at all, I pitch it in the trash. They are cheap. Make sure you get the best quality bowden tube as well.
The Samba member since 2004.
Tcash
Tcash is offline
PostPosted: Sat Jul 07, 2018 9:07 am    Post subject: Re: The Stupid Question Thread Reply with quote
The last Gemo Bowden tube I got was good construction.
https://www.google.com/search?client=safari&rl...p;oe=UTF-8
busdaddy
busdaddy is online now
PostPosted: Sat Jul 07, 2018 10:13 am    Post subject: Re: The Stupid Question Thread Reply with quote
For what kind of engine?
Слава Україні!
Mispeld
Mispeld is offline
PostPosted: Sat Jul 07, 2018 11:19 am    Post subject: Re: The Stupid Question Thread Reply with quote
I've been looking for diagrams for the vapor lines. PO just connected the two together above the engine lid. From what I've seen, there is a T fitting, then goes to the Air cleaner? One line is curved so it doesn't look like a T fitting goes there.
Currently, a vacuum line goes from the diaphragm looking part on the air cleaner to the charcoal canister and T's off to the metal part below the charcoal canister.
What's wrong? What am I missing? Yes, hoses will be replaced in the near future. It's on my looooong list of things to do. Thanks.
Tom
1977 Westy. 2.0 Fuel Injected.
busdaddy
PostPosted: Sat Jul 07, 2018 12:16 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Now that's some seriously creative vacuum line placement, go ahead, blame your PO Very Happy
The 2 lines in the roof of the engine compartment Tee together, the RH (darker colored) line needs to swing forward to pick up the side branch of the Tee when one end is on the green line, from there it goes to the small fitting on your charcoal canister (the one currently connected to your decel and EEC valves Confused ). Have a look at this: http://www.ratwell.com/technical/VacuumHoses.html
Definitely change those hoses, it's suprising it even runs with those on there, here's how it should be plumbed:
Слава Україні!
Mispeld
Mispeld is offline
PostPosted: Sat Jul 07, 2018 1:40 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Yep, PO. I'm sticking with that. Razz
Thanks again busdaddy, you just answered every question I had. I corrected them all with the exception of the vapor lines. I need to pick up a T fitting to connect them to the charcoal canister.
Tom
alman72
alman72 is offline
PostPosted: Sat Jul 07, 2018 3:10 pm    Post subject: Re: The Stupid Question Thread Reply with quote
it is a 1973. sorry. pancake.
alman72
alman72 is offline
PostPosted: Sat Jul 07, 2018 3:11 pm    Post subject: Re: The Stupid Question Thread Reply with quote
cv66seabear
PostPosted: Sat Jul 07, 2018 3:30 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thank you gentlemen - TCash and Bill - Interesting reading!
Passat Wagon "Wolf"
busdaddy
PostPosted: Sat Jul 07, 2018 5:30 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Maybe add some of those facts to your signature line next time you are poking around the control panel tab at the upper left of this page? Wink
Read this: https://www.thesamba.com/vw/forum/viewtopic.php?t=410602 pay particular attention to Raygreenwood's post.
Слава Україні!
78BusGA
78BusGA is offline
PostPosted: Mon Jul 09, 2018 2:08 am    Post subject: Re: The Stupid Question Thread Reply with quote
What tricks have some of you used to get a stubborn front seat to move in it's track? Mine won't budge on the outboard rail.
Few will understand the passion and majesty, among the nuts and grease.
Tom H.
My '74 Super 1303 thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=764902&start=60
My '78 Kombi Bus thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=769385&highlight=
'72 Superbeetle (retired), '78 Bus Kombi 2.0FI, '74 1303 Superbeetle
Spike0180
Spike0180 is offline
PostPosted: Mon Jul 09, 2018 5:36 am    Post subject: Re: The Stupid Question Thread Reply with quote
Clean it really well. Lube it really well (I use 10W40 oil, because I have it laying around). If it is rusted, PB Blaster is your friend. Use it liberally and let it sit, re-applying a couple times a day for a few days.
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
Mispeld
Mispeld is offline
PostPosted: Mon Jul 09, 2018 11:54 am    Post subject: Re: The Stupid Question Thread Reply with quote
I forced mine very carwfully after lubing like mentioned above. I used a crow bar with a 2x4 against the wall/door pillar and carefully pried at the base of the tracks. I don't think it has moved in 20 yrs.
Tom
78BusGA
78BusGA is offline
PostPosted: Mon Jul 09, 2018 8:04 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks for the suggestions. Yea, these haven't moved in 16 years.
Tom H.
Page 374 of 515
