Where is your fuel filter ?
1) I don't need one.
2%
 2%  [ 2 ]
2) Under the gas tank.
28%
 28%  [ 24 ]
3) Next to the transmission.
42%
 42%  [ 36 ]
4) In the engine bay between the fuel pump and carburetor.
18%
 18%  [ 16 ]
5) In the engine bay before the fuel pump.
8%
 8%  [ 7 ]
Total Votes : 85
Dark Earth
Dark Earth is offline
PostPosted: Wed Jul 11, 2018 7:16 pm    Post subject: Where is your fuel filter ? Reply with quote
My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ Anxious
sb001
sb001 is offline
PostPosted: Wed Jul 11, 2018 7:24 pm    Post subject: Re: Where is your fuel filter ? Reply with quote
Uh oh.
Thread locked shortly.
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
Pulseflux
Pulseflux is offline
PostPosted: Wed Jul 11, 2018 7:58 pm    Post subject: Re: Where is your fuel filter ? Reply with quote
3) next to transmission
Dark Earth
PostPosted: Wed Jul 11, 2018 8:06 pm    Post subject: Re: Where is your fuel filter ? Reply with quote
Click the circle next to #3 and click "Submit Vote" to have it counted in the poll results.
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Wed Jul 11, 2018 9:37 pm    Post subject: Re: Where is your fuel filter ? Reply with quote
Can’t do multiples in this poll = fail.
I used to have three: screens in the tank and fuel pump, filter next to the transmission. Had to replace the fuel pump so now I’m down to just two.
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
PostPosted: Wed Jul 11, 2018 10:02 pm    Post subject: Re: Where is your fuel filter ? Reply with quote
Moderator says:
Since it seems like this person wanted to do a poll, let's stick with voting and voting comments and not get into another war over where a filter should be or if you need one since that is well covered in multiple threads.
Thank you.
Tim Donahoe
Tim Donahoe is offline
PostPosted: Wed Jul 11, 2018 10:11 pm    Post subject: Re: Where is your fuel filter ? Reply with quote
I have two. One under the fuel tank, and one by the transmission.
Tim
Let's do the Time Warp again!
Richard O'Brien
vamram Premium Member
vamram is offline
PostPosted: Thu Jul 12, 2018 3:49 am    Post subject: Re: Where is your fuel filter ? Reply with quote
2, same as Tim.
Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!!
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Thu Jul 12, 2018 4:25 am    Post subject: Re: Where is your fuel filter ? Reply with quote
I have a cheap plastic filter down low by transmission. My reasoning is twofold, if it did leak I’d be likely to see a spot under the car and it’s less likely to cause a fire. Then there’s the visual, in my opinion it look like shit crammed up next to the coil or perched above the distributor. The added weight may cause a vibration which helps to work the brass fittings loose. Really though whenever you are looking at an engine and you see jury rigged filters hanging, clamps installed upside down or backwards, plug wires run over the top of the generator etc. it makes you wonder about the rest of the car.
Someone here sells a nice filter holder which bolts to transmission to provide neat appearance and proper support, great idea . Very Happy sorry I exceeded twofold
Frodge
Frodge is offline
PostPosted: Thu Jul 12, 2018 4:32 am    Post subject: Re: Where is your fuel filter ? Reply with quote
Next to the transmission. First thing I did to my car.
Dark Earth
PostPosted: Thu Jul 12, 2018 7:05 am    Post subject: Re: Where is your fuel filter ? Reply with quote
Oops Embarassed … I didn't quite think this through.
Towel Rail
PostPosted: Thu Jul 12, 2018 8:44 am    Post subject: Re: Where is your fuel filter ? Reply with quote
No worries, I figured you only had add-on filters in mind. But it's easy for people to forget that VW provided screening of the fuel to keep contaminants out of the carb. They were just hidden really well.
I'll be a good sport and vote for "by the transmission." Wink
Xevin Premium Member
Xevin is offline
PostPosted: Thu Jul 12, 2018 8:57 am    Post subject: Re: Where is your fuel filter ? Reply with quote
That right there. So well articulated Applause I’m totally stealing that thought when this conversation comes up with the bros Wink Very Happy
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
Eskamobob1
Eskamobob1 is offline
PostPosted: Thu Jul 12, 2018 9:51 am    Post subject: Re: Where is your fuel filter ? Reply with quote
Any chance you have a link to that? I seriously need to move mine tbh, and that sounds far more interesting than me trying to rig up a bracket out of sheet metal that was going to look like ass
'74 - front disks/lots more work to do
AlmostHeavenWV_VW Premium Member
AlmostHeavenWV_VW is offline
PostPosted: Thu Jul 12, 2018 10:10 am    Post subject: Re: Where is your fuel filter ? Reply with quote
Here you go:
https://www.thesamba.com/vw/classifieds/detail.php?id=1901747
1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor
Frodge
Frodge is offline
PostPosted: Thu Jul 12, 2018 10:22 am    Post subject: Re: Where is your fuel filter ? Reply with quote
That’s pretty nice.
Frodge
Frodge is offline
PostPosted: Thu Jul 12, 2018 10:30 am    Post subject: Re: Where is your fuel filter ? Reply with quote
Btw....#4 is begging for a fire.#5 almost as bad.
ps2375
ps2375 is offline
PostPosted: Thu Jul 12, 2018 10:59 am    Post subject: Re: Where is your fuel filter ? Reply with quote
2) under the tank before the electric pump.
Q-Dog
Q-Dog is offline
PostPosted: Thu Jul 12, 2018 12:44 pm    Post subject: Re: Where is your fuel filter ? Reply with quote
My filter is in the fuel pump. Wink plus the screen in the tank.
(but on my buggy I run one next to the trans because there is no screen in the tank)
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
hitest
hitest is offline
PostPosted: Thu Jul 12, 2018 1:15 pm    Post subject: Re: Where is your fuel filter ? Reply with quote
same here- two factory filters seams enough. If I'm working with a serviced tank I'll put a temporary one in line under the tank and remove it as soon as gas is clean- or before SB001 has a total meltdown hissyfit over it's location. Wink
FU#5
