Pertronix No spark
Rawq
Rawq is offline
PostPosted: Tue Jul 10, 2018 7:05 pm    Post subject: Pertronix No spark Reply with quote
16 yrs into my restoration and I finally got time to finish the motor and install it.. Wouldn't you know it, everything went smooth until I cranked it over.. "No Spark" Everything is new (pics attached) I've ran all the normal tests (Ohm readings, test lamps on the coil, both pos. to neg, pos to ground)
All I can think of is that the ignition module is no good. This is my first time using an electronic ignition so excuse my lack of knowledge..
Is there another way to test the module?
Volswagon
Volswagon is offline
PostPosted: Tue Jul 10, 2018 8:05 pm    Post subject: Re: Pertronix No spark Reply with quote
Make sure that's a 3-ohm coil. There should be a .010" gap at the rotor pickup. I assume that red wire goes to the coil.
An overall pic might be helpful.
I know the pieces fit, cos I watched them fall away.
'71 Ghia coupe https://www.thesamba.com/vw/classifieds/detail.php?id=2152608
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight=
'98 Chevy S-10
Lingwendil
Location: Oakley, behind enemy lines in communist California
Lingwendil is offline
PostPosted: Tue Jul 10, 2018 8:07 pm    Post subject: Re: Pertronix No spark Reply with quote
I keep an original German 009 on hand with points already gapped, and timing set with its own clamp for such troubleshooting, since it can be easily swapped in in a minute or two. If you have voltage to the coil, and the coil measures well, I would bet the module has given up the ghost (whadd'a surprise! Laughing )and needs to be replaced or upgraded to points. Easiest test is a quick swap.
73 super beetle thread!
http://www.thesamba.com/vw/forum/viewtopic.php?t=649622
How to- Modify your Kadrons for SVDA!
http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
modok
modok is offline
PostPosted: Tue Jul 10, 2018 8:29 pm    Post subject: Re: Pertronix No spark Reply with quote
Spin the distributor, should make sparks if coil is hooked up. If you hook up a test light in place of coil, it should go on and off. it's just like a switch, or relay. Connects and disconnects the black wire from ground.
just testing the coil I don't like to crank the engine.
Just unbolt the distributor clamp and pull it up a little and spin it. Leave it IN the hole tho, so it's grounded.
Dale M.
Dale M. is offline
PostPosted: Tue Jul 10, 2018 9:26 pm    Post subject: Re: Pertronix No spark Reply with quote
You should be able to put test lamp on negative terminal of coil, have someone spin the motor over and you watch test lamp, test lamp should flash on-off-on-off-on-off.... If coil has power and is good and module is good... IF you have power to coil and lamp does not flash (stays dark) you may have open coil or module bad... If lamp stay on (all the time) you have good coil and "open" in wiring or module (bad module) ...
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
rugblaster
rugblaster is offline
PostPosted: Tue Jul 10, 2018 10:33 pm    Post subject: Re: Pertronix No spark Reply with quote
Looks like you could throw a yellow dog through that air gap.
'69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.23 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '10 MB E350, '65 Plymouth Valiant convertible and a '14 Ford F150 King Ranch
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
cbeck
cbeck is offline
PostPosted: Wed Jul 11, 2018 4:03 am    Post subject: Re: Pertronix No spark Reply with quote
http://support.pertronix.com/kb/faq.php?cid=1
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Jul 11, 2018 5:01 am    Post subject: Re: Pertronix No spark Reply with quote
And you cheap out on a Chinese distributor?
Glenn
iRide4Sue.org Please Donate to fight Cancer. $31,000 raised in 2018, hoping for the same in 2019
GARRICK.CLARK
GARRICK.CLARK is offline
PostPosted: Thu Jul 12, 2018 10:26 am    Post subject: Re: Pertronix No spark Reply with quote
As lingwendil says. UPGRADE to points
Erik G
Erik G is offline
PostPosted: Thu Jul 12, 2018 10:41 am    Post subject: Re: Pertronix No spark Reply with quote
How's your ground strap?
My friend had one and it wouldn't start. Pulled my 009 out of my DC and installed it in his bug, started right up. His distributor worked in mine... I could only guess that he had some kind of electrical issue and his motor wasn't grounding or something. He previously had someone else just help him with a starter, and I was in nice clothes not about to crawl under it
The quality isn't there, make sure yours advances all the way (his didn't. that rubber grommet had to be trimmed) they really shouldnt be sold...
ccowx
ccowx is offline
PostPosted: Sat Jul 14, 2018 9:54 pm    Post subject: Re: Pertronix No spark Reply with quote
I also second(third/fourth/fifth/?) the idea of giving everything a quick look over and then trying points. Ground, power to coil, gap, etc. If that does not work, you are basically down to the module. I have not used a Pertronix myself but I have certainly heard enough stories to know that they do occasionally crap out. That and the new distributors have a bad reputation and worth going through to make sure it is all ok inside.
Chris
