mark tucker Samba Member
Posted: Tue Jul 17, 2018 3:21 pm Post subject: Re: Best path for max low end torque |
86 or bigger crank.force feed it if thats not enough.either belt driven turbo or std blower or crank mounted super charger. you can get turbo pistons for the 4.6~5.4 ford for great price and have 4 left over. |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Tue Jul 17, 2018 4:09 pm Post subject: Re: Best path for max low end torque |
clonebug wrote: |
Krochus wrote: |
Big motor AND boost for maximum sketchiness! |
I spent the day at the Kent, Wa. VW nationals yesterday.....
I watched a big stroker with turbo run a high 15 second quarter on his worst run and and his best run was a 14.45 second run. Averages were about 14.70 seconds.
I also watched a stock 1600 with supercharger run from high sixteens to a best of 15.47 seconds.
Size does not dictate power or speed............ |
Cool, yeah I was there too. Did you see my blue 68? Didnt run it because of a pushrod issue. The orange bug that was running crappy times is a new build And something the guy was new to. Thing sounded bad go ok my down the track. Not real zippy. His turbo wasnt spooling up until about 4500 rpm. Issues _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Tue Jul 17, 2018 6:24 pm Post subject: Re: Best path for max low end torque |
I did not see your car there......But I wasn't expecting it to be there either so I might have walked right on by it and it didn't click with me..
Was it in the car show????
There were a quite a few cars that didn't get a good run. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Tue Jul 17, 2018 9:27 pm Post subject: Re: Best path for max low end torque |
Looks like there's plenty of room for duals, if you just run them outside of the bars. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
JoeE13 Samba Member
Posted: Wed Jul 18, 2018 6:20 am Post subject: Re: Best path for max low end torque |
Yes I believe so
bugguy1967 wrote: |
Looks like there's plenty of room for duals, if you just run them outside of the bars. |
JoeE13 Samba Member
Posted: Wed Jul 18, 2018 6:25 pm Post subject: Re: Best path for max low end torque |
I believe plenty of room for dual carbs
JoeE13 Samba Member
Posted: Wed Jul 18, 2018 6:28 pm Post subject: Re: Best path for max low end torque |
Carb is a Weber car was originally assembled in 2008.
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Wed Jul 18, 2018 8:42 pm Post subject: Re: Best path for max low end torque |
A progressive on a race car
HUGE IRONY
And they even went to the trouble of mounting it the right direction. |
JoeE13 Samba Member
Posted: Thu Jul 19, 2018 6:52 am Post subject: Re: Best path for max low end torque |
Thats what I thought when I was looking it over
modok wrote: |
HUGE IRONY
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
