Auto Trans and Diff Shims
T91Carat
T91Carat is offline
PostPosted: Mon Jul 16, 2018 12:16 pm    Post subject: Auto Trans and Diff Shims Reply with quote
91 Carat, auto. In the process of swapping for a EJ22 and updating all seals possible while the engine and transaxle are out of the vehicle.
Upon splitting the Diff from the Trans we noticed that one of the two shims that where on the there looks severely misshapen. The one looks perfect... the other is no longer round and actually has scoring on it.
Has anyone seen this before? And where can I go to another to replace it?
Thanks,
blee
blee is offline
PostPosted: Mon Jul 06, 2020 5:29 pm    Post subject: Re: Auto Trans and Diff Shims Reply with quote
Looking for the same, did you ever find them? If so where. Thanks
MarkWard
MarkWard is offline
PostPosted: Mon Jul 06, 2020 5:41 pm    Post subject: Re: Auto Trans and Diff Shims Reply with quote
The manual has the part numbers for the different thickness shims. Lately it seems trans parts are available from Porsche. Once you have the numbers, you can google and see what comes up.
edit: I was wrong, my Bentley manual does not show the part numbers. I remembered wrong. My ETKA does not show the shims either. Weird.
jlrftype7
jlrftype7 is offline
PostPosted: Mon Jul 06, 2020 6:11 pm    Post subject: Re: Auto Trans and Diff Shims Reply with quote
I bought the following shims from Mc-Master Carr, .30mm, .40mm, 1.0mm, 1.2mm. And 1.5mm. Stock shims were listed in Bentley as .40mm and 1.2mm if I remember right, but I got an assortment just to be safe.
While Porsche may still stock them, McMaster has them here in the States.
Steel and Stainless Steel. I believe all the ones I bought were steel.
I can look up my order history if you need more info.
Fit just fine on the ID and OD needed, and I use the Transmission assembly heavy lube to keep them together and next to the Final Drive assembly while installing the trans against the final drive.
Not expensive at all since they’re small and so thin... Cool
Okay, 3088A368 gets you .38mm,/ inch spec is .015”. Works great as the .40mm shim
And for 1.2mm, use 3088A458, which is 1.19mm/ .0470”
Rockwell B65 spec carbon steel, 1008/1010
ID is basically 32mm and OD is approx 45mm for both
‘84 Tin Top - Hilga....Auto
vwhammer
vwhammer is offline
PostPosted: Tue Jul 07, 2020 1:03 pm    Post subject: Re: Auto Trans and Diff Shims Reply with quote
Yup I second the McMaster-Carr shims.
Seems like the cheapest easiest solution and was also my suggestion in the "Building a better Vanagon automatic transaxle" thread when the same subject came up.
Pretty normal daily driver build
https://www.thesamba.com/vw/forum/viewtopic.php?t=708418&highlight=
4x4 build
https://www.expeditionportal.com/forum/threads/volkswagen-vanagon-4x4-conversion.162055/
View user's profile Send private message Yahoo Messenger Instagram Classifieds Feedback
blackglasspirate
blackglasspirate is offline
PostPosted: Tue Jul 07, 2020 4:59 pm    Post subject: Re: Auto Trans and Diff Shims Reply with quote
I got mine from a Porsche specific site based in Atlanta, though they had to order them from Europe. Expedited shipping was still pretty cheap ($10-$20, don't remember). Once you know what thickness you need, you can find the part numbers in the Bentley and get the exact ones. I think I either got them from Auto Atlanta, or Vertex Auto.
'87 Vanagon GL Westfalia
IG: @holidayatsee
FB: https://www.facebook.com/holidayatsee
