74 bus with type 4 engine not running over 45-48mph
HITE
HITE is offline
PostPosted: Wed Jul 11, 2018 3:57 pm    Post subject: 74 bus with type 4 engine not running over 45-48mph Reply with quote
So I finally got the bus running about a week ago. Glorious feeling. But now I feel like I got some ripples to iron out.
I took it for a ride today to advanced auto, about 6.5 miles away. Then told my friend who owns mainly split window buses said a type 4 engine should be hauling ass.
Basic cruising speed that I got it to was about 45-48 MPH.
Light uphill she drops down to about 35-40mph (without dropping her down to 3rd gear to pick up speed)
Downhill I get to about 50-55( soft hills )
I want to say the accelerator is about an inch off the floor to keep up the 45MPH cruising speed.
I plan on changing the oil this weekend, and plan on readjusting the valves this Sunday.
I replaced the heads. And gaskets, pushrod tubes, etc. . Still leaking a bit of oil but not a ton.
Any help. Or a check list of things to go through would be awesome.
busdaddy
busdaddy is offline
PostPosted: Wed Jul 11, 2018 4:09 pm    Post subject: Re: 74 bus with type 4 engine not running over 45-48mph Reply with quote
Have you ever done a tune up and compression test? When it's idling and you pull each plug wire out of the cap is the drop in RPM the same before you replace it and move on to the next one?
sjbartnik
sjbartnik is offline
PostPosted: Wed Jul 11, 2018 4:28 pm    Post subject: Re: 74 bus with type 4 engine not running over 45-48mph Reply with quote
Maybe compared to a splittie with reduction boxes a Type 4 Bus hauls ass, but by no other reasonable standard would anyone else say it hauls ass Very Happy
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
Tcash
Tcash is offline
PostPosted: Wed Jul 11, 2018 4:52 pm    Post subject: Re: 74 bus with type 4 engine not running over 45-48mph Reply with quote
Welcome to TheSamba, Bay Window Bus Forum!
73-79 NEWBIE
Tcash wrote:
Every Type IV engine owner should know this!!!
If you over tighten the Oil Strainer bolt, you will brake the engine case!
There is a Oil strainer in there.
TORQUE THE STRAINER BOLT TO NO MORE THAN 9 FT. LBS.
Tcash wrote:
Here is a little information. Good Luck
Pictures would be cool.
How to post photos/How to post a photo in the Forums
Pronunciation (Samba) English
I am thinking of buying a VW van
Cleaning+Rodents+Hantavirus
Up in smoke... Bus fires... don't let it happen to you!
M-Plate Location
Type 2 M-Plate decoder
M-Plate Decoder Volkswagen Type 2 Bus
Bus VIN / Chassis Numbers
Type 2/Bus Owner's Manuals
Bus repair manuals
Bus parts manuals
Early Baywindow Bus Parts Book
Late Baywindow Bus Parts Fiche
Type 2 Wiring Diagrams
Model and Year Variations
Type 4: Secrets Revealed
Distributor Parts & Specifications
PARTS INTERCHANGE MANUAL
Youtube Videos
There is a ton of information located at the top of the Forum section.
Tcash
Tcash is offline
PostPosted: Wed Jul 11, 2018 4:54 pm    Post subject: Re: 74 bus with type 4 engine not running over 45-48mph Reply with quote
Tune up
Timing
Put a brick on the Gas pedal and go back and make sure the Throttle is all the way open.
Good luck
Tcash
TomWesty
TomWesty is offline
PostPosted: Wed Jul 11, 2018 11:35 pm    Post subject: Re: 74 bus with type 4 engine not running over 45-48mph Reply with quote
Tcash wrote:
Tune up
Timing
Good luck
Tcash
With the ignition off I assume? Laughing Cool
Globespotter Premium Member
Globespotter is offline
PostPosted: Thu Jul 12, 2018 8:52 am    Post subject: Re: 74 bus with type 4 engine not running over 45-48mph Reply with quote
Type 4 should be easy to cruise at 65 mph, and light hills should not slow it down to less than 55 mph.
Mine was running at the speeds you mention on 2 cylinders with zero compression in #3.
1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
Read the story about my Survivor Super Beetle: http://globespotter.com/survivor/
My 77 Westy M-Plate decoded: http://www.vw-mplate.com/mplate-30990.htm
NOTE: PM me if you want to discuss anything controversial. Done with the drama. Have put the rude ones on ignore.
aerosurfer
aerosurfer is offline
PostPosted: Thu Jul 12, 2018 10:52 am    Post subject: Re: 74 bus with type 4 engine not running over 45-48mph Reply with quote
Tcash wrote:
Tune up
Timing
Good luck
Tcash
I had this once.... what a night and day difference once I took the slack out, and full throttle really was....
Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone)
pioneer1
pioneer1 is offline
PostPosted: Thu Jul 12, 2018 12:24 pm    Post subject: Re: 74 bus with type 4 engine not running over 45-48mph Reply with quote
Can we assume the brakes are not sticking?
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
79 Westfalia
timvw7476
timvw7476 is offline
PostPosted: Thu Jul 12, 2018 1:15 pm    Post subject: Re: 74 bus with type 4 engine not running over 45-48mph Reply with quote
aerosurfer wrote:
Tcash wrote:
Tune up
Timing
Good luck
Tcash
^do this next^
you may need a new linkage & rod under your gas pedal. They get ovalled
out & the rod goes cock-eyed over the years, wind up with 60% throttle.: (
Tcash
Tcash is offline
PostPosted: Thu Jul 12, 2018 9:41 pm    Post subject: Re: 74 bus with type 4 engine not running over 45-48mph Reply with quote
TomWesty wrote:
Tcash wrote:
Tune up
Timing
Good luck
Tcash
If the engine was on, you'd be moving fast to check that throttle cable I'd bet.
Let's try it with the engine off though.
Laughing
Tcash
In High School shop class, this kid was adjusting the idle in drive on a Ford Mustang. Let me paint the picture for you.
Cars in drive parking brake on, kid sitting in the engine bay adjusting idle.
As we always did in those days, he reaches over to blips the throttle to clear the carb.
The car lurches forward stopping inches from the cinder block wall in front of it. He looked at me with eyes bigger than the Owl that couldn't get to the bottom of a Tootsie pop.
HITE
HITE is offline
PostPosted: Fri Jul 13, 2018 6:19 am    Post subject: Re: 74 bus with type 4 engine not running over 45-48mph Reply with quote
I replaced the heads. (Both) because I had bad compression on #2. Also replaced the pushrod tubes. I can re-check compression. But before I replaced the heads the bus wasnít getting above 20mph. Would barely make it up a hill. Hopefully thatís not an issue. Confused
Randy in Maine
Randy in Maine is offline
PostPosted: Fri Jul 13, 2018 6:38 am    Post subject: Re: 74 bus with type 4 engine not running over 45-48mph Reply with quote
When you are setting the timing, keep your timing light on there as you rev the engine up and down a few times to see if it really is advancing and retarding correctly.
The centrical advance in the distributor might be all crudded up with dead grease.
TomWesty
TomWesty is offline
PostPosted: Sat Jul 14, 2018 8:41 am    Post subject: Re: 74 bus with type 4 engine not running over 45-48mph Reply with quote
Tcash wrote:
TomWesty wrote:
Tcash wrote:
Tune up
Timing
Good luck
Tcash
Laughing
Tcash
Good thing he was in the engine bay! Shocked
