Brake difference in '71 Super vs '71 Standard.
Cheburashka
Cheburashka is offline
PostPosted: Sat Jul 14, 2018 4:07 pm    Post subject: Brake difference in '71 Super vs '71 Standard. Reply with quote
OK--I fell for the "Supers have curved windshields" myth and bought a master cylinder and slave cylinders designed for a standard Beetle when mine is actually a Super. So, what are the differences in the parts? Since everything I have seems to bolt up perfectly, do I have to get Super Beetle parts, or will the standard parts work?
Edit: Never mind. I see that my rear cylinders are OK, but my fronts will be the wrong diameter and the MC will have an extra fitting that isn't used on the Super.
I assume the difference in wheel cylinder diameter is because of the single output from the MC. How much difference in size was there? (Just interested--I don't plan to use them.)
Cusser
Cusser is offline
PostPosted: Sat Jul 14, 2018 4:50 pm    Post subject: Re: Brake difference in '71 Super vs '71 Standard. Reply with quote
As you found out, only the rears are the same. The Super master cylinder is definitely different, as are the front brake stuff. I have both a 1970 standard and a 1971 Super, over 40 years with each, so I know this.
And transmission, engine, rear metal is same on 1971 standard and Super.
