Fish Samba Member
Joined: December 05, 2000 Posts: 5559 Location: OB. It's beside the point.
Posted: Mon Jul 09, 2018 9:50 pm Post subject: Re: The Stupid Question Thread |
FYI: You can make your own penitrating oil by useing equal amount of kerosene and ATF, Automatic Transmissio Fluid. You can substitute acetone for the kerosene, but be careful you could damage the paint with acetone mix. _________________ Prosit!
# 303 and #156
78BusGA Samba Member
Joined: February 01, 2017 Posts: 315 Location: Buford, Georgia
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Thu Jul 12, 2018 1:25 pm Post subject: Re: The Stupid Question Thread |
what size ID gas line comes off the barb on a 73 gas tank? |
LoveTours415 Samba Member
Joined: November 20, 2015 Posts: 1 Location: San Francisco
Posted: Thu Jul 12, 2018 5:38 pm Post subject: Re: The Stupid Question Thread |
I hope this stupid question gets me in the right direction... I have a 73 bay window standard, that I want to convert to Automatic. Would an early vanagon automatic transmission work buy just modifying the flywheel? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jul 12, 2018 6:20 pm Post subject: Re: The Stupid Question Thread |
LoveTours415 wrote: |
Welcome!
Here's a collection of swap topics that will get you pointed in the right direction: https://www.thesamba.com/vw/forum/search.php?searc..._chars=200 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
WestySteff Samba Member
Posted: Sat Jul 14, 2018 2:18 am Post subject: Re: The Stupid Question Thread |
Hello,
I set out to adjust my valves for the first time on my 1973 Westaflia with a type IV engine. I just wanted to make sure that I didn't have hydraulic lifters. Below are a few pictures of my valve train, the question is: Are these hydraulic lifters or not. My engine has a CJ code.
ere are a few pictures of my valve train, are these hydraulic or not?
Volswagon Samba Member
Joined: December 29, 2009 Posts: 299 Location: Knoxville, TN
Posted: Sat Jul 14, 2018 4:12 am Post subject: Re: The Stupid Question Thread |
If there is no free play, the solid spacers indicate hydraulic. _________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight= |
Posted: Sat Jul 14, 2018 4:28 am Post subject: Re: The Stupid Question Thread |
I tried rocking them by pushing with my thumb but I couldn't, and when I tried sticking feelers in between it absolutely wouldn't get trough. But at the same time the push rods seem aluminium with a different tip than body - which i've read is one of the indicators that it could be solid...I am very confused |
Posted: Sat Jul 14, 2018 7:11 am Post subject: Re: The Stupid Question Thread |
With an experienced hand one can feel the difference when adjusting the valves. Back an adjusting screw off and then turn it back in slowly using just your fingers. With hydraulics there will often be a point of soft contact before you get hard contact and the valve begins to open as you turn it further.
Solids will only have the hard contact and it will always be in the same place no matter how many times you try it. |
Mispeld Samba Member
Joined: April 29, 2018 Posts: 355 Location: Jacksonville - Coastal NC
Posted: Sat Jul 14, 2018 11:46 am Post subject: Re: The Stupid Question Thread |
Pushrod tube seal replacement - I've read so much on them. People use grey permatex non hardening sealant, grease, oil, dry, and even pipe dope.
What do you pro's out there use to seal the o rings? _________________ Tom
1977 Westy. 2.0 Fuel Injected. |
cv66seabear Samba Member
Joined: February 18, 2017 Posts: 105 Location: Wisconsin
Posted: Sun Jul 15, 2018 11:59 am Post subject: Re: The Stupid Question Thread |
Replacing the clutch cable - it is driving me crazy! I cannot figure out how the cable adjustment end fits through the tiny holes in the rubber boot covers - I've tried pushing them it through, I've tried to screw it on and through, I don't want to risk enlarging the hole and ripping the boots.
How do you do this? The boots do go over the end of the tube correct?
I'd love to know how anyone gets this done in 30 minutes!
Thanks in advance,
Kent WI _________________ "Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy" |
guitarman63mm Samba Member
Joined: September 03, 2008 Posts: 797 Location: Asheville, NC
Posted: Sun Jul 15, 2018 4:48 pm Post subject: Re: The Stupid Question Thread |
Mispeld wrote: |
What do you pro's out there use to seal the o rings? |
I have always used a nice synthetic grease - Super Lube is a good choice.
Gooping additional sealants on an o-ring makes little sense to me. That's more of a hack to get you home than it is best practice. _________________ Jimmy
- 1974 Safaré Custom Camper. 091 trans + Dual Weber 34 ICTs + Pertronix SVDA + 1.7L 914 T4 engine. |
Posted: Sun Jul 15, 2018 5:55 pm Post subject: Re: The Stupid Question Thread |
Mispeld wrote: |
You don't need any sealant beyond engine oil as that is what is going to lube them in the long run anyway. Pipe dope will make them go together easier and thus reduce the chance of the o-rings being pinched and or cut as you slip the tubes into place. Other things may work as well or better than pipe dope, but none that I have tried have done as well. |
Jamminator Samba Member
Joined: August 02, 2014 Posts: 10 Location: Rochester, NH
Posted: Tue Jul 17, 2018 5:28 am Post subject: Re: The Stupid Question Thread |
Good morning all!
I'm about to take by 70 camper on a 2-week trip through the coast and woods of Maine.
http://jamieflorio.wixsite.com/brunosworld
I've done a lot to "Bruno", but there's one thing I've not figured out...my dash light is out. Where is that bulb?? anyone know?
thanks - Jamie |
Posted: Tue Jul 17, 2018 6:40 am Post subject: Re: The Stupid Question Thread |
Jamminator wrote: |
Good morning all!
thanks - Jamie |
There's plenty of lights in the dash, could you be more specific? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Tue Jul 17, 2018 6:44 am Post subject: Re: The Stupid Question Thread |
If an early bay dash is the same as a late bay, it requires unscrewing the instrument cluster, unscrewing the speedometer cable from the cluster, then finally replacing the bulb. Take care removing the four screws holding the cluster, as each screw has a clip that will fall off and get lost.
Then to reinstall, reattach the speedo cable, partially screw the clips back on, then "pop" the cluster into place. The clips are made to hold it in place using spring tension.
Also be very careful not to let any wires come loose while removing the cluster. It's a rats nest of wires back there.
Good luck! _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Posted: Tue Jul 17, 2018 7:04 am Post subject: Re: The Stupid Question Thread |
Jamminator wrote: |
Good morning all!
thanks - Jamie |
You could have a bad headlight switch or you could have a bad ground to the dash cluster. You can get at some of the bulbs by reaching up behind the dash. |
Posted: Tue Jul 17, 2018 7:42 am Post subject: Re: The Stupid Question Thread |
Thanks all!
I have dug around under the dash a bit in the rat's nest for the bulb- I just couldn't find it.
All the idiot lights work just not the illumination light. I haven't popped off the instrument cluster - I was hoping to avoid that. I will have to do that!
thanks - Jamie |
