Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Posted: Thu Jun 28, 2018 1:00 pm Post subject: Re: The Stupid Question Thread |
Globespotter wrote: |
Wildthings wrote: |
So the engine on my 77 Westy is out for a rebuild. Any advice on what to do while it is out?
I have already replaced the fuel filler and vapor lines. Thinking I'll pull the sender and fix it. Any other tasks while I'm in there? |
Reseal your tranny if it has not been done in a while. Also install a shift bushing kit while the tranny is out. |
Tranny is not out. Just engine. |
It takes little time to pull the tranny while the engine is out, while you can not remove the tranny while the engine is in. Good time to clean and repack the CV's as well.
The seals are cheap. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Fri Jun 29, 2018 10:41 pm Post subject: Re: The Stupid Question Thread |
Cleaning the transaxle is MUCH easier with it out, and a clean transaxle runs cooler and therefore lasts longer. +1 vote for "do it!"
www.airschooled.com |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Fri Jul 06, 2018 5:35 pm Post subject: Re: The Stupid Question Thread |
what is the quality go-to for push rod seals? |
cv66seabear Samba Member
Joined: February 18, 2017 Posts: 105 Location: Wisconsin
Posted: Sat Jul 07, 2018 6:39 am Post subject: Re: The Stupid Question Thread |
Quick questions re: clutch cable replacement- So far, I've heard to grease the entire cable and grease just the part that goes through the Bowden tube.
Which is correct? If I grease the length am I just asking for the grease to pick up dirt and gunk?
Replace the Bowden tube everytime or just if it appears damaged?
Thanks!
KentWI _________________ "Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy" |
Tcash Samba Member
Posted: Sat Jul 07, 2018 7:28 am Post subject: Re: The Stupid Question Thread |
cv66seabear wrote: |
Thanks!
KentWI |
The clutch cable experiences tension through out the entire cable. The greatest tension being experienced in the rubbing surfaces i.e. tubes, pulleys. To add to that, the cable rust.
The cable should be Lubricated with a Penetrating protective lube its entire length.
Then apply a top coating lubricant to the high friction areas i.e. tubes and pulleys.
A little reading
https://www.machinerylubrication.com/Read/372/wire-rope-lubrication
The Bowden tube is a wear item. If it shows no signs of wear run it again. But if it shows any wear at all replace it.
GD
Tcash |
wcfvw69 Samba Purist
Posted: Sat Jul 07, 2018 7:36 am Post subject: Re: The Stupid Question Thread |
If the bowden tube looks aged at all, I pitch it in the trash. They are cheap. Make sure you get the best quality bowden tube as well. _________________ Contact me at [email protected]
The Samba member since 2004.
Tcash Samba Member
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jul 07, 2018 10:13 am Post subject: Re: The Stupid Question Thread |
alman72 wrote: |
For what kind of engine? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Mispeld Samba Member
Joined: April 29, 2018 Posts: 355 Location: Jacksonville - Coastal NC
Posted: Sat Jul 07, 2018 11:19 am Post subject: Re: The Stupid Question Thread |
I've been looking for diagrams for the vapor lines. PO just connected the two together above the engine lid. From what I've seen, there is a T fitting, then goes to the Air cleaner? One line is curved so it doesn't look like a T fitting goes there.
Currently, a vacuum line goes from the diaphragm looking part on the air cleaner to the charcoal canister and T's off to the metal part below the charcoal canister.
What's wrong? What am I missing? Yes, hoses will be replaced in the near future. It's on my looooong list of things to do. Thanks. _________________ Tom
1977 Westy. 2.0 Fuel Injected. |
Posted: Sat Jul 07, 2018 12:16 pm Post subject: Re: The Stupid Question Thread |
Now that's some seriously creative vacuum line placement, go ahead, blame your PO
The 2 lines in the roof of the engine compartment Tee together, the RH (darker colored) line needs to swing forward to pick up the side branch of the Tee when one end is on the green line, from there it goes to the small fitting on your charcoal canister (the one currently connected to your decel and EEC valves ). Have a look at this: http://www.ratwell.com/technical/VacuumHoses.html
Definitely change those hoses, it's suprising it even runs with those on there, here's how it should be plumbed:
Слава Україні! |
Posted: Sat Jul 07, 2018 1:40 pm Post subject: Re: The Stupid Question Thread |
Yep, PO. I'm sticking with that.
Thanks again busdaddy, you just answered every question I had. I corrected them all with the exception of the vapor lines. I need to pick up a T fitting to connect them to the charcoal canister. _________________ Tom
Posted: Sat Jul 07, 2018 3:10 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
alman72 wrote: |
For what kind of engine? |
it is a 1973. sorry. pancake. |
Posted: Sat Jul 07, 2018 3:11 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
alman72 wrote: |
Posted: Sat Jul 07, 2018 3:30 pm Post subject: Re: The Stupid Question Thread |
Thank you gentlemen - TCash and Bill - Interesting reading! _________________ "Not all who wander are lost." JRR Tolkien
Passat Wagon "Wolf"
Posted: Sat Jul 07, 2018 5:30 pm Post subject: Re: The Stupid Question Thread |
alman72 wrote: |
busdaddy wrote: |
alman72 wrote: |
Maybe add some of those facts to your signature line next time you are poking around the control panel tab at the upper left of this page?
Read this: https://www.thesamba.com/vw/forum/viewtopic.php?t=410602 pay particular attention to Raygreenwood's post. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
78BusGA Samba Member
Joined: February 01, 2017 Posts: 315 Location: Buford, Georgia
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Mon Jul 09, 2018 5:36 am Post subject: Re: The Stupid Question Thread |
78BusGA wrote: |
What tricks have some of you used to get a stubborn front seat to move in it's track? Mine won't budge on the outboard rail. |
Clean it really well. Lube it really well (I use 10W40 oil, because I have it laying around). If it is rusted, PB Blaster is your friend. Use it liberally and let it sit, re-applying a couple times a day for a few days. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Mon Jul 09, 2018 11:54 am Post subject: Re: The Stupid Question Thread |
I forced mine very carwfully after lubing like mentioned above. I used a crow bar with a 2x4 against the wall/door pillar and carefully pried at the base of the tracks. I don't think it has moved in 20 yrs. _________________ Tom
