Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Wed Jul 18, 2018 8:24 am Post subject: Re: fuel pressure |
Meiang wrote: |
This whole fuel pressure measurement issue is so !!!
Trying to find a gauge that can measure 3psi accurately is very hard. 3, 4, 5, 6, 8, psi, most cheap gauges would not distinguish the difference accurately. Most are 15psi miniumum FSD
Unless a gauge has a calibration certificate it means nothing. This means you are going to pay US$150-200 plus for the gauge. Who pays that.
For those who dispute this. Have they had their gauge tested by a certified laboratory. Check the price - its probable a lot more.
Just because the cheap gauge indicates 3psi means nothing. |
Just for kicks, I did a search on Australian eBay, and had no trouble finding inexpensive name-brand 0-15psi gauges. Here's one: https://www.ebay.com.au/itm/AEROFLOW-FUEL-OR-OIL-P...0760958804
They're plenty accurate for setting fuel pressure on our old carbureted cars. You just need to get it in the ballpark where it's not overwhelming the carb or starving it at higher RPMs. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
JaimeReyes Samba Member
Joined: May 30, 2018 Posts: 165 Location: San diego CA
Posted: Wed Jul 18, 2018 9:34 am Post subject: Re: fuel pressure |
had a question if anyone knows...is there a decent fuel pressure regulator out there? i don’t like the fact that i have to stack soooo many gaskets. i’ve heard too many bad things about the empi brand regulators so i want to stay away from that one. |
Dark Earth Samba Member
Posted: Wed Jul 18, 2018 10:08 am Post subject: Re: fuel pressure |
JaimeReyes wrote: |
What is the thickness of the gasket stack you have right now ? _________________ My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jul 18, 2018 11:54 am Post subject: Re: fuel pressure |
JaimeReyes wrote: |
Better to get an OG fuel pump (two is even better), and a couple of the new rebuild kits from Wolfsburg West that are now reportedly greatly improved. _________________ In Stereo, Where Available! |
Posted: Wed Jul 18, 2018 12:31 pm Post subject: Re: fuel pressure |
Eric&Barb wrote: |
JaimeReyes wrote: |
Better to get an OG fuel pump (two is even better), and a couple of the new rebuild kits from Wolfsburg West that are now reportedly greatly improved. |
that’s ultimately the plan but i’m really short for money at the moment. this is more of a temporary fix until i can afford a better quality one |
Posted: Wed Jul 18, 2018 12:32 pm Post subject: Re: fuel pressure |
Dark Earth wrote: |
JaimeReyes wrote: |
What is the thickness of the gasket stack you have right now ? |
i’m not sure since i’m not home at the moment. i’m pretty sure i’ve got 7+ gaskets under there though |
Posted: Wed Jul 18, 2018 12:53 pm Post subject: Re: fuel pressure |
If you have a generator style fuel pump that is straight ( not the angled alternator style ), your pushrod should be 108 mm / 4.252" long. It should stick out of the fuel pump spacer 13mm at its highest point ( TDC, I believe ). If you have those measurements and the fuel pump still puts out over 3 psi, you'll have to live with it or find another pump ( original VW being the best ). _________________ My Build: '69 Baja - Dark Earth Version
Posted: Wed Jul 18, 2018 5:28 pm Post subject: Re: fuel pressure |
Dark Earth wrote: |
If you have a generator style fuel pump that is straight ( not the angled alternator style ), your pushrod should be 108 mm / 4.252" long. It should stick out of the fuel pump spacer 13mm at its highest point ( TDC, I believe ). If you have those measurements and the fuel pump still puts out over 3 psi, you'll have to live with it or find another pump ( original VW being the best ). |
so you don’t think it’s worth getting a regulator in the mean time? don’t have 250+ to spend on a og fuel pump. pretty sure it was around 13mm when i measured but put out like 8psi without gaskets. |
Posted: Wed Jul 18, 2018 5:41 pm Post subject: Re: fuel pressure |
Rebuildable fuel pumps are as low as $10.00, but let us say $15.00, with $5.00 shipping
Rebuild kit is $35.00, and let us say $20.00 for shipping.
That is $75.00....
$250.00 minus $70.00 = $180.00 unaccounted funds.
So how/where are you loosing $180.00????????
Even if you get two of each it will be less than $150.00 figuring combined shipping of parts, that is still a $100.00 less. _________________ In Stereo, Where Available!
Posted: Wed Jul 18, 2018 5:45 pm Post subject: Re: fuel pressure |
JaimeReyes wrote: |
Dark Earth wrote: |
A regulator would work fine. The fuel pump might work "as is" until you can get a new pump though (as long as the fuel pump pressure is not enough to overpower the needle and seat in the carburetor.) _________________ My Build: '69 Baja - Dark Earth Version
Posted: Wed Jul 18, 2018 5:56 pm Post subject: Re: fuel pressure |
Looks like WW is out of the kits right now, but CIP1 has kits for $24.00. _________________ In Stereo, Where Available! |
Posted: Wed Jul 18, 2018 6:20 pm Post subject: Re: fuel pressure |
Eric&Barb wrote: |
Are you talking about JOGR in the classified section ? _________________ My Build: '69 Baja - Dark Earth Version
Posted: Wed Jul 18, 2018 6:42 pm Post subject: Re: fuel pressure |
Dark Earth wrote: |
Eric&Barb wrote: |
Are you talking about JOGR in the classified section ? |
Yes, and DutchboyVW has same for $7.00.
Here is out the door rebuilt for $65.00.
https://www.thesamba.com/vw/classifieds/detail.php?id=2117692
Just add a diaphragm kit... _________________ In Stereo, Where Available! |
Posted: Wed Jul 18, 2018 7:26 pm Post subject: Re: fuel pressure |
Eric&Barb wrote: |
Looks like WW is out of the kits right now, but CIP1 has kits for $24.00. |
Does WW routinely run out of kits ? If so, how long does it usually take for them to get them back in stock ? Isn't the $24 CIP1 kit for a different model fuel pump ? _________________ My Build: '69 Baja - Dark Earth Version
Posted: Wed Jul 18, 2018 7:57 pm Post subject: Re: fuel pressure |
Dark Earth wrote: |
Eric&Barb wrote: |
Does WW routinely run out of kits ? If so, how long does it usually take for them to get them back in stock ? Isn't the $24 CIP1 kit for a different model fuel pump ? |
Would not be able to tell you.
40 HP and the later 1500/1600 pumps use same parts from diaphragm on down. Most times the diaphragm is the failed part.
The 40HP style pumps were used well into 1500 engines into the 67 or 68 model years. _________________ In Stereo, Where Available! |
wcfvw69 Samba Purist
Posted: Wed Jul 18, 2018 8:02 pm Post subject: Re: fuel pressure |
Be mindful of any "cheap" VW pump or any part. Here's someone else's recent posting of a cheap fuel pump.
Yup, spending $15 to $25 dollars for a pump can save a few bucks. But, what's your time worth when it does this. How much is the tow home?
I've rebuilt hundreds of the German Pierburg fuel pumps. They are as good as new after rebuild if you use the good Effbe rebuild kits. You can reuse all the hard parts in them as well. The crap kit Cip-1 sells are terrible and put out too much fuel pressure.
https://www.thesamba.com/vw/classifieds/detail.php?id=2190238
I find these NOS pumps occasionally. These are excellent fuel pumps and were made under license from Pierburg about 20 years ago. They are NLA now.
Another option if you don't want to gamble with a cheap pump or a more expensive professionally rebuilt original German Pierburg. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Jul 18, 2018 9:21 pm Post subject: Re: fuel pressure |
Eric&Barb wrote: |
That is $75.00....
Even if you get two of each it will be less than $150.00 figuring combined shipping of parts, that is still a $100.00 less. |
that’s because i was looking for already restored/rebuilt pumps because i’m a novice when it comes to cars. would it be easy to throw a diaphragm kit in that $65 one you linked?? also the nos one that wcfvw69 linked looks pretty good to me for $85. just wouldn’t have the money for another week or 2 |
Thanks Eric&Barb and wcfvw69 !! Good stuff. _________________ My Build: '69 Baja - Dark Earth Version
Posted: Wed Jul 18, 2018 9:29 pm Post subject: Re: fuel pressure |
wcfvw69 wrote: |
Another option if you don't want to gamble with a cheap pump or a more expensive professionally rebuilt original German Pierburg. |
i would definitely be interested in that nos one you listed if it’s still available when i have the money!! just kinda have to figure out what’s wrong with my car first before i put more money into it |
Posted: Thu Jul 19, 2018 4:51 am Post subject: Re: fuel pressure |
Eric&Barb wrote: |
Agree the diaphragm/s are usually the culprit when the pumps fail. The dome top pumps have the main diaphragm w/spring. The square tops have the small upper diaphragm as well.
Eric&Barb wrote: |
The 40HP style pumps were used well into 1500 engines into the 67 or 68 model years. |
On bugs, the 40hp dome top pumps were last used on 1965 models before they went to the new square top fuel pump in 1966 models with the built in fuel shut off valve.
On buses, the 40hp dome top pump was used all the way through production of the type 1 engine equipped buses in the USA through 1971. In 1972, USA buses came with the type 4 engine and a different version of the Pierburg square top pump for that engine. Square top fuel pumps were never factory installed on buses in the USA. The were used on Bugs, Ghias and Type 3's though. _________________ Contact me at [email protected]
