Marleybus Samba Member
Joined: January 05, 2013 Posts: 314 Location: Oro Station, Ontario, Canada
Posted: Tue Jul 17, 2018 3:24 am Post subject: What size nut do I need? |
I recently lost the nut that attaches to the bolt that is the pivot bolt for the Alternator for my 77 bus. The bolt has a rounded head with one flat side and rests behind the Alternator belt. I need to buy another nut and try to thread on to the bolt.
Anyone know this nut size? _________________ 1972 VW Westy (Hit by dumptruck)
1963 VW Beetle (RIP)
1974 VW Beetle (RIP)
1981 Vanagon Westfalia (Sold)
1969 VW Beetle Convertible (Wifes)
1977 VW Westy 2.0L FI Chrome Yellow
1978 VW Westy 2.0L FI (Under Restoration)
1973 VW Westy 1.7L Tourist Delivery Orange
Check out my thread!!http://www.thesamba.com/vw/forum/viewtopic.php?t=556709 |
guitarman63mm Samba Member
Joined: September 03, 2008 Posts: 797 Location: Asheville, NC
Posted: Tue Jul 17, 2018 3:44 am Post subject: Re: What size nut do I need? |
Pretty sure most of the hardware down there is M8x1.25. _________________ Jimmy
- 1974 Safaré Custom Camper. 091 trans + Dual Weber 34 ICTs + Pertronix SVDA + 1.7L 914 T4 engine. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Tue Jul 17, 2018 6:09 am Post subject: Re: What size nut do I need? |
guitarman63mm wrote: |
Pretty sure most of the hardware down there is M8x1.25. |
X2- its the adjuster nut that's hard to find- so basically- any old nut will do. (in that thread) - as long as you tighten it when the adjustment is done- a dab of silicone on the threads will help hold it in place and won't "lock " it to tight to loosen for future adjustments. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
SGKent Samba Member
Posted: Tue Jul 17, 2018 7:57 am Post subject: Re: What size nut do I need? |
Buying a flange nut will eliminate the need for a washer under the nut. Sounds like you may have had an acorn nut to begin with, this would be unnecessary unless someone was just trying to keep road salts away from the threads. |
Tcash Samba Member
