Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Posted: Mon Jul 16, 2018 7:23 pm Post subject: Re: Reviving Bettie (69 Squareback) |
I remember this car from the first time around. Really liked the family project.
Is there any evidence that it has been in a wreck, specifically the front end? The hood shouldn't be that far off.
The chrome beak is removable, there are 4 or 5 screws on the back side holding it to the hood. Also, you can adjust the position of the latch to get it latch proper. I'm more concerned that you have a bigger issue if your gaps are that far off.
Also, you'll get better measurements from a fixed point on the hood to compare them rather than the ground, like the holes for the latch to the back or corners or hinges. _________________ 69 Fastback Build
Berg5 Build |
Temmett Samba Member
Joined: April 19, 2010 Posts: 334 Location: Ferndale, CA
Posted: Tue Jul 17, 2018 2:36 pm Post subject: Re: Reviving Bettie (69 Squareback) |
Brent wrote: |
I remember this car from the first time around. Really liked the family project. |
Thanks. The whole family is back at it.
Brent wrote: |
Is there any evidence that it has been in a wreck, specifically the front end? The hood shouldn't be that far off. |
Yes. Probably several times.
Brent wrote: |
The chrome beak is removable, there are 4 or 5 screws on the back side holding it to the hood. Also, you can adjust the position of the latch to get it latch proper. I'm more concerned that you have a bigger issue if your gaps are that far off. |
I took the chrome beak off and laid it up against the original hood. The curvature is way off.
Brent wrote: |
Also, you'll get better measurements from a fixed point on the hood to compare them rather than the ground, like the holes for the latch to the back or corners or hinges. |
I'll try a more precise measurment. _________________ 1978 Westfalia - pre-purchase walk around
1969 Squareback http://squarebackresto.wordpress.com/ |
Posted: Wed Jul 18, 2018 11:06 am Post subject: Re: Reviving Bettie (69 Squareback) |
A few more pics to accompany my hood investigation. Some obvious problems.
The passenger side is touching but the driver side isn't.
Passenger side. You can see where when it's opened the friction chips off paint.
Driver side.
Windshield wiper as a manual bump stop for the hood. Love it!
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Tue Jul 24, 2018 11:08 am Post subject: Re: Reviving Bettie (69 Squareback) |
Very cool Temmett.
On the wiring, I'd probably disconnect it all from the fuse box, and using a long jumper wire (with alligator clips on each end) ohm out each one, to verify it's still good.
Also in the top right side of the page is a link to the technical section. Click on it, (it defaults to T-2, so you'll have to click on type 3) and then bring up the wiring diagram for your year in the t-3 section. Save it to a memory stick and then have it printed out (Kinko's). It's in color which is nice to follow. Russ recommended having it laminated (and blown up slightly larger), so you could follow it along with a grease pencil. That would help you out to verify the individual wires are going where they should go.
Then once you know the wires are good, it's just a matter of re-attaching them to the fuse box on 1 end, and to their component on the other. No sense and making it harder on you, and then trying to find out something's not working later on. Test it all before hand. If you find a problem, NOW is the time to fix it.
Remember, one of the first things PO's do to old VWs is mess with the wiring. I don't know why, but they do. Ask Tram.
I hope this helps.
P.S. You might need to pull the front end out like you did to the rear years ago ( ), to get a better hood alignment. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Brent Samba Member
Posted: Wed Jul 25, 2018 12:38 am Post subject: Re: Reviving Bettie (69 Squareback) |
Bobnotch wrote: |
P.S. You might need to pull the front end out like you did to the rear years ago ( ), to get a better hood alignment. |
Yeah, that's kind of what I was thinking given those pictures. Hope it's not too bad. _________________ 69 Fastback Build
Berg5 Build |
Posted: Sat Jul 28, 2018 8:46 pm Post subject: Re: Reviving Bettie (69 Squareback) |
Bobnotch wrote: |
I hope this helps. |
Thanks for all the guidance. I will definitely download, print, and laminate the diagram. The very first thing we ever did to Bettie back in the day was replace the wiring harness. We learned the hard way why laminating the diagram is beneficial. I don't even remember how this diagram got ruined, even after it was laminated. But my wife soldiered through.
Interesting idea. I might give that a try. _________________ 1978 Westfalia - pre-purchase walk around
Posted: Sat Jul 28, 2018 8:47 pm Post subject: Re: Reviving Bettie (69 Squareback) |
Brent wrote: |
Bobnotch wrote: |
Yeah, that's kind of what I was thinking given those pictures. Hope it's not too bad. |
Brent, here's to hoping. _________________ 1978 Westfalia - pre-purchase walk around
Posted: Fri Aug 31, 2018 12:24 pm Post subject: Re: Reviving Bettie (69 Squareback) |
We were pretty stoked to have dropped Bettie's engine. It was the first time we'd ever done it so we took our time and learned as we went. Even though I know it's a simple thing, it feels like we accomplished something major.
It's been stripped down and put on the stand. I know the idea is to get the engine back in the car, but maybe I could just get another one to keep as a garage decoration...?
This little guy hit the ground when we pulled the muffler off. Don't know what it is. You?
My son is going to be driving this as his first car so we're doing the engine overhaul together. I pulled the first head today. He'll get to tackle the other side. But this is what I found. Lots of carbon...
and some gnarly cracks.
Brent Samba Member
Posted: Fri Aug 31, 2018 12:54 pm Post subject: Re: Reviving Bettie (69 Squareback) |
Those adapters that mount to your oil pump studs have mixed reviews. IMO, that's a lot of weight to be suspended by your oil pump studs. Maybe ok for a stocker, but you might want to consider finding a later case with the proper bosses for the mustache bar.
There are a lot of good new heads. I wouldn't trust them with cracks to the valve seats.
...probably not what you wanted to hear.
Have you make any progress on the front end? _________________ 69 Fastback Build
Berg5 Build |
Posted: Sat Sep 01, 2018 10:08 am Post subject: Re: Reviving Bettie (69 Squareback) |
Brent wrote: |
Have you make any progress on the front end? |
Not to mention the helicoil for 1 plug already. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Sep 01, 2018 1:36 pm Post subject: Re: Reviving Bettie (69 Squareback) |
Brent wrote: |
I was expecting major problems. The engine never ran great. It's time to bring her back to life. Those cracks look pretty bad to me. Good call on the helicoil, Bobnotch. I was thinking new heads too. I'm learning what I'm looking at as I go. What is the oil pump adapter for? Tried searching it out. Not having much luck.
As far as the front end, I have been persuading the replacement hood to fit. Just about there. _________________ 1978 Westfalia - pre-purchase walk around
Posted: Sun Sep 02, 2018 8:54 am Post subject: Re: Reviving Bettie (69 Squareback) |
Temmett wrote: |
What is the oil pump adapter for? Tried searching it out. Not having much luck. |
The oil pump "adapter" plate bolts the engine hanger bar to the engine case.
In your case, the adapter was used because the engine block is from a 68 or earlier model, and doesn't have the mounting bosses for the engine hanger to bolt to.
Like Brent mentioned above, it might be a good idea to look for another engine case (with the bosses) to build upon. Ideally, you'd like to find a type 3 case, but, you can use a universal case too.
What I have in my 65 Notch is an all aluminum universal case. I'm also using the engine hanger bar, because of my IRS conversion. Just something to think about. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Sep 02, 2018 4:46 pm Post subject: Re: Reviving Bettie (69 Squareback) |
Bobnotch wrote: |
Temmett wrote: |
What I have in my 65 Notch is an all aluminum universal case. I'm also using the engine hanger bar, because of my IRS conversion. Just something to think about. |
Thanks for the education, Bobnotch. I always appreciate the help.
My son pulled the left side head and, well, I'm guessing things got just a little hot.
Posted: Mon Sep 03, 2018 10:46 am Post subject: Re: Reviving Bettie (69 Squareback) |
Yeah, I'd say that side is a goner. That engine needs a full going thru, with the inside parts needing to be mic'd out. You're looking at a pair of heads, and a P&C set for sure, along with a full gasket kit at minimum. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Sep 03, 2018 12:51 pm Post subject: Re: Reviving Bettie (69 Squareback) |
Bobnotch wrote: |
Yeah, I'd say that side is a goner. That engine needs a full going thru, with the inside parts needing to be mic'd out. You're looking at a pair of heads, and a P&C set for sure, along with a full gasket kit at minimum. |
If this baby needs that kind of work, would it be better to go with a whole new engine? _________________ 1978 Westfalia - pre-purchase walk around
Posted: Tue Sep 04, 2018 8:31 am Post subject: Re: Reviving Bettie (69 Squareback) |
Temmett wrote: |
Bobnotch wrote: |
If this baby needs that kind of work, would it be better to go with a whole new engine? |
Probably. But, you'll have to decide how big to go, how fine you want it balanced, and most importantly, who will build it for you.
Whatever you do, don't let price alone be the deciding factor. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Sep 04, 2018 12:50 pm Post subject: Re: Reviving Bettie (69 Squareback) |
Bobnotch wrote: |
Temmett wrote: |
Bobnotch wrote: |
Whatever you do, don't let price alone be the deciding factor. |
I think sticking with as stock a setup as possible is probably the best idea. This is my son's first car and I want him to be able to use the Bentley and The Samba as resources when work needs done. I just ordered an engine from Bus Depot for my Westy. Where would you recommend I start looking for a standard Squareback engine? Great advice on the finances. Price won't be the deciding factor. _________________ 1978 Westfalia - pre-purchase walk around
Posted: Wed Sep 05, 2018 8:46 am Post subject: Re: Reviving Bettie (69 Squareback) |
Temmett wrote: |
Bobnotch wrote: |
Temmett wrote: |
Bobnotch wrote: |
I think sticking with as stock a setup as possible is probably the best idea. This is my son's first car and I want him to be able to use the Bentley and The Samba as resources when work needs done. I just ordered an engine from Bus Depot for my Westy. Where would you recommend I start looking for a standard Squareback engine? Great advice on the finances. Price won't be the deciding factor. |
Probably someone like VW Paradise comes to mind right off hand in your general area. I only say that, as you really want a "custom" stock engine. Meaning; balanced really well so it'll be smooth as silk, and uses the best quality stock parts they can find. Also, you want someone that will stand behind their work. Another option would be to talk to Steve (aka Clatter on here), as he likes to build engines. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Brent Samba Member
Posted: Thu Sep 06, 2018 9:52 pm Post subject: Re: Reviving Bettie (69 Squareback) |
Aircooled.net has a lot of longblock options. They have an excellent reputation.
Chico is another I'd trust to build me a motor.
Clatter will talk you into a Type 4. _________________ 69 Fastback Build
Berg5 Build |
