buffalovebus Samba Member
Posted: Tue Jul 10, 2018 7:07 pm Post subject: Engine extremely HOT |
I recently had a new rebuild engine put into my 73 westy. I took it out for a test drive and then stoped in a park to look, listen, and feel the engine. First the exhaust coming out of the tail pipe is well pipping hot. The bumper is extremely hot. Funny thing is touching the engine was not hot to the touch but later after I was home and it had been sitting for about 20 minutes then it was extremely hot to the touch. The bus is an automatic and runs and drives fine. What are my options? Thank you |
wcfvw69 Samba Purist
Posted: Tue Jul 10, 2018 7:10 pm Post subject: Re: Engine extremely HOT |
mpmitri wrote: |
Do you have any data, measurements or temps? You can buy a $25 laser temp gauge to accomplish getting some data. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Tue Jul 10, 2018 7:17 pm Post subject: Re: Engine extremely HOT |
wcfvw69 wrote: |
mpmitri wrote: |
Do you have any data, measurements or temps? You can buy a $25 laser temp gauge to accomplish getting some data. |
The battery in my laser temp guage is dead. I'll get that info tomorrow. |
Tcash Samba Member
Posted: Tue Jul 10, 2018 7:26 pm Post subject: Re: Engine extremely HOT |
mpmitri wrote: |
The bumper will get hot without the factory heat shield.
https://www.thesamba.com/vw/forum/viewtopic.php?t=657522&highlight=exh%2A+heat+shield
The engine will get hotter after it sits. It is called heat soak.
Without temperature readings, it is hard to tell if it is actually overheating.
Make sure the timing is not more than 28* btdc at 3500 rpm. If it is too far advanced it can cause overheating.
Water boils at 212*F |
Posted: Tue Jul 10, 2018 7:36 pm Post subject: Re: Engine extremely HOT |
Tcash wrote: |
mpmitri wrote: |
I actually do have the factory heat shield. That is interesting about heat soak, I never knew that. |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Tue Jul 10, 2018 7:48 pm Post subject: Re: Engine extremely HOT |
Seems you have had this same issue before (almost exactly two years ago):
mpmitri wrote: |
Hello,
So my 1973 type 4 pancake engine Westfalia seems to be running hotter then ever. So hot that it would deliver a super bad burn just to touch the rear bumper for more then a second. My question is what could the possible causes be?
Thank you! |
https://www.thesamba.com/vw/forum/viewtopic.php?t=659066&highlight=[/url] _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Posted: Tue Jul 10, 2018 7:52 pm Post subject: Re: Engine extremely HOT |
BUSBOSS wrote: |
mpmitri wrote: |
Hello,
Thank you! |
https://www.thesamba.com/vw/forum/viewtopic.php?t=659066&highlight=[/url] |
Ha that's right! |
Posted: Tue Jul 10, 2018 8:33 pm Post subject: Re: Engine extremely HOT |
Sprinkle some water on the block and see if it dances around, or just sits there and evaporates. You can not touch the exhaust near the heads on an engine after it has run more than a few seconds, within a minute or so you will burn your hand if you touch the tail pipe. |
Tcash Samba Member
Posted: Tue Jul 10, 2018 9:00 pm Post subject: Re: Engine extremely HOT |
mpmitri wrote: |
BUSBOSS wrote: |
mpmitri wrote: |
Hello,
Thank you! |
Ha that's right! |
Was this post before or after your rebuild?
The reason I ask is, if it overheated before and you rebuilt it and did not fix the overheating problem. It is going to ruin the engine.
The first place to start is a good tune up.
Tune up
Check the Thermostat and flaps.
Type 4 thermostat and flaps
Good luck
Tcash |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Wed Jul 11, 2018 7:27 am Post subject: Re: Engine extremely HOT |
Yes exhaust will be hot.
Yes the engine gets hot. It has fire inside. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Wed Jul 11, 2018 7:28 am Post subject: Re: Engine extremely HOT |
sjbartnik wrote: |
Yes the engine gets hot. It has fire inside. |
I think you can help answer this one...from the T3 Forum
Quote: |
How does one know they have a fire in their engine while driving? |
_________________ .ssS! |
Posted: Wed Jul 11, 2018 7:34 am Post subject: Re: Engine extremely HOT |
Abscate wrote: |
It's running? _________________ 1965 Volkswagen 1500 Variant S
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Posted: Wed Jul 11, 2018 4:20 pm Post subject: Re: Engine extremely HOT |
Tcash wrote: |
mpmitri wrote: |
BUSBOSS wrote: |
mpmitri wrote: |
Hello,
Thank you! |
Ha that's right! |
Tune up
Before and after. Thank you!
Good luck
Tcash |
Posted: Wed Jul 11, 2018 4:23 pm Post subject: Re: Engine extremely HOT |
Globespotter wrote: |
It always kills me when people post about how hot an exhaust, dipstick or engine is. No kidding. Why are you touching this? |
Actually, no not really. |
Posted: Wed Jul 11, 2018 4:29 pm Post subject: Re: Engine extremely HOT |
wcfvw69 wrote: |
mpmitri wrote: |
So I got the laser temp gauge working and here is what I have. I admit I am no expert so I am just looking for thoughts.
Baseline temps cold sitting in 72 degree shade was engine 78 degrees, exhaust pipe 80, and bumper 78.
After driving it 30 minutes engine 113 degrees, exhaust pipe 330, and bumper 185.
Again, I know I'm a dummy but any thought would be appreciated. Thank you! |
Posted: Wed Jul 11, 2018 4:35 pm Post subject: Re: Engine extremely HOT |
mpmitri wrote: |
wcfvw69 wrote: |
mpmitri wrote: |
Shoot the top center of the engine case and that will give you a good idea of what your oil temperatures are. I am guessing you shot the bottom of the pickup screen cover which is the coldest place on the block and not reflective of actual oil temps. Your exhaust temp is low if anything and the bumper pretty normal depending on your exhaust and shielding. |
Posted: Wed Jul 11, 2018 4:50 pm Post subject: Re: Engine extremely HOT |
Wildthings wrote: |
mpmitri wrote: |
wcfvw69 wrote: |
mpmitri wrote: |
Thank you! good to know...I actually did shoot the top so thats good I am assuming. Thank you again! |
Posted: Wed Jul 11, 2018 5:33 pm Post subject: Re: Engine extremely HOT |
Wildthings wrote: |
IF it does the Samba , smile.
If you have two Busses, it might do the Tango. _________________ .ssS! |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Wed Jul 11, 2018 11:31 pm Post subject: Re: Engine extremely HOT |
sjbartnik wrote: |
I held back from this same comment when I first read the post. Thousands of explosions every minute tend to produce heat.... _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
