docdanracy Samba Member
Joined: June 26, 2012 Posts: 1118 Location: Auburn, CA
Posted: Mon Jul 09, 2018 10:19 am Post subject: Re: 1970 Bug Sunroof |
New exhaust to help motor breath better.
https://youtu.be/KoEY8K26KAM _________________ Doc
1970 Sunroof Bug Yukon Yellow (L19K)
Custom 6.5x15 914 Sport Wheels wrapped in 185x65x15 Contis
Empi shifter, full compliment of gauges, 1679 with mild cam, stock induction
SOLD: 1974 Marina Blue Standard Beetle undergoing restoration/preservation
1679 with Kadrons and header/QP
914 sport wheels 5.5" ET40 wrapped in 195x65x15 Kumhos |
Posted: Fri Jul 13, 2018 9:21 pm Post subject: Re: 1970 Bug Sunroof |
Out on the town
Bob Brugge Samba Member
Joined: April 09, 2015 Posts: 721 Location: Missoula, MT
Posted: Sat Jul 14, 2018 10:28 am Post subject: Re: 1970 Bug Sunroof |
Nice little bug! _________________ Keep on Dubbin'! |
Posted: Sun Jul 15, 2018 3:37 pm Post subject: Re: 1970 Bug Sunroof |
Thank you! _________________ Doc
AlmostHeavenWV_VW Samba Member
Posted: Sun Jul 15, 2018 4:16 pm Post subject: Re: 1970 Bug Sunroof |
Bob Brugge wrote: |
Nice little bug! |
x2
Agreed.
Doc, I still crush on your bug a little more every time you post up
That color is just.... _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Sun Jul 15, 2018 8:59 pm Post subject: Re: 1970 Bug Sunroof |
Thanks guys!
Not one of the full body off restos
I was lucky to find a great car and have been making small changes to make it even better.... _________________ Doc
Posted: Mon Jul 16, 2018 4:09 pm Post subject: Re: 1970 Bug Sunroof |
Tidied up the engine compartment wiring
Placed pretty much all of it in wire looms.
Much better
Also cleaned up and polished the coil strap
This pic snows the before wiring and polished oil cap and dipstick
Posted: Tue Jul 24, 2018 4:56 pm Post subject: Re: 1970 Bug Sunroof |
Will be adding a set of vintage style fog lamps.
H3 55W bulbs.
Want to have a light on dash that lets me know when they are on.
Will also be using them as daytime running lights..
After checking speedometer found on the left side near 25mph there is a light that appears to be for parking or fog lights.
On back of speedo, there is a blank in this spot.
So a new bulb holder and bulb and I will have my fog light indicator on the speedo!
Lights are on their way and should be here tomorrow.
Posted: Wed Jul 25, 2018 7:26 pm Post subject: Re: 1970 Bug Sunroof |
H3 55W fog lights
H4 Head lights
Deciding on placement and spacing
Tough with bumper guards since they are basically right where I would like to have the lights
So accommodations must be made
Probably will be picture 3.
They unfortunately need to be at the height of the bumper guards so as not to block light from the side.
Or I could mount them under the bumper, but I prefer the vintage rallye look.
I have made a prototype mounting bracket out of scrap...
Two matching brackets will be made and then painted black to help hide them when done.
Posted: Mon Jul 30, 2018 1:06 pm Post subject: Re: 1970 Bug Sunroof |
12v H3 55W
Fog lights mounted, wired and functional!
Wired with relay and thru keyed ignition, will also be used as DRLs
All wiring in wire loom and tucked away
Posted: Mon Jul 30, 2018 5:18 pm Post subject: Re: 1970 Bug Sunroof |
And illuminated
kpf Samba Member
Joined: March 01, 2017 Posts: 853 Location: California, US
Posted: Tue Jul 31, 2018 1:38 pm Post subject: Re: 1970 Bug Sunroof |
Looks fantastic, Doc!
Did you use a dedicated switch or do the fog/DRL lights always come on with the ignition?
Regards,
Kris _________________ 1971 Super Beetle |
Posted: Tue Jul 31, 2018 2:53 pm Post subject: Re: 1970 Bug Sunroof |
Thanks Kris
Separate switch wired thru the ignition, so even if I leave them on they will go off with ignition.
Also wired thru speedometer warning light for parking lights
Light at about 25mph
Posted: Tue Jul 31, 2018 3:06 pm Post subject: Re: 1970 Bug Sunroof |
Kris,
I had a 71 Sunroof Super Beetle brand new back in the day, in Marina Blue!
Bought in San Jose at Almaden VW.
Dealership was owned by NorCal distributor of VWs
Reynold C. Johnson.
I worked for the dealership while in High School and college _________________ Doc
Posted: Tue Oct 02, 2018 9:33 pm Post subject: Re: 1970 Bug Sunroof |
Well today I decided to replace the shift rod bushing
That was a bear of a job doing it single handed. _________________ Doc
Posted: Thu Oct 04, 2018 7:31 pm Post subject: Re: 1970 Bug Sunroof |
Well that was even more fun
Drive to office today...come out after work and car wont start....cranks fine but no fire...unless accelerator floored and then sputters and quits.
Fuel leaking from carb....stuck float?
Well....take top off carb in parking lot with it raining
Float is sunk...completely full of fuel...
Damn cheap Chinese carb rebuild kit....
Took float out, got the gas out of it, reassemble and drive home.
Will put old German float back in tomorrow and seal up cheap float and keep as emergency spare only....
Lesson learned the semi hard way
Where can you get good quality carb rebuild kits? _________________ Doc
Posted: Fri Oct 12, 2018 2:01 pm Post subject: Re: 1970 Bug Sunroof |
Car has been running terrific since I went back to Solex float!
Hooked up, adjusted and tested original windshield washer...
Tank, hoses and valve all holding pressure and working as designed!
And a little idle video
https://youtu.be/RP3HlmbeFZU _________________ Doc
Posted: Fri Oct 12, 2018 4:50 pm Post subject: Re: 1970 Bug Sunroof |
docdanracy wrote: |
Where can you get good quality carb rebuild kits? |
Sucks about the float but glad you got it figured out quickly.
Unfortunately the quality of aftermarket parts for our cars is rather horrid so try to keep as many OEM parts as possible. If you do replace anything, keep the old one if it's still good. Always good to have a backup.
I have a small bin full of parts I keep in the car:
New (cheapo) distributor
Plugs
Wires
Cap
Points
Fuel pump
I guess I need to add a carb kit/float to it
I also keep a full set of tools just in case.
I like the fog lights
Here's mine. You can see my one MINI Cooper fog lamp on the left side of the front bumper.
_________________ **1971 Super Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
