Tcash Samba Member
WESTYJACK Samba Member
Joined: February 21, 2017 Posts: 266 Location: LAVAL,QC CANADA
Posted: Sun Jul 08, 2018 3:16 pm Post subject: Re: timming help |
new update
an maybe the resolve
after 2 hours go under the bus unpluged the inlet hose of the pump (good flow) an this was pass the fuel filter so filter good
after this time the pump was cool
start it start right up with 40-45 psi
go under the bus and the pump make no sound and it idle perfectly put my hand on the pump and nothing
return up an rev trhe bus about 3000 rpm
return under the pump start to make sound like vibration put my hand on the pump and feel something vibrating
my wife tell me this morning "hey what is that sound" it was the pump
so now i know that the pump make no sound when it is working ok
my oppnion
pump goes hot why? start to make noise after some time and drop in pressure
i'l check for filter in pump no filter _________________ VW bus type 2 1978 transplant engine 1975 1800cc fuel injection |
Posted: Sun Jul 08, 2018 6:21 pm Post subject: Re: timming help |
WESTYJACK wrote: |
my oppnion
i'l check for filter in pump no filter |
Everything is pointing to a restriction in flow. When there is normal flow the gasoline cools the pump as it moves through the pump and the pump isn't having to suck hard so it runs quiet. However once something on the suction side of the pump begins to limit fuel flow, the pump begins to cavitate and starts making noise and the lack of flow causes the pump to get hot. |
Posted: Sun Jul 08, 2018 6:36 pm Post subject: Re: timming help |
maybe but where
if i unplug the hose at the pump inlet i have full flow
bad pump possibility or not _________________ VW bus type 2 1978 transplant engine 1975 1800cc fuel injection |
Posted: Sun Jul 15, 2018 10:26 am Post subject: Re: timming help |
update
no more fuel problem
i drop the tank clean the brand new tank i install a week ago and now no more starvation
next timming _________________ VW bus type 2 1978 transplant engine 1975 1800cc fuel injection |
Posted: Sun Jul 15, 2018 10:58 am Post subject: Re: timming help |
WESTYJACK wrote: |
next timming |
Or maybe as known in the US "timing"
Posted: Sun Jul 15, 2018 1:39 pm Post subject: Re: timming help |
your right
timing
i take the bus for a little ride run great but seem to have hesitation in 2 and acceleration is very slow 60mph gonna be hard to do
know that bay bus is not a jet but...
tomorrow check trottle cable ajustment and timing _________________ VW bus type 2 1978 transplant engine 1975 1800cc fuel injection |
Posted: Sun Jul 15, 2018 2:12 pm Post subject: Re: timming help |
The best timing for your engine will be 28° BTDC @3500+ rpm, hose(s) off and plugged. Depending on what distributor you have and its condition, if you time your engine to the spec given in the book it may not run all that well or may run hot. |
Posted: Sun Jul 15, 2018 6:02 pm Post subject: Re: timming help |
Thanks
first check dist if advance work ok
next timing at 28 BTDC at 3500 rmp
last thing
install my gauge
oil pressure
head temp
volmeter
alarm for head temp
tacho
put photos _________________ VW bus type 2 1978 transplant engine 1975 1800cc fuel injection |
Tcash Samba Member
Posted: Mon Jul 16, 2018 9:47 am Post subject: Re: timming help |
update
work on the distributor 005 clean and lube (TCASH)
contact breaker dwell 50 (a bit used)
contact breaker gap .016
timing 32-34 BTDC at 3500 rmp (have to redo dont remember if vacuum was unplung)
advance work ok and dist can hold vacuum
your opinion? _________________ VW bus type 2 1978 transplant engine 1975 1800cc fuel injection |
Tcash Samba Member
Posted: Mon Jul 16, 2018 10:32 am Post subject: Re: timming help |
It is: next timing at 28 BTDC at 3500 hosed disconnected and plugged. |
Posted: Thu Jul 19, 2018 12:52 pm Post subject: Re: timming help |
update
dwell at 45-50
timing at 28 BTDC @ 3500
i have an exhaust leak at deceleration small back fire or pop at the exhaust
go for road test
engine idle and run great
i try to get a cruising speed of 60mph it's seem to be very long to get that speed
i'm not very used to run air cooled engine so maybe not go enough higher in rpm
remark my rpm in the dash is not install yet
your comment please
thanks _________________ VW bus type 2 1978 transplant engine 1975 1800cc fuel injection |
Tcash Samba Member
Posted: Thu Jul 19, 2018 2:10 pm Post subject: Re: 1975 1800cc fuel injection timming help |
Tcash Samba Member
Tcash Samba Member
Posted: Thu Jul 19, 2018 2:12 pm Post subject: Re: 1975 1800cc fuel injection timming help |
A little reading.
Welcome to TheSamba, Bay Window Bus Forum!
73-79 NEWBIE
Tcash wrote: |
Every Type IV engine owner should know this!!!
If you over tighten the Oil Strainer bolt, you will brake the engine case!
There is a Oil strainer in there.
TORQUE THE STRAINER BOLT TO NO MORE THAN 9 FT. LBS. |
Posted: Thu Jul 19, 2018 6:13 pm Post subject: Re: 1975 1800cc fuel injection timming help |
The timing was with the hose(s) disconnected from the vacuum can? |
Posted: Fri Jul 20, 2018 5:46 am Post subject: Re: 1975 1800cc fuel injection timming help |
yes and hose blocked
order center pin (loose in steering)
check everything but loose come from there for sure
What do you think about performance of the engine
dwell ok
point at 016 check and clean
timing at 28 BTDC at 3500 rpm
last compression test around 110-120 each
leak at exhaust
but like i write earlier newbie to aircooled but trying to make 60mph last run seem like impossible
the only thing i can see is i dont rev enough the engine to make it
if i remember right i shift 3 to 4 at maybe 40-45 mph (canada 60KmH) _________________ VW bus type 2 1978 transplant engine 1975 1800cc fuel injection |
Posted: Fri Jul 20, 2018 7:34 am Post subject: Re: 1975 1800cc fuel injection timming help |
The engine should run 75mph/120Kph easily enough.
Do a 30 kilometer highway run and then pull a plug and get us a nice sharp picture of it. |
busdaddy Samba Member
Posted: Fri Jul 20, 2018 9:11 am Post subject: Re: 1975 1800cc fuel injection timming help |
WESTYJACK wrote: |
if i remember right i shift 3 to 4 at maybe 40-45 mph (canada 60KmH) |
That's a good speed to be shifting from 3rd to 4th at.
Anything odd about your bus? like tiny tires?, big tires?, high top?, 5000 lbs of surf and video gear onboard? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
