1960 SO23 Westy - New project
Page: Previous  1, 2, 3, 4, 5, 6 ... 12, 13, 14  Next
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Tue Jul 10, 2018 6:59 pm    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
The plastic cover on the generator? Is it NOS too? Laughing I didn't think VW used them until the 70's? Wink I've also understood that many people believe they shouldn't be used as the covers restrict cooling air from getting inside the generator.
On a serious note, the engine looks fantastic. Running the restored carb, fuel pump and distributor make it look so correct. I'm sure it will run amazing as well.
Bill
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
npbusguy
npbusguy is offline
PostPosted: Tue Jul 10, 2018 7:03 pm    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
Looking good Jon! I'm loving the patina touches. Hope the rest of the bus buffs out. I guess I'll know in a couple weeks when I get to see it in person for the first time.
easy e
easy e is offline
PostPosted: Tue Jul 10, 2018 9:39 pm    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
So fun to watch Jon!
Grommet for the preheat hose. WW was out, aw shucks, gotta use NOS...
WW has their picture + description right... but, Iíll let them know they have a couple flip-flopped part numbers to fix.
aka: Evan
zuggbug
zuggbug is offline
PostPosted: Wed Jul 11, 2018 4:20 am    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
very nice work Jon.
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
crofty
Judas of the North
crofty is offline
PostPosted: Wed Jul 11, 2018 7:47 am    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
Wouldn't a '60 40hp run the ignition wire holders that the wires pass through?
When in doubt, logo it out!!
HamburgerBrad wrote:
doveblue3
doveblue3 is offline
PostPosted: Wed Jul 11, 2018 9:29 am    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
And also this oil filler baffle? I genuinely thought that my '61 40 hp would use this baffle, so if I am wrong about that, it would be good to know.
nlorntson Premium Member
Crazy VW Lady
nlorntson is offline
PostPosted: Wed Jul 11, 2018 9:43 am    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
I think the wire tube ended with the 36hp
Those are aftermarket add-on's
hazetguy
hazetguy is offline
PostPosted: Wed Jul 11, 2018 10:18 am    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
The oil tube type 40hp baffle is a real VW item and comes in short and tall versions. There are a few good threads about them.
The case that this engine was built on is a D case, big bore 83's, "hot rod" cam. The case has a lot of later features, like 8mm oil pump studs, large oil passages, dual relief, "D" cut out for the generator pedestal (hence the baffle I used), cam bearings, and yet still has the 40hp cylinder size bore.
Test ran the engine today (Neil... Shame on you ), and aside from the oil pump cover leaking (which really pi$$es me off), everything sounded good, had good oil pressure, no other leaks, so aside from the oil pump leak issue, waiting on the WW parts order to arrive, and some final assembly, and some "disassembly" so it fits in Neils car for transport, it's good to go.
Your crystal ball ain't so crystal clear
Parts and mechanical restoration services available. I restore and rebuild fuel pumps, distributors, spindles, etc.
Check my ads or send a PM.
Braukuche
Braukuche is offline
PostPosted: Wed Jul 11, 2018 10:21 am    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
Yep, I think 60 36hp type 1 didn't use the tube either, but they went to those big rubber plugs, three of them. I see Jon is using the smaller hard plastic holders, I guess that's an early 40hp thing but I'm pretty sure bastard 40 used the big rubber plug wire holders.
Go Reds! Smash state!
My retirement plan:
1956 Ghia
1969 Ghia Convertible
1959 SO-23 Westfalia
1960 double cab
1960 convertible bug
1963 356 B coupe
1962 356 B Coupe
1967 21 window rust bucket
1967 912
hazetguy
hazetguy is offline
PostPosted: Wed Jul 11, 2018 10:33 am    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
I had some original white plastic wire holders, but they would not stay secured in the fan shroud holes. So I used some black clips I had.
I think the ones that Sean is talking about are the ones seen here (pic from gallery, Mats W):
I don't know where to get those, and if it's something that Neil just has to have, that can be on his shopping list for the future. I have been told repeatedly that this is not a show motor, it's a go motor.
khalimadeath
khalimadeath is offline
PostPosted: Wed Jul 11, 2018 10:39 am    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
That motor is beautiful! Nice work!
The United States Constitution
(c) 1787. All Rights Reserved
1970 Bus Westfalia
1964 Kombi
62DoKaGuy Premium Member
62DoKaGuy is online now
PostPosted: Wed Jul 11, 2018 10:49 am    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
hazetguy wrote:
...this is not a show motor, it's a go motor.
Words to live by. And the level of quality is kind of showy, so maybe you're killing two birds with one stone, or killing one and wounding the other...whatever, looking great, Jon!
Wenige Menschen denken, und doch wollen alle entscheiden.
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there...
4/62 Double Cab
4/59 Single Cab
BarryL Premium Member
BarryL is offline
PostPosted: Wed Jul 11, 2018 11:23 am    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
You engine looks like a candy coated lollypop waiting to be licked. Does the stale air heat have more air pressure than the fresh air heat? Is it hotter since you get to use cylinder heat plus that front exhaust surround?
crofty
Judas of the North
crofty is offline
PostPosted: Wed Jul 11, 2018 11:25 am    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
Yes, those are the ones. I had originally wanted to run those on my hot rod 40 for my 62 but just went 1600.
This should be them
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113905451
crofty
Judas of the North
crofty is offline
PostPosted: Wed Jul 11, 2018 11:27 am    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
"Kind of"? LOL
Jon doesn't f around. If he was closer id have him do my spindles or anything else I cant do on my own. His work is always top notch.
PostPosted: Wed Jul 11, 2018 11:35 am    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
crofty wrote:
"Kind of"? LOL
Trust me, that was sarcasm haha. Over the years, I've never seen or heard anything but the best about Jon's workmanship.
4/62 Double Cab
4/59 Single Cab
hazetguy
hazetguy is offline
PostPosted: Wed Jul 11, 2018 12:02 pm    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
This should be them
grrrrrr. I searched for all kinds of terms, but not for 'ignition cable". FFS, who calls them that? Thanks for the link Sean.
Thanks for all the kind words. I couldn't do what I do without the help of other highly skilled people, and good people who sell hard to find parts, and I am totally grateful for their services when I am doing a project.
This was truly a 'go' motor project, and not a full-on 'restoration' like I am used to doing. Of course, I am not totally satisfied with the cosmetic results, but I guess it'll work for a non-"show" vehicle. Smile
I'll post some assembled, "ready for Neil to pick up" pics another time.
scvw
scvw is offline
PostPosted: Wed Jul 11, 2018 12:10 pm    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
crofty wrote:
"Kind of"? LOL
I will vouch for that!
58 Coral Red ragtop(Diana's car)
57 PG/SG standard
63 Ruby Red SC
WTB - Sigla popout glass like in my ad.
http://www.thesamba.com/vw/classifieds/detail.php?id=1667775
npbusguy
npbusguy is offline
PostPosted: Wed Jul 11, 2018 12:11 pm    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
Hell yeah, this engine should climb any mountain, or at least push a SO23 around most roads without a struggle.
I'll pick the engine up next week, and then the following week, I'll get to see the bus in person for the first time.
This build is going to take a major detour soon, stay tuned to see where in the world it is going.
npbusguy
npbusguy is offline
PostPosted: Wed Jul 11, 2018 1:03 pm    Post subject: Re: 1960 SO23 Westy - New project Reply with quote
40hp folks, I'm looking for this vacuum line, in case anyone has one kicking around.
Page 5 of 14
