HITE Samba Member
Joined: October 10, 2017 Posts: 41 Location: Virginia
Posted: Wed Jul 11, 2018 3:57 pm Post subject: 74 bus with type 4 engine not running over 45-48mph |
So I finally got the bus running about a week ago. Glorious feeling. But now I feel like I got some ripples to iron out.
I took it for a ride today to advanced auto, about 6.5 miles away. Then told my friend who owns mainly split window buses said a type 4 engine should be hauling ass.
Basic cruising speed that I got it to was about 45-48 MPH.
Light uphill she drops down to about 35-40mph (without dropping her down to 3rd gear to pick up speed)
Downhill I get to about 50-55( soft hills )
I want to say the accelerator is about an inch off the floor to keep up the 45MPH cruising speed.
I plan on changing the oil this weekend, and plan on readjusting the valves this Sunday.
I replaced the heads. And gaskets, pushrod tubes, etc. . Still leaking a bit of oil but not a ton.
Any help. Or a check list of things to go through would be awesome. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jul 11, 2018 4:09 pm Post subject: Re: 74 bus with type 4 engine not running over 45-48mph |
Have you ever done a tune up and compression test? When it's idling and you pull each plug wire out of the cap is the drop in RPM the same before you replace it and move on to the next one? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Wed Jul 11, 2018 4:28 pm Post subject: Re: 74 bus with type 4 engine not running over 45-48mph |
Maybe compared to a splittie with reduction boxes a Type 4 Bus hauls ass, but by no other reasonable standard would anyone else say it hauls ass _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Tcash Samba Member
Posted: Wed Jul 11, 2018 4:52 pm Post subject: Re: 74 bus with type 4 engine not running over 45-48mph |
Welcome to TheSamba, Bay Window Bus Forum!
73-79 NEWBIE
Tcash wrote: |
Every Type IV engine owner should know this!!!
If you over tighten the Oil Strainer bolt, you will brake the engine case!
There is a Oil strainer in there.
TORQUE THE STRAINER BOLT TO NO MORE THAN 9 FT. LBS. |
Tcash Samba Member
Posted: Wed Jul 11, 2018 4:54 pm Post subject: Re: 74 bus with type 4 engine not running over 45-48mph |
Tune up
Timing
Put a brick on the Gas pedal and go back and make sure the Throttle is all the way open.
Good luck
Tcash |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Wed Jul 11, 2018 11:35 pm Post subject: Re: 74 bus with type 4 engine not running over 45-48mph |
Tcash wrote: |
Tune up
Timing
Good luck
Tcash |
With the ignition off I assume? _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Thu Jul 12, 2018 10:52 am Post subject: Re: 74 bus with type 4 engine not running over 45-48mph |
Tcash wrote: |
Tune up
Timing
Good luck
Tcash |
I had this once.... what a night and day difference once I took the slack out, and full throttle really was.... _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Thu Jul 12, 2018 12:24 pm Post subject: Re: 74 bus with type 4 engine not running over 45-48mph |
Can we assume the brakes are not sticking? _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
timvw7476 Samba Member
Posted: Thu Jul 12, 2018 1:15 pm Post subject: Re: 74 bus with type 4 engine not running over 45-48mph |
aerosurfer wrote: |
Tcash wrote: |
Tune up
Timing
Good luck
Tcash |
I had this once.... what a night and day difference once I took the slack out, and full throttle really was.... |
^do this next^
you may need a new linkage & rod under your gas pedal. They get ovalled
out & the rod goes cock-eyed over the years, wind up with 60% throttle.: ( |
Tcash Samba Member
Posted: Thu Jul 12, 2018 9:41 pm Post subject: Re: 74 bus with type 4 engine not running over 45-48mph |
TomWesty wrote: |
Tcash wrote: |
Tune up
Timing
Good luck
Tcash |
With the ignition off I assume? |
If the engine was on, you'd be moving fast to check that throttle cable I'd bet.
Let's try it with the engine off though.
Tcash
In High School shop class, this kid was adjusting the idle in drive on a Ford Mustang. Let me paint the picture for you.
Cars in drive parking brake on, kid sitting in the engine bay adjusting idle.
As we always did in those days, he reaches over to blips the throttle to clear the carb.
The car lurches forward stopping inches from the cinder block wall in front of it. He looked at me with eyes bigger than the Owl that couldn't get to the bottom of a Tootsie pop.
HITE Samba Member
Posted: Fri Jul 13, 2018 6:19 am Post subject: Re: 74 bus with type 4 engine not running over 45-48mph |
busdaddy wrote: |
Have you ever done a tune up and compression test? When it's idling and you pull each plug wire out of the cap is the drop in RPM the same before you replace it and move on to the next one? |
I replaced the heads. (Both) because I had bad compression on #2. Also replaced the pushrod tubes. I can re-check compression. But before I replaced the heads the bus wasn’t getting above 20mph. Would barely make it up a hill. Hopefully that’s not an issue. |
Randy in Maine Samba Member
Posted: Fri Jul 13, 2018 6:38 am Post subject: Re: 74 bus with type 4 engine not running over 45-48mph |
When you are setting the timing, keep your timing light on there as you rev the engine up and down a few times to see if it really is advancing and retarding correctly.
The centrical advance in the distributor might be all crudded up with dead grease. |
Posted: Sat Jul 14, 2018 8:41 am Post subject: Re: 74 bus with type 4 engine not running over 45-48mph |
Tcash wrote: |
TomWesty wrote: |
Tcash wrote: |
Tune up
Timing
Good luck
Tcash |
Tcash
The car lurches forward stopping inches from the cinder block wall in front of it. He looked at me with eyes bigger than the Owl that couldn't get to the bottom of a Tootsie pop. |
Good thing he was in the engine bay! _________________ If you haven't bled on them, you haven't worked on them.
