Official Fuel injection questions thread
Page: Previous  1, 2, 3 ... 7, 8, 9 ... 54, 55, 56  Next
owdlvr
owdlvr is offline
PostPosted: Tue Jun 26, 2018 4:48 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
Okay, a new patient to consider. Car is a 1979 Beetle, completely stock including points. Not your usual internet forum "stock" either, this one is restored to be as it left the factory.
Starts up cold, no problem. Idles fine. Drives fine. On a cold day, you can drive all day without a problem. On warm days, its a gamble. On hot days, you know you're going to have an issue.
On a hot day you can drive the car for about 30-45min before it starts to stumble, and will die. You will not be able to get the car to restart. On a warm day, you can drive 2 hours plus without a problem, but as soon as you stop and shut the car off...it won't restart. If you wait 20-40min the car will fire back up, act as though it has no problem, and drive for an equal amount of time. On a hot day, this is 30-45min. On a warm day, until you shut the car off.
The will-not-start problem was non-existent five years ago, but has become progressively more common over the last three driving seasons. The car dying after 30-45min of driving on a hot day surfaced last summer, and continues this spring.
The patient vehicle is owned by my father, and we live on opposite sides of the country. It's only ever died on me once, but it's now at the point where Dad can't realistically trust the car to go anywhere. Power is seen a the fuel pump when it won't restart, but as I was actually starting one of my classic car adventures events at the time it died on me, I didn't get time to dive into the diagnosis further.
• Fuel pump is original german pump from 1979.
• Double relay has been replaced.
• Fuel lines are due for replacement due to age, but only out of caution for our ethanol fuels. They're still soft, pliable and (at least last Fall) when I pulled one and checked it, still good inside.
I think that is all the relevant details I can think of at the moment.
-Dave
Instagram: @DaveHord
1971 1302s - Salzburg Tribute the #RallyBug
1958 Beetle
1975 Beetle
1973 Super Beetle
1993 C3500 with Cummins swap
1967 MGB
1963 MG Midget
busdaddy
busdaddy is offline
PostPosted: Tue Jun 26, 2018 5:03 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
Has he tried another TS2 (the sensor in the head above #4's rockerbox)?, it's always good to have a spare on board if it doesn't change the way it behaves.
Sounds like it's flooding itself, most likely due to a weak TS2, the parking lot hack would be to ground the wire that leads to the sensor when it's acting up and see if it starts (puts system in full lean mode).
Слава Україні!
owdlvr
owdlvr is offline
PostPosted: Tue Jun 26, 2018 5:10 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
He hasn't! Will send him out for a road-test!
-Dave
1958 Beetle
1975 Beetle
1973 Super Beetle
1967 MGB
1963 MG Midget
Ithomson
Ithomson is offline
PostPosted: Sun Jul 15, 2018 7:43 am    Post subject: Re: Official Fuel injection questions thread Reply with quote
How important is the exhaust temp sensor on a non-catalytic setup of a 1975-1979 FI beetle engine? They are getting hard to come by these days?
busdaddy
busdaddy is offline
PostPosted: Sun Jul 15, 2018 8:25 am    Post subject: Re: Official Fuel injection questions thread Reply with quote
Hmmm..., VW didn't use an oxygen sensor on L-jet in the beetle, at least for the North American market, maybe it's an Aus only thing?, is it connected to anything?
https://www.thesamba.com/vw/forum/viewtopic.php?t=694380
Слава Україні!
Ithomson
Ithomson is offline
PostPosted: Sun Jul 15, 2018 8:16 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
It doesn’t look like an oxygen sensor, just a metal probe that seems to connect to the ECU from the exhaust. I think they describe it as a gas temperature switch for the AJ engine.
busdaddy
busdaddy is offline
PostPosted: Sun Jul 15, 2018 8:24 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
Time to break out the camera, doesn't sound like something VW put there.
Слава Україні!
Ithomson
Ithomson is offline
PostPosted: Mon Jul 16, 2018 12:47 am    Post subject: Re: Official Fuel injection questions thread Reply with quote
Okay - here goes.
[img]
It is the braided cable running from the cooling tin up to this connection which then drops back behind the shroud.
I found a schematic showing the sensor connecting to a catalytic converter on the California bugs, but my bug came with a sensor until it shredded off during a drive (wasn't connected to the new exhaust). My bug doesn't have a catalytic converter, so I am not too sure why it is needed.
busdaddy
busdaddy is offline
PostPosted: Mon Jul 16, 2018 6:55 am    Post subject: Re: Official Fuel injection questions thread Reply with quote
Ithomson wrote:
Okay - here goes.
[pics]
Shocked OK, looks like VW did indeed put it there, never seen that before.
Since the wires are colored and the plug isn't a Bosch style I wonder if it's controlling a vacuum valve or something that isn't directly part of the FI?
Where do the wires from it lead to up front of the shroud?
Слава Україні!
airschooled
Air-Schooled
airschooled is offline
PostPosted: Wed Aug 01, 2018 10:49 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
x2, please let us know!
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
cphipps79
cphipps79 is offline
PostPosted: Mon Aug 20, 2018 8:05 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
I was considering upgrading to electronic ignition on my 75 FI. I have searched and hadn’t found someone that has done it and what they used. I am also having trouble finding the correct setup for the fuel injection, could anyone point me in the right direction? Thanks!!
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger Facebook Gallery Classifieds Feedback
busdaddy
busdaddy is offline
PostPosted: Mon Aug 20, 2018 9:33 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
Not many (if any) points conversion modules produce the correct waveform for the ECU to interpret, you are better off buying your points at NAPA (not Bosch) and checking/lubing them at each oil change.
Слава Україні!
cphipps79
PostPosted: Thu Aug 23, 2018 3:28 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
Well that sucks haha. Let me ask this, is it possible to get the famous beetle chirp or “fweem” out of the FI exhaust? Or at all for that matter?
busdaddy
busdaddy is offline
PostPosted: Thu Aug 23, 2018 3:56 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
More bad news, that sound comes from the tiny tailpipes and the perforated lining inside them, the better breathing FI exhaust system won't do that, unless maybe you lined the tailpipe with perforated metal.
Слава Україні!
Cherry
Cherry is offline
PostPosted: Sun Sep 02, 2018 3:27 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
I'm not sure if I'm asking in the right place I'm new here but here goes. I'm putting back together a 1975 beetle 1303 and running into a bit of difficulty with the fuel injection. Beetle is firing up but won't stay running ive tested intake air sensor and it testing OK I've checked fuel pump and pressure and all seems OK just doest seem to want to take off any help or ideas of what else to check is appreciated
busdaddy
busdaddy is offline
PostPosted: Sun Sep 02, 2018 3:36 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
Welcome!
This is the right place, but it's also OK if you start a dedicated thread for this resurrection project of yours to avoid cross contamination.
So it starts but quits seconds after releasing the key? Sounds like the AFM isn't closing the fuel pump contacts when it opens, maybe it's not opening due to a large vacuum leak? Does the fuel pump run when you poke the AFM flap through the inlet while the key is on?
Слава Україні!
Cherry
Cherry is offline
PostPosted: Sun Sep 02, 2018 3:43 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
busdaddy wrote:
Welcome!
Yes it does. When it's firing the flap is fluttering constantly
busdaddy
busdaddy is offline
PostPosted: Sun Sep 02, 2018 4:02 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
Cherry wrote:
busdaddy wrote:
Welcome!
A smoke test can't make it worse: https://www.thesamba.com/vw/forum/viewtopic.php?t=620083&highlight=smoke+tester you'll be suprised what shows up, and L-jet can't tolerate the tinyest leak.
Слава Україні!
Cherry
Cherry is offline
PostPosted: Mon Sep 03, 2018 3:38 am    Post subject: Re: Official Fuel injection questions thread Reply with quote
busdaddy wrote:
Cherry wrote:
busdaddy wrote:
Welcome!
Thanks for that will give it a go in the few day
Cherry
Cherry is offline
PostPosted: Sat Sep 08, 2018 3:59 am    Post subject: Re: Official Fuel injection questions thread Reply with quote
busdaddy wrote:
Cherry wrote:
busdaddy wrote:
Welcome!
Thanks for your help it was a leak on a hose have replaced them and it's running good now
Page 8 of 56
