Engine extremely HOT
buffalovebus
buffalovebus is offline
PostPosted: Tue Jul 10, 2018 7:07 pm    Post subject: Engine extremely HOT Reply with quote
I recently had a new rebuild engine put into my 73 westy. I took it out for a test drive and then stoped in a park to look, listen, and feel the engine. First the exhaust coming out of the tail pipe is well pipping hot. The bumper is extremely hot. Funny thing is touching the engine was not hot to the touch but later after I was home and it had been sitting for about 20 minutes then it was extremely hot to the touch. The bus is an automatic and runs and drives fine. What are my options? Thank you
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Tue Jul 10, 2018 7:10 pm    Post subject: Re: Engine extremely HOT Reply with quote
Do you have any data, measurements or temps? You can buy a $25 laser temp gauge to accomplish getting some data.
The Samba member since 2004.
buffalovebus
PostPosted: Tue Jul 10, 2018 7:17 pm    Post subject: Re: Engine extremely HOT Reply with quote
The battery in my laser temp guage is dead. I'll get that info tomorrow.
Tcash
Tcash is offline
PostPosted: Tue Jul 10, 2018 7:26 pm    Post subject: Re: Engine extremely HOT Reply with quote
The bumper will get hot without the factory heat shield.
https://www.thesamba.com/vw/forum/viewtopic.php?t=657522&highlight=exh%2A+heat+shield
The engine will get hotter after it sits. It is called heat soak.
Without temperature readings, it is hard to tell if it is actually overheating.
Make sure the timing is not more than 28* btdc at 3500 rpm. If it is too far advanced it can cause overheating.
Water boils at 212*F
buffalovebus
PostPosted: Tue Jul 10, 2018 7:36 pm    Post subject: Re: Engine extremely HOT Reply with quote
I actually do have the factory heat shield. That is interesting about heat soak, I never knew that.
BUSBOSS
BUSBOSS is offline
PostPosted: Tue Jul 10, 2018 7:48 pm    Post subject: Re: Engine extremely HOT Reply with quote
Seems you have had this same issue before (almost exactly two years ago):
mpmitri wrote:
Hello,
So my 1973 type 4 pancake engine Westfalia seems to be running hotter then ever. So hot that it would deliver a super bad burn just to touch the rear bumper for more then a second. My question is what could the possible causes be?
Thank you!
https://www.thesamba.com/vw/forum/viewtopic.php?t=659066&highlight=[/url]
All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible
(sold - but not forgotten)
buffalovebus
PostPosted: Tue Jul 10, 2018 7:52 pm    Post subject: Re: Engine extremely HOT Reply with quote
mpmitri wrote:
Hello,
Thank you!
Ha that's right!
Wildthings
Wildthings is offline
PostPosted: Tue Jul 10, 2018 8:33 pm    Post subject: Re: Engine extremely HOT Reply with quote
Sprinkle some water on the block and see if it dances around, or just sits there and evaporates. You can not touch the exhaust near the heads on an engine after it has run more than a few seconds, within a minute or so you will burn your hand if you touch the tail pipe.
Tcash
Tcash is offline
PostPosted: Tue Jul 10, 2018 9:00 pm    Post subject: Re: Engine extremely HOT Reply with quote
mpmitri wrote:
mpmitri wrote:
Hello,
Thank you!
Ha that's right!
Was this post before or after your rebuild?
The reason I ask is, if it overheated before and you rebuilt it and did not fix the overheating problem. It is going to ruin the engine.
The first place to start is a good tune up.
Tune up
Check the Thermostat and flaps.
Type 4 thermostat and flaps
Good luck
Tcash
sjbartnik
sjbartnik is offline
PostPosted: Wed Jul 11, 2018 7:27 am    Post subject: Re: Engine extremely HOT Reply with quote
Yes exhaust will be hot.
Yes the engine gets hot. It has fire inside.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
Abscate
Abscate is offline
PostPosted: Wed Jul 11, 2018 7:28 am    Post subject: Re: Engine extremely HOT Reply with quote
I think you can help answer this one...from the T3 Forum
How does one know they have a fire in their engine while driving?
.ssS!
sjbartnik
PostPosted: Wed Jul 11, 2018 7:34 am    Post subject: Re: Engine extremely HOT Reply with quote
It's running? Laughing
2000 Kawasaki W650
Globespotter
Globespotter is offline
PostPosted: Wed Jul 11, 2018 8:28 am    Post subject: Re: Engine extremely HOT Reply with quote
It always kills me when people post about how hot an exhaust, dipstick or engine is. No kidding. Why are you touching this? Very Happy
1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
1971 SB Survivor Story: https://globespotter.com/
Road Trip Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=511800&highlight=
My 77 Westy Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=647114&highlight=
http://vw-mplate.com/mcode.php?lang=EN&id=30990
https://vw-type2-id.xyz/mplate/72067382
buffalovebus
PostPosted: Wed Jul 11, 2018 4:20 pm    Post subject: Re: Engine extremely HOT Reply with quote
Tcash wrote:
mpmitri wrote:
mpmitri wrote:
Hello,
Thank you!
Ha that's right!
Tune up
Before and after. Thank you!
Good luck
Tcash
buffalovebus
PostPosted: Wed Jul 11, 2018 4:23 pm    Post subject: Re: Engine extremely HOT Reply with quote
Actually, no not really.
buffalovebus
PostPosted: Wed Jul 11, 2018 4:29 pm    Post subject: Re: Engine extremely HOT Reply with quote
So I got the laser temp gauge working and here is what I have. I admit I am no expert so I am just looking for thoughts.
Baseline temps cold sitting in 72 degree shade was engine 78 degrees, exhaust pipe 80, and bumper 78.
After driving it 30 minutes engine 113 degrees, exhaust pipe 330, and bumper 185.
Again, I know I'm a dummy but any thought would be appreciated. Thank you!
Wildthings
PostPosted: Wed Jul 11, 2018 4:35 pm    Post subject: Re: Engine extremely HOT Reply with quote
Shoot the top center of the engine case and that will give you a good idea of what your oil temperatures are. I am guessing you shot the bottom of the pickup screen cover which is the coldest place on the block and not reflective of actual oil temps. Your exhaust temp is low if anything and the bumper pretty normal depending on your exhaust and shielding.
buffalovebus
PostPosted: Wed Jul 11, 2018 4:50 pm    Post subject: Re: Engine extremely HOT Reply with quote
Thank you! good to know...I actually did shoot the top so thats good I am assuming. Thank you again!
Abscate
Abscate is offline
PostPosted: Wed Jul 11, 2018 5:33 pm    Post subject: Re: Engine extremely HOT Reply with quote
IF it does the Samba , smile.
If you have two Busses, it might do the Tango.
.ssS!
TomWesty
TomWesty is offline
PostPosted: Wed Jul 11, 2018 11:31 pm    Post subject: Re: Engine extremely HOT Reply with quote
I held back from this same comment when I first read the post. Thousands of explosions every minute tend to produce heat.... Cool
