Bosch VJU4BR8 Distributor Contact Plate Lubricant
garagebandking41
garagebandking41 is offline
PostPosted: Thu Jul 12, 2018 5:44 am    Post subject: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
I'm not sure if I got the name right but what kind of lubricant should I use between the two metal plates that adjust the timing on the BR8 Distributor? I think I recall the manual mentioned some drops of motor oil, but they are metal on metal and that doesn't seem to be substantial enough.
The part in question is pointed out by the red arrow.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jul 12, 2018 6:41 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
I use Bosch distributor grease
Glenn
iRide4Sue.org Please Donate to fight Cancer. $31,000 raised in 2018, hoping for the same in 2019
garagebandking41
PostPosted: Thu Jul 12, 2018 7:19 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
Thanks Glenn,
I hand polished for hours those mating surfaces because mine were worn down. It is a very close fit and there were some depressions in the "top" plate that were deep enough to cause jerky motion. Moving my way from 400 grit to 800 I was able to restore non-interference and smooth operation, but I never want to do that again!
Mr. 010
Glenn is offline
PostPosted: Thu Jul 12, 2018 7:55 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
garagebandking41 wrote:
Thanks Glenn,
Those divots are a problem.
If you contacted me, i have a few of those assemblies in good condition and would of sold one for a reasonable price.
Whenever I buy a core that is not rebuildable, I do salvage every good parts and do offer them for sale if I have more than i need.
Divot
Glenn
garagebandking41
PostPosted: Thu Jul 12, 2018 8:49 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
Glenn,
Your pictures did not show up. The link may be dead. I'm interested to see how bad they can get. Like I said, mine was salvageable. I didn't mic them but I couldn't have taken off more than a thou to cure the problem. Like butter now Laughing
Edit: Now the pictures showed up. Mine look just like that now! Thank you again.
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Thu Jul 12, 2018 9:58 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
Glenn wrote:
Divot
Glenn, when you say "divots", what area are you referring to?
Mr. 010
Glenn is offline
PostPosted: Thu Jul 12, 2018 10:01 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
The indent on the raised surface that the ball rides on. It should be smooth so the ball can move when the upper plate moves.
Glenn
garagebandking41
PostPosted: Thu Jul 12, 2018 10:13 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
Ahh, I didn't realize that is what you were referring to. Mine does not have that issue. I had to polish grooves worn in by the three raised sections on the bottom plate. You can't really tell in my tear down pic. but you can see the three raised sections right in the middle of the frame there.
Mr. 010
Glenn is offline
PostPosted: Thu Jul 12, 2018 10:26 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
I've never seen one where the bottom of the upper breaker plate needed to be resurfaced. And i've rebuilt over 200 of them.
Glenn
garagebandking41
PostPosted: Thu Jul 12, 2018 10:31 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
I'll take a photo when I get back to my shop. You can still make out the grooves I'm talking about. I polished just enough to restore smooth movement, though I think it may have been a bit unnecessary to the degree I took it.
garagebandking41
PostPosted: Thu Jul 12, 2018 7:54 pm    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
You can see my sanding. But still make out the original indentations of the bottom breaker plate. It passes the fingernail test and is now smooth.
tasb Premium Member
The Distributor Distributor
tasb is offline
PostPosted: Fri Jul 13, 2018 8:12 pm    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
What then, should the rest of us use? if you've done a google search for the stuff you find out that there is little out there. One Samba user found a tube and has put it up for sale:
https://www.thesamba.com/vw/classifieds/detail.php?id=2178463 Sad
When last I saw a tube on ebay it sold for $25 and wasn't even a full tube.
Here is a helpful thread for the rest of us:
https://www.thesamba.com/vw/forum/viewtopic.php?t=652724&highlight=distributor+grease
for the glide surface of the points plates even a thin coat of some bearing grease will do in a pinch, or you can pay $225...
Roads Scholar & distributor restorations
1956 oval third owner 36 hp- slow drag Champion 2012, 2014, 2015, 2017
1957 Kombi low mileage 36 hp governor equiped M 178 Slow Drag Winner 2014, 2015, 2018
1960 sunroof beetle owned since 1991 36 hp
1965 hrdtop Deluxe Microbus owned since 1990 M 620 factory 12 v 1500cc
Mr. 010
Glenn is offline
PostPosted: Fri Jul 13, 2018 8:17 pm    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
Or Standard Libricam For $11.
https://www.amazon.com/Standard-Motor-Products-SL2-Lubricam/dp/B000JKDAR6
Wheel bearing grease is ment to be kept in place by seals. Distributor grease is very sticky and stays in place.
Oil will work, but for how long? Use an inferior product and the plate will eventually drag as friction increased and finally bind. Then you'll be doing it again.
Glenn
tasb Premium Member
tasb is offline
PostPosted: Sat Jul 14, 2018 12:53 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
Applause Good alternative,
A thin layer of bearing grease sandwiched between two non moving, flat parts is not going to go anywhere. It will dry out faster- years, than distributor lube That's why I stated "in a pinch" and provided a thread with alternatives.
There are still plenty of VJU distributors out there, no need for anyone else to go through what the OP did. We have lot's of spares.
garagebandking41
PostPosted: Sat Jul 14, 2018 6:54 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
Shocked Well pardon me for keeping an original piece in working order! I was wondering why some 36hp parts are hard to come by.
In all seriousness thank you all for the help and discussion!
tasb Premium Member
tasb is offline
PostPosted: Sat Jul 14, 2018 7:31 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
No worries, I applaud your efforts too. Applause
60ragtop Premium Member
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Sat Jul 14, 2018 8:03 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
Why does 5 of my Bentley manuals say it is OK to use wheel bearing grease inside the distributor cap on the cam, pivot points and advance plate ball if it is deemed so bad to use Question
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
Sharp64 wrote:
But thatís crazy talk. He must be made to comply!!!
" Even when all the experts agree they may well be mistaken." Bertrand Russell
[email protected] wrote:
aftermarket shit that always needs a tweek eats time
Eaallred wrote:
People are over analyzing.......(insert your problem here)
Mr. 010
Glenn is offline
PostPosted: Sat Jul 14, 2018 8:07 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
Because Bentley is not Bosch and they are assuming you don't have a specific grease like Bosch distributor grease.
I used to use it to grease the input shaft of a transaxle.
Glenn
60ragtop is offline
PostPosted: Sat Jul 14, 2018 9:11 am    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
Laughing
Just the answer I figured would come.
But it's OK to say read the Bentley and follow it the till doesn't agree with your perceived notions.
I have been using wheel bearing grease on hundreds and hundreds of VW distributors over 50 years with no problems so I guess Bentley can't be to far off by recommending it.
Rick
Mr. 010
Glenn is offline
PostPosted: Sat Jul 14, 2018 12:21 pm    Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant Reply with quote
60ragtop wrote:
Laughing
I've rebuilt over 3000 distributors and everyone that used wheel bearing grease had it slung all over the inside and think gunk on the bottom.
The problem is not that it doesn't lubricate, jut just doesn't stick as well as the correct product. But since the correct product is NLA, use whatever works for you.
I bet if you read the Muir book, it says you can just Vaseline Wink
Glenn
