wcfvw69 Samba Purist
Posted: Tue Jul 10, 2018 6:59 pm Post subject: Re: 1960 SO23 Westy - New project |
The plastic cover on the generator? Is it NOS too? I didn't think VW used them until the 70's? I've also understood that many people believe they shouldn't be used as the covers restrict cooling air from getting inside the generator.
On a serious note, the engine looks fantastic. Running the restored carb, fuel pump and distributor make it look so correct. I'm sure it will run amazing as well. _________________ Contact me at [email protected]
The Samba member since 2004.
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1658 Location: Budapest, Hungary
Posted: Tue Jul 10, 2018 7:03 pm Post subject: Re: 1960 SO23 Westy - New project |
Looking good Jon! I'm loving the patina touches. Hope the rest of the bus buffs out. I guess I'll know in a couple weeks when I get to see it in person for the first time. |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Tue Jul 10, 2018 9:39 pm Post subject: Re: 1960 SO23 Westy - New project |
So fun to watch Jon!
Grommet for the preheat hose. WW was out, aw shucks, gotta use NOS...
WW has their picture + description right... but, I’ll let them know they have a couple flip-flopped part numbers to fix.
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Wed Jul 11, 2018 4:20 am Post subject: Re: 1960 SO23 Westy - New project |
very nice work Jon. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Wed Jul 11, 2018 7:47 am Post subject: Re: 1960 SO23 Westy - New project |
Wouldn't a '60 40hp run the ignition wire holders that the wires pass through? _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
doveblue3 Samba Member
Posted: Wed Jul 11, 2018 9:29 am Post subject: Re: 1960 SO23 Westy - New project |
crofty wrote: |
Wouldn't a '60 40hp run the ignition wire holders that the wires pass through? |
And also this oil filler baffle? I genuinely thought that my '61 40 hp would use this baffle, so if I am wrong about that, it would be good to know.
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Jul 11, 2018 9:43 am Post subject: Re: 1960 SO23 Westy - New project |
crofty wrote: |
I think the wire tube ended with the 36hp
doveblue3 wrote: |
Those are aftermarket add-on's |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed Jul 11, 2018 10:18 am Post subject: Re: 1960 SO23 Westy - New project |
The oil tube type 40hp baffle is a real VW item and comes in short and tall versions. There are a few good threads about them.
The case that this engine was built on is a D case, big bore 83's, "hot rod" cam. The case has a lot of later features, like 8mm oil pump studs, large oil passages, dual relief, "D" cut out for the generator pedestal (hence the baffle I used), cam bearings, and yet still has the 40hp cylinder size bore.
Test ran the engine today (Neil... ), and aside from the oil pump cover leaking (which really pi$$es me off), everything sounded good, had good oil pressure, no other leaks, so aside from the oil pump leak issue, waiting on the WW parts order to arrive, and some final assembly, and some "disassembly" so it fits in Neils car for transport, it's good to go. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Braukuche Samba Member
Posted: Wed Jul 11, 2018 10:21 am Post subject: Re: 1960 SO23 Westy - New project |
nlorntson wrote: |
crofty wrote: |
doveblue3 wrote: |
Yep, I think 60 36hp type 1 didn't use the tube either, but they went to those big rubber plugs, three of them. I see Jon is using the smaller hard plastic holders, I guess that's an early 40hp thing but I'm pretty sure bastard 40 used the big rubber plug wire holders. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Wed Jul 11, 2018 10:33 am Post subject: Re: 1960 SO23 Westy - New project |
I had some original white plastic wire holders, but they would not stay secured in the fan shroud holes. So I used some black clips I had.
I think the ones that Sean is talking about are the ones seen here (pic from gallery, Mats W):
I don't know where to get those, and if it's something that Neil just has to have, that can be on his shopping list for the future. I have been told repeatedly that this is not a show motor, it's a go motor. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
khalimadeath Samba Member
Posted: Wed Jul 11, 2018 10:39 am Post subject: Re: 1960 SO23 Westy - New project |
That motor is beautiful! Nice work! _________________ The United States Constitution
(c) 1787. All Rights Reserved
1970 Bus Westfalia
1964 Kombi |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Wed Jul 11, 2018 10:49 am Post subject: Re: 1960 SO23 Westy - New project |
hazetguy wrote: |
...this is not a show motor, it's a go motor. |
Words to live by. And the level of quality is kind of showy, so maybe you're killing two birds with one stone, or killing one and wounding the other...whatever, looking great, Jon! _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Wed Jul 11, 2018 11:23 am Post subject: Re: 1960 SO23 Westy - New project |
You engine looks like a candy coated lollypop waiting to be licked. Does the stale air heat have more air pressure than the fresh air heat? Is it hotter since you get to use cylinder heat plus that front exhaust surround? |
Posted: Wed Jul 11, 2018 11:25 am Post subject: Re: 1960 SO23 Westy - New project |
Yes, those are the ones. I had originally wanted to run those on my hot rod 40 for my 62 but just went 1600.
This should be them
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113905451
hazetguy wrote: |
I don't know where to get those, and if it's something that Neil just has to have, that can be on his shopping list for the future. I have been told repeatedly that this is not a show motor, it's a go motor. |
Posted: Wed Jul 11, 2018 11:27 am Post subject: Re: 1960 SO23 Westy - New project |
62DoKaGuy wrote: |
hazetguy wrote: |
Words to live by. And the level of quality is kind of showy, so maybe you're killing two birds with one stone, or killing one and wounding the other...whatever, looking great, Jon! |
"Kind of"? LOL
Jon doesn't f around. If he was closer id have him do my spindles or anything else I cant do on my own. His work is always top notch. _________________ Your Vanagon sucks, Stop waving at me.
Posted: Wed Jul 11, 2018 11:35 am Post subject: Re: 1960 SO23 Westy - New project |
crofty wrote: |
62DoKaGuy wrote: |
hazetguy wrote: |
"Kind of"? LOL
Jon doesn't f around. If he was closer id have him do my spindles or anything else I cant do on my own. His work is always top notch. |
Trust me, that was sarcasm haha. Over the years, I've never seen or heard anything but the best about Jon's workmanship. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
4/62 Double Cab
5/61 Panel (sold)
Posted: Wed Jul 11, 2018 12:02 pm Post subject: Re: 1960 SO23 Westy - New project |
grrrrrr. I searched for all kinds of terms, but not for 'ignition cable". FFS, who calls them that? Thanks for the link Sean.
Thanks for all the kind words. I couldn't do what I do without the help of other highly skilled people, and good people who sell hard to find parts, and I am totally grateful for their services when I am doing a project.
This was truly a 'go' motor project, and not a full-on 'restoration' like I am used to doing. Of course, I am not totally satisfied with the cosmetic results, but I guess it'll work for a non-"show" vehicle.
I'll post some assembled, "ready for Neil to pick up" pics another time. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
scvw Samba Member
Joined: September 02, 2006 Posts: 3544 Location: South Carolina
Posted: Wed Jul 11, 2018 12:10 pm Post subject: Re: 1960 SO23 Westy - New project |
crofty wrote: |
"Kind of"? LOL
I will vouch for that! _________________ 58 Coral Red ragtop(Diana's car)
57 PG/SG standard
63 Ruby Red SC
WTB - Sigla popout glass like in my ad.
http://www.thesamba.com/vw/classifieds/detail.php?id=1667775 |
Posted: Wed Jul 11, 2018 12:11 pm Post subject: Re: 1960 SO23 Westy - New project |
hazetguy wrote: |
Hell yeah, this engine should climb any mountain, or at least push a SO23 around most roads without a struggle.
I'll pick the engine up next week, and then the following week, I'll get to see the bus in person for the first time.
This build is going to take a major detour soon, stay tuned to see where in the world it is going. |
Posted: Wed Jul 11, 2018 1:03 pm Post subject: Re: 1960 SO23 Westy - New project |
40hp folks, I'm looking for this vacuum line, in case anyone has one kicking around.
