Anybody have a spare 94mm Mahle Cylinder for a 2.0 bus motor?
69BahamaYellow
69BahamaYellow is offline
PostPosted: Thu Jul 12, 2018 5:14 am    Post subject: Anybody have a spare 94mm Mahle Cylinder for a 2.0 bus motor? Reply with quote
I'm rebuilding a 1978 bus motor that had been sitting in storage for many years, and condensation got into 1 cylinder and pitted it. The other 3 cylinders and all 4 of the pistons are in great shape, with very low miles on them (like maybe 5,000 miles), since the pistons/cylinders had been replaced shortly before it went into storage, so I'd rather just replace the 1 bad cylinder than buy another whole set.
Randy in Maine
Randy in Maine is offline
PostPosted: Thu Jul 12, 2018 5:17 am    Post subject: Re: Anybody have a spare 94mm Mahle Cylinder for a 2.0 bus motor? Reply with quote
Try John at aircooled.net Sometimes he has stuff like that.
69BahamaYellow
PostPosted: Mon Jul 16, 2018 4:04 am    Post subject: Re: Anybody have a spare 94mm Mahle Cylinder for a 2.0 bus motor? Reply with quote
Thanks for the tip. I checked and they only sell cylinders in sets of 4 from AA for about $130. Wouldn't be a bad option, but I'm going to keep looking for a used Mahle Cylinder for a little while longer....
guitarman63mm
guitarman63mm is offline
PostPosted: Mon Jul 16, 2018 4:34 am    Post subject: Re: Anybody have a spare 94mm Mahle Cylinder for a 2.0 bus motor? Reply with quote
I think he may have meant to shoot them an email to see if they have one floating around. I doubt it's something they'd list on the site given that most people replace these in sets.
Jimmy
- 1974 Safaré Custom Camper. 091 trans + Dual Weber 34 ICTs + Pertronix SVDA + 1.7L 914 T4 engine.
riverside66
riverside66 is offline
PostPosted: Mon Jul 16, 2018 7:09 am    Post subject: Re: Anybody have a spare 94mm Mahle Cylinder for a 2.0 bus motor? Reply with quote
I'm pretty sure I do (actually I think I have 3 of them, Mahle specifically, never used). Let me just confirm that first, and I'll get back with you...
1977 Standard Beetle -Sold-
1979 Transporter - "Wheatbread" -Sold-
Randy in Maine
PostPosted: Mon Jul 16, 2018 7:28 am    Post subject: Re: Anybody have a spare 94mm Mahle Cylinder for a 2.0 bus motor? Reply with quote
And keep in mind that a 94mm P&C for a Type 4 engine is different that a 94mm for a Type 1 engine.
SGKent Premium Member
SGKent is offline
PostPosted: Mon Jul 16, 2018 7:38 am    Post subject: Re: Anybody have a spare 94mm Mahle Cylinder for a 2.0 bus motor? Reply with quote
also please don't just stick a piston into a cylinder without having it properly measured first. If it is loose it may rattle like hell, and if tight seize when it gets hot.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
69BahamaYellow
PostPosted: Mon Jul 16, 2018 9:07 am    Post subject: Re: Anybody have a spare 94mm Mahle Cylinder for a 2.0 bus motor? Reply with quote
Awesome! PM me if you do. Also Randy in Maine made a good point that I need a 94mm cylinder for a type 4 motor.
Seems like the top of the cylinder protrudes about 1/4" from the fins on a type 4 cylinder and about 3/4" on a type 1, but for sure they are not interchangeable, even though the bore is the same.
On a new or fairly low mileage used Mahle cylinder, I think I'm pretty good on making my current piston fit. I've alway's had good luck with the machining tolerances on Mahle P&C's, but SGKent makes a good point about sizing them correctly, since I know Mahle grades both the pistons and cylinders to fit together with optimum clearance.
riverside66
PostPosted: Mon Jul 16, 2018 9:15 am    Post subject: Re: Anybody have a spare 94mm Mahle Cylinder for a 2.0 bus motor? Reply with quote
Yup, type 4. I'll PM ya.
