IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Wed Jul 18, 2018 9:25 am Post subject: Anyone struggle getting front wheel bearing seal in? (2WD) |
I've been doing wheel bearings for more than 40 years by hand, and yesterday I could not get a new wheel bearing seal back in the front hub after packing and inserting new races and bearings.
I tried tapping it in with a brass hammer and it seemed a touch too large. It fought me and I gave up and took it to the press where I pressed it in perfectly square. When I pulled the hub out for a look, the seal had gone in very crooked. It looked like it was too tight and suddenly one end snapped in. That's about as perfect a way of pushing a seal in perfectly square and it didn't go.
I seem to recall this has happened to me before where there were two VERY close diameters and I fought to put a seal in, and I've also experienced the opposite where a seal went in too easily and made me uneasy. These on other vehicles.
So, I'm asking the group - has anyone experienced this? Are there two hubs or seals that are very close in the Vanagon world, and how do I differentiate and get the right one?
Thanks. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3800 Location: VA/TN
Posted: Wed Jul 18, 2018 9:35 am Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
I bought my kit from VC. I used a bearing press kit? It's like a punch with a round disk on the end of it. But I could not get it to sit 100% flush with the outer lip. A part of it was too deep. I used a pick tool with a 90 degree or right angle end to pull the too deep part up. And yeah give it a minute cause I put one in and a minute later it popped out.
ABN Bearing Race and Seal Bush Driver Set with Carrying Case – Master/Universal Kit for Automotive Wheel Bearings https://www.amazon.com/dp/B01GVQOSA4/ref=cm_sw_r_cp_apa_SX2tBbEXJPMSD _________________ Brandon
Instagram @joannthevan |
kourt Samba Member
Joined: August 13, 2013 Posts: 1947 Location: Austin, TX
Posted: Wed Jul 18, 2018 9:42 am Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
From whom did you get the bearing seal? I ask because I have received incorrect seals multiple times from various providers. All were fixed with a phone call, but it was annoying.
kourt |
Posted: Wed Jul 18, 2018 9:50 am Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
I got it from my favorite vendor and I've got a call in there (I'll share what I learn for the group - this can't be first time it's happened in our world) and its an Elring 349.855 with listed dimensions of 55X68/8.5. Looks and feels like a very high quality seal - no flex of internal steel despite my abuse, the outer rubber layer is ribbed and feels properly thick, etc. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Wed Jul 18, 2018 9:52 am Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
Hmm - thanks Brandon. You reminded me I have a seal driver kit for my press in a suitcase under the work bench I may/will give it a try with that, but still interested in the tribal knowledge because others would never be able to get this in by the side of the road or with the normal process of tapping it in with a hammer.
The other thought I have is to put it in with the press completely dry and perhaps then it will stay square. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Wed Jul 18, 2018 10:13 am Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
If it is the correct seal you should be able to set the one side of the seal in at least half way and then beat on the other side of the seal at about a 45° angle with a hammer. This will usually encourage a seal to go right in.
You can also set the seal flat on the hub, lay a 2x4 over it and give it a firm blow with a 2# hammer. |
danfromsyr Samba Member
Posted: Wed Jul 18, 2018 10:44 am Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
I use the block of wood technique and YES one was a bit of a pain to get in, chased it around the bore for quite some time. _________________
Abscate wrote: |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4791 Location: Bemidji, MN
hkunstmann Samba Member
Joined: April 30, 2016 Posts: 47 Location: San Antonio, TX
Posted: Wed Jul 18, 2018 11:15 am Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
I had similar difficulty. What I did is put the inboard bearing in, start the seal and reinstalled the axle assembly, install the front bearing washer and nut. Torque down. The seal will be aligned to help the installation. Undo nut and remove the axle assembly. You'll find the seal isn't all the way installed but far enough it won't pop out. Slowly tap in it till its flush, working around the seal circle like. Just make sure the inboard bearing is already packed with grease. Won't be able to get it once the seal is installed. |
Posted: Wed Jul 18, 2018 11:28 am Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
I got it almost in flush with the press today dry (wiped dry - not sterile with brake cleaner) but it shaved some rubber off the outside. Then I put it on the ground and went to get my brass hammer. Came back and it had popped out.
Does anyone have any clarity on "earlier" vs "later" vanagon hubs? Somewhere in the back of my mind there is a slight difference. I've salvaged a few and recall that they had a different "shoulder" look to the rotor casting - like the wheel contact surface was wider. Comments? _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
riceye Samba Member
Joined: March 09, 2006 Posts: 1661 Location: Caledonia, WI
This is very interesting. Another anomaly I found was searching "wheel seal" on Rocky Mountain Westy/Van Cafe I found a second seal number for a 2wd vanagon. That number is 281407641C rather than 251407641A, and is currently unavailable. _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
Eric_Taylor Samba Member
Joined: January 21, 2011 Posts: 291 Location: Bend, Oregon
Posted: Wed Jul 18, 2018 11:32 am Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
I did both front's recently and had the same problem on the passenger side. I can't remember exactly how we got it started, but what I noticed was that the seal seemed a bit oversized. The one on the drivers side went in by hand, no problem, easy as pie. This one was just slightly bigger and ended up tearing a bit on the outter part of the seal, but went in. I'm not thrilled about it, but it didn't tear a surface that touches the bearing or hub, so I was comfortable with it, but we shall see. Glad to know I'm not the only one who has gone through this. |
Vanagon Nut Samba Member
Posted: Wed Jul 18, 2018 11:38 am Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
It sounds like you've done far more bearing/seal jobs than me so I doubt this is the issue but.....
On my first Vanagon front bearing/seal job, I managed to get grease on the seal OD which in turn caused it to work its' way out after it was installed. I cleaned the rotor metal surface with brake parts cleaner, cleaned grease off the seal best I could, the seal then stayed in place.
1988 West DIY 50º ABA
VE7TBN |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Wed Jul 18, 2018 12:00 pm Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
This should add to the confusion. I am looking at my old ETKA.
281 407 641 C F >> 24A 0024 011
251 407 641 A F 24A 0024 012 >>
Unfortunately there are no seal dimensions. But there appears to be a change depending on chassis number. _________________ ☮️ |
Posted: Wed Jul 18, 2018 2:00 pm Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
OK, so this is what I did to get it successfully in place (at least it's still in from 30 minutes ago):
All of us use this trick and the promptly forget about it in a memory cycle that goes back a long time. I set up the press with the rotor/hub sitting there, the press cycled down to the right height, and popped the seal in the freezer. An hour later, I grabbed it and ran to the garage, bashing my shin on a camp box on the way, and it went in like Flynn*
Thanks for your support. I think one of my rotors may be the prior chassis size and the other the newer chassis size. It's not a huge change, so if you run into this - that's how its done!
Doug
*A reference to famous ladies man Errol Flynn _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9936 Location: Orbiting San Diego
Posted: Wed Jul 18, 2018 2:19 pm Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
Yes, but the 24A means the change occurred in the 80 model year. Vin 024 111 so only a couple months of the first T3 came with different parts. The other part changed at the same time was the part that the inner lip of the seal spins on.
Another change noted on that VW Parts diagram was the outer bearing changed during 24-E which means during 84 model year. That was when VW increased the diameter of the front spindle, meaning a bearing with a larger inner hole was needed.
Mark
MarkWard wrote: |
Unfortunately there are no seal dimensions. But there appears to be a change depending on chassis number. |
jberger Samba Member
Posted: Wed Jul 18, 2018 2:59 pm Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
FWIW I use the old seal as a driver for the new. Plate or lumber over for whacking or pressing. I also take the old bearing, remove balls and inner race, grind the OD slightly and use as pressing tool for new bearing. I do quite a few of the same bearing sizes.. so it pays to keep them hanging around.
J |
Posted: Wed Jul 18, 2018 6:39 pm Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
Yeah, I've also heard take the old race and cut through it. Now it's easy to pop back out. Having a ground one on hand is good advice. My problem is I have about 16 different races in my life to take care of and I don't have a grinder! So I get by starting the new race with an old race and just when it starts to bind I pull it out. Tap if you slightly overdo it. Then I use a punch to push the race to the bottom, at which point your hammer blows go from a dull sound to a bright ringing. That's the bottom! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Thu Jul 19, 2018 6:44 am Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
Just curious - and to make sure - but should these seals go in 100% dry and clean when installing? I am about to do transaxle final drive seals and the seal there is very similar to the wheel bearings seals. _________________ Brandon
tencentlife Samba Member
Posted: Thu Jul 19, 2018 7:57 am Post subject: Re: Anyone struggle getting front wheel bearing seal in? (2WD) |
Yes, seals like this are best installed with the outer ribbed surface and the receiving housing dry.
Did the OP ever compare the embossed sizes on the two seals to compare? That would have told him he had the wrong part right quick. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
