mtnride1 Samba Member
Joined: March 30, 2011 Posts: 194 Location: la quinta, CA
Posted: Sun Aug 14, 2016 6:34 pm Post subject: fantastic fan install |
Has anyone installed a fantastic fan in the existing skylight or anywhere else on the pop top? |
Birdcage Samba Member
Joined: November 06, 2013 Posts: 203 Location: Collins of fort
Posted: Sun Aug 14, 2016 9:38 pm Post subject: Re: fantastic fan install |
Pretty simple, cut 14"x14" hole and place it in. If you wanna replace the existing vent you have to make a custom surround, still pretty easy. _________________ @syncrostyle
@optoverland |
MidwestDrifter Samba Member
Joined: June 13, 2012 Posts: 769 Location: Kicking Around Australia
Posted: Mon Aug 15, 2016 11:29 am Post subject: Re: fantastic fan install |
The PO of my van hacked a nasty oversized skylight vent into the westy roof. I lost it to some straight line winds. I made a patch for the hole, and installed a fan into the patch.
It was one of the best upgrades to the van. Having forced ventilation is amazing. Doing it again I would use a maxxair fan. They are overall better quality, and can be left open in the rain. _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
1982 Diesel Westy W/ ABA I4 hybrid (Sold)
Epic Road Tripping since 08/05/12 | http://VagariesAbound.blogspot.com/
My Current Build | http://sprinter-source.com/forum/showthread.php?t=41215 |
Dana Champion Samba Member
Joined: July 06, 2012 Posts: 633 Location: Ventura County, CA
Posted: Mon Aug 15, 2016 3:10 pm Post subject: Re: fantastic fan install |
The roof isn't thick enough on the poptop. Fantastic Fans are designed for motorhomes with insulated roofs. I put one in a Winnebago LeSharo that I used to have.
I contacted Fantastic Fan, for advice. They suggested using their shallowest unit, and using a foam spacer. The roof on the Lesharo is about one inch thick. I had to use two spacers.
Maybe you could have the spacer on the inside...?, and incorporate some kind of cool tricky light, since you will need juice for the fan.
If they made one for a thin roof like the poptop, it would make more sense. |
Posted: Mon Aug 15, 2016 9:02 pm Post subject: Re: fantastic fan install |
Dana Champion wrote: |
There's more than one way to skin a rabbit, both fantastic and maxxfans fit just fine on the westy top. Just look at all the tops fiberine sells, nearly everyone gets a fan or an AC unit and their not much thicker then the westy top. I install a handful every week. Once installed a fan on the side of a van 1/8" sheet metal and worked beautifully. OP if you wanna do this I can walk you thru the steps it's easy peasy couple hours of work. _________________ @syncrostyle
@optoverland |
Posted: Tue Aug 16, 2016 10:28 am Post subject: Re: fantastic fan install |
Birdcage wrote: |
There's more than one way to skin a rabbit, both fantastic and maxxfans fit just fine on the westy top. Just look at all the tops fiberine sells, nearly everyone gets a fan or an AC unit and their not much thicker then the westy top. I install a handful every week. Once installed a fan on the side of a van 1/8" sheet metal and worked beautifully. OP if you wanna do this I can walk you thru the steps it's easy peasy couple hours of work. |
Awesome! ... Any pictures of your installations? Like to see how they look! |
Phaedrus Samba Member
Joined: January 06, 2014 Posts: 500 Location: Washington
Posted: Tue Aug 16, 2016 4:33 pm Post subject: Re: fantastic fan install |
I second the interest in some sort of walkthrough or guide or first-hand experience. Would like to install one of these on my tin top camper. Is there really a drastic quality difference Fantastic Fan vs. Maxxair? Around the same price point, lots of solid reviews for both... _________________ 1986 WBX (Tin Top Camper) |
Posted: Tue Aug 16, 2016 5:24 pm Post subject: Re: fantastic fan install |
Both fans work great, I favor the maxxfan for the following reasons
1. Although the it sits a bit higher, it looks nicer to me
2. It has two arms for closing the vent so it doesn't flutter at highway speeds
3. You can leave it up while it's raining
4. You can drive with it up and running
5. They just updated it and the new remote is a lot nicer
Although the maxx has 10 speeds the highest setting is equal to the highest #3 setting on the fantastic.
Both fans have the same 14"x14" footprint both install with 16 screws that are provided. I normally toss those and use my own but the ones it comes with work o.k.
Other things you'll want to have on hand
1. Pre upholstered spacer made from 2"x2" lumber is sufficient *hint (cut 4 pcs. @ 14.5" arrange so they fit the 14" opening, glue, staple, upholster)
2. Plumbers putty or eternabond
3. Split loom or other wiring cover for routing your wires to a power source
4. Self leveling lap sealant I prefer grey because the white turns brown and gross in no time.
5. Table saw without safety guard or air saw to cut the trim cover to size
6. Enough wire (I use bonded 16/2) to route to a power source. Use an inline fuse in not wiring to a fuse block. 5a will do the job.
Let me know if y'all have any questions. _________________ @syncrostyle
@optoverland |
Posted: Tue Aug 16, 2016 6:35 pm Post subject: Re: fantastic fan install |
Birdcage wrote: |
Let me know if y'all have any questions. |
Thank you mucho, Birdcage. Sounds really straightforward. Do you happen to have any pics lying around of what the finished install should look like on a Vanagon? Just curious. Sure I could figure it out without (the links Midwest posted require registration with that forum). _________________ 1986 WBX (Tin Top Camper) |
Stevekirk Samba Member
Posted: Tue Jul 17, 2018 7:55 am Post subject: Re: fantastic fan install |
So reading this old post I really didn’t see where a Maxxair roof fan was installed on a westy.
If installed where the skylight would go you would somehow have to deal with the size not being 14x14 and the drain channels
Anyone done this |
kourt Samba Member
Joined: August 13, 2013 Posts: 1941 Location: Austin, TX
human compass Samba Member
Joined: June 04, 2013 Posts: 423 Location: Flagstaff,AZ
Posted: Tue Jul 17, 2018 1:48 pm Post subject: Re: fantastic fan install |
It seems like all that is needed to make this a clean install is an adapter plate for the exterior, to fill the drain channel, and another for the inside to increase thickness. Surely one of your 3d printer friends could do this?
Outside of that it's just a couple of cuts and some wiring...
Wish I had a 3d printer and the know how. _________________ 84 Westy Syncro- 3.3L SVX stage 2 tune,subaru gears 6speed with tbd, front locker, porche brakes x4, aux tank, radflo susp |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6243 Location: Portland OR
Posted: Tue Jul 17, 2018 3:51 pm Post subject: Re: fantastic fan install |
I vent fan will only be affective when it is in a sealed opening. Just installing an open fan in the skylight would not pull air through the van unless the rest of the opening was sealed. _________________ 89 Westy 2.1 Auto |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Tue Jul 17, 2018 9:01 pm Post subject: Re: fantastic fan install |
We need a clean mod adapter of sorts for this upgrade. Lets face it our skylights are basically pathetic. A maxxair or fantastic fan are huge improvements, presuming you have the power source. I just did a week in the canadian badlands and was pretty hot in the van even at 11oclock at night. I have a 12v fan but it doesnt quite cut it. Having a way to vent hot air forcefully through the skylight is key. I am all ears on this |
jimf909 Samba Member
Posted: Tue Jul 17, 2018 10:46 pm Post subject: Re: fantastic fan install |
PDXWESTY has shared good knowledge on air exchange in other threads.
I’ll say that a FantasticFan moves a lot of air through my van and makes a noticeable difference in van comfort by exchanging stale van air with fresh evening air from outside the van.
My frugal dad used a whole house fan to replace stale Illinois afternoon heated air with cool evening air in the house. On some days that influx of cool evening air was all that was needed, on other days it was too hot outside and the central a/c was the only solution.
Likewise in a van, some days a high-volume air exchange provided by a FantasticFan or Maxx fan is perfect. It won’t replace a/c in some conditions but in some places where daytime temps are in the 80s/90s during the day and drop to the 60s at night it accelerates temp drops in the van. It’s also great for circulating air in the van in moist PNW conditions. In short, a high volume exhaust fan is perfect for the PNW, west and SW but may be less effective in the humid Midwest/NE/South where a/c may be the best solution.
Airflow like this (FantasticFan installed in NAHT - apologies that this install doesn’t address the pop-top issue, I just want to confirm that a good exhaust fan helps) can improve comfort levels inside a van:
_________________ - Jim
Abscate wrote: |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3795 Location: VA/TN
Posted: Wed Jul 18, 2018 5:40 am Post subject: Re: fantastic fan install |
In my parents 5th wheel toy hauler they had a fantastic fan above the kitchen area and were not using it. I asked why didn't they use it and they responded they didn't realize it was there . It is automatic and it has a switch on the wall that controls the dome/fan.
I'd pay good money to have this in my van as I could see this being game changer. I don't have a moon roof - so I could simply cut out 14x14 and install this? I just question if it would hit my future roof rack. _________________ Brandon
Instagram @joannthevan |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
Posted: Wed Jul 18, 2018 5:51 am Post subject: Re: fantastic fan install |
I'd also buy a clean adapter for putting a fantastic or other dedicated roof fan in. Honestly, I'm surprised this doesn't already exist. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
