The Stupid Question Thread
Page: Previous  1, 2, 3 ... 374, 375, 376 ... 513, 514, 515  Next
Fish
Fish is offline
PostPosted: Mon Jul 09, 2018 9:50 pm    Post subject: Re: The Stupid Question Thread Reply with quote
FYI: You can make your own penitrating oil by useing equal amount of kerosene and ATF, Automatic Transmissio Fluid. You can substitute acetone for the kerosene, but be careful you could damage the paint with acetone mix.
Prosit!
# 303 and #156
78BusGA
78BusGA is offline
PostPosted: Mon Jul 09, 2018 9:54 pm    Post subject: Re: The Stupid Question Thread Reply with quote
• Takes copious notes writing down every detail, then carefully conducting the beginnings of the chemistry, accidentally spills the acetone on the paper dissolving the ink and destroying the notes •
Duly noted!
Few will understand the passion and majesty, among the nuts and grease.
Tom H.
My '74 Super 1303 thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=764902&start=60
My '78 Kombi Bus thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=769385&highlight=
'72 Superbeetle (retired), '78 Bus Kombi 2.0FI, '74 1303 Superbeetle
alman72
alman72 is offline
PostPosted: Thu Jul 12, 2018 1:25 pm    Post subject: Re: The Stupid Question Thread Reply with quote
what size ID gas line comes off the barb on a 73 gas tank?
LoveTours415
LoveTours415 is offline
PostPosted: Thu Jul 12, 2018 5:38 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I hope this stupid question gets me in the right direction... I have a 73 bay window standard, that I want to convert to Automatic. Would an early vanagon automatic transmission work buy just modifying the flywheel?
busdaddy
busdaddy is online now
PostPosted: Thu Jul 12, 2018 6:16 pm    Post subject: Re: The Stupid Question Thread Reply with quote
http://www.ratwell.com/technical/FuelHoses.html
Слава Україні!
busdaddy
PostPosted: Thu Jul 12, 2018 6:20 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Welcome!
Here's a collection of swap topics that will get you pointed in the right direction: https://www.thesamba.com/vw/forum/search.php?searc..._chars=200
Слава Україні!
WestySteff
WestySteff is offline
PostPosted: Sat Jul 14, 2018 2:18 am    Post subject: Re: The Stupid Question Thread Reply with quote
Hello,
I set out to adjust my valves for the first time on my 1973 Westaflia with a type IV engine. I just wanted to make sure that I didn't have hydraulic lifters. Below are a few pictures of my valve train, the question is: Are these hydraulic lifters or not. My engine has a CJ code.
ere are a few pictures of my valve train, are these hydraulic or not?
Volswagon
Volswagon is offline
PostPosted: Sat Jul 14, 2018 4:12 am    Post subject: Re: The Stupid Question Thread Reply with quote
If there is no free play, the solid spacers indicate hydraulic.
I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight=
WestySteff
PostPosted: Sat Jul 14, 2018 4:28 am    Post subject: Re: The Stupid Question Thread Reply with quote
I tried rocking them by pushing with my thumb but I couldn't, and when I tried sticking feelers in between it absolutely wouldn't get trough. But at the same time the push rods seem aluminium with a different tip than body - which i've read is one of the indicators that it could be solid...I am very confused
Wildthings
Wildthings is offline
PostPosted: Sat Jul 14, 2018 7:11 am    Post subject: Re: The Stupid Question Thread Reply with quote
With an experienced hand one can feel the difference when adjusting the valves. Back an adjusting screw off and then turn it back in slowly using just your fingers. With hydraulics there will often be a point of soft contact before you get hard contact and the valve begins to open as you turn it further.
Solids will only have the hard contact and it will always be in the same place no matter how many times you try it.
Mispeld
Mispeld is offline
PostPosted: Sat Jul 14, 2018 8:31 am    Post subject: Re: The Stupid Question Thread Reply with quote
Here is a link Tcash posted about lifters.
https://www.thesamba.com/vw/forum/viewtopic.php?p=6617613#6617613
Tom
1977 Westy. 2.0 Fuel Injected.
Mispeld
Mispeld is offline
PostPosted: Sat Jul 14, 2018 11:46 am    Post subject: Re: The Stupid Question Thread Reply with quote
Pushrod tube seal replacement - I've read so much on them. People use grey permatex non hardening sealant, grease, oil, dry, and even pipe dope.
What do you pro's out there use to seal the o rings?
Tom
cv66seabear
cv66seabear is offline
PostPosted: Sun Jul 15, 2018 11:59 am    Post subject: Re: The Stupid Question Thread Reply with quote
Replacing the clutch cable - it is driving me crazy! I cannot figure out how the cable adjustment end fits through the tiny holes in the rubber boot covers - I've tried pushing them it through, I've tried to screw it on and through, I don't want to risk enlarging the hole and ripping the boots.
How do you do this? The boots do go over the end of the tube correct?
I'd love to know how anyone gets this done in 30 minutes!
Thanks in advance,
Kent WI
"Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy"
guitarman63mm
guitarman63mm is offline
PostPosted: Sun Jul 15, 2018 4:48 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I have always used a nice synthetic grease - Super Lube is a good choice.
Gooping additional sealants on an o-ring makes little sense to me. That's more of a hack to get you home than it is best practice. Wink
Jimmy
- 1974 Safaré Custom Camper. 091 trans + Dual Weber 34 ICTs + Pertronix SVDA + 1.7L 914 T4 engine.
Wildthings
PostPosted: Sun Jul 15, 2018 5:55 pm    Post subject: Re: The Stupid Question Thread Reply with quote
You don't need any sealant beyond engine oil as that is what is going to lube them in the long run anyway. Pipe dope will make them go together easier and thus reduce the chance of the o-rings being pinched and or cut as you slip the tubes into place. Other things may work as well or better than pipe dope, but none that I have tried have done as well.
Jamminator
Jamminator is offline
PostPosted: Tue Jul 17, 2018 5:28 am    Post subject: Re: The Stupid Question Thread Reply with quote
Good morning all!
I'm about to take by 70 camper on a 2-week trip through the coast and woods of Maine.
http://jamieflorio.wixsite.com/brunosworld
I've done a lot to "Bruno", but there's one thing I've not figured out...my dash light is out. Where is that bulb?? anyone know?
thanks - Jamie
busdaddy
PostPosted: Tue Jul 17, 2018 6:40 am    Post subject: Re: The Stupid Question Thread Reply with quote
Jamminator wrote:
Good morning all!
thanks - Jamie
There's plenty of lights in the dash, could you be more specific?
Слава Україні!
KentABQ Premium Member
KentABQ is offline
PostPosted: Tue Jul 17, 2018 6:44 am    Post subject: Re: The Stupid Question Thread Reply with quote
If an early bay dash is the same as a late bay, it requires unscrewing the instrument cluster, unscrewing the speedometer cable from the cluster, then finally replacing the bulb. Take care removing the four screws holding the cluster, as each screw has a clip that will fall off and get lost.
Then to reinstall, reattach the speedo cable, partially screw the clips back on, then "pop" the cluster into place. The clips are made to hold it in place using spring tension.
Also be very careful not to let any wires come loose while removing the cluster. It's a rats nest of wires back there.
Good luck!
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
Wildthings
PostPosted: Tue Jul 17, 2018 7:04 am    Post subject: Re: The Stupid Question Thread Reply with quote
Jamminator wrote:
Good morning all!
thanks - Jamie
You could have a bad headlight switch or you could have a bad ground to the dash cluster. You can get at some of the bulbs by reaching up behind the dash.
Jamminator
PostPosted: Tue Jul 17, 2018 7:42 am    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks all!
I have dug around under the dash a bit in the rat's nest for the bulb- I just couldn't find it.
All the idiot lights work just not the illumination light. I haven't popped off the instrument cluster - I was hoping to avoid that. I will have to do that!
thanks - Jamie
Page 375 of 515
