flightofphx Samba Member
Posted: Wed Jul 18, 2018 3:46 pm Post subject: Is it a "must" to remove glass before painting? |
I bought a Fastback recently that is primered. The PO had just replaced window rubber all the way around (except the doors). I want to paint it, but use the original paint code so the jams and interior of doors will match.
Is it an absolute must to pull the glass before painting a primered car? I know it is best practice - but it will be a pain in the ass to pull the glass and a waste with the brand new rubber (assuming it will need to be cut to remove it).
I want a painted car - but I am realistic in keeping costs inline with the worth of the car as a whole. I am going to find a local painter to do this is a side gig. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Wed Jul 18, 2018 3:54 pm Post subject: Re: Is it a "must" to remove glass before painting? |
You can just work the tape behind and wrap it around, but I would NOT suggest it. If you ever have to replace a seal and its a tiny bit smaller, it will look like hell. I jast ran into this on a 63 that we did new seals and an interior respray. Outside had been painted not that long ago (without removing the windows) and I removed the side and rear windows to do the headliner. New seals were just a tiny bit smaller.. We played hell trying to get a good blend. _________________ D-Dubya Manx clone - 63 Short pan,1914.
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Jul 18, 2018 4:09 pm Post subject: Re: Is it a "must" to remove glass before painting? |
a special tape is made to slip under the rubber and it pulls it up so paint can get under the seal. Just saw this last month from a painter, have no idea what it is called ?
quick search shows this in the UK
https://www.ebay.co.uk/itm/auto-body-shop-paint-3m...swla9uxpcm _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76895 Location: Sneaking up behind you
Posted: Wed Jul 18, 2018 5:14 pm Post subject: Re: Is it a "must" to remove glass before painting? |
Most cheap paint jobs don't remove the glass.
If you want it done the right way, you know the answer. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Jul 18, 2018 5:52 pm Post subject: Re: Is it a "must" to remove glass before painting? |
Yeah - my body guy also mentioned the special tape. The only time that I would use it is if I already had nice paint and needed to just respray a panel like the roof. This was done (not by us) on my 65 that was freshly painted, but had roof damage when the car was transported to PA from CA. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Angus II Samba Member
Joined: June 01, 2016 Posts: 707 Location: Mammoth Lakes Ca. 93546
Posted: Wed Jul 18, 2018 7:15 pm Post subject: Re: Is it a "must" to remove glass before painting? |
Hello,
Alright, I tell you about a little trick... that I use if the windows rubbers are not removed.
What you do is pull up the rubber seal with a glass tool and stuff a piece of 1/4 nylon cord under it. Somewhat, like putting a window in, but on the outside lip.
It will raise the rubber up and out of the way creating a gap for which you can spray under the rubber. After the paint has fully cured, you can pull the cord out and the rubber will fall back into place. No tape lines over or short on the rubbers/seals edge(tape rolls over and under seal). And it will look as if you did pull the glass...
Give it a try it works. I use to use this trick on older cars when finding the rubber trim was no longer avalible... or the owner didn't want to spend the money. Or as on my Japanese mini truck.
Plus, it gets the rubber out of the way of the sander when doing body work also...
Here is a picture, it's dark. But, you can see the gap under the windshield rubber at the bottom edge.
Make sure you stick the cord in to just the radius of the opening, that gives you some painting space and the rubber will cover it and if you do end up putting in new rubber latter it will cover the paint line.
I hope this little "old bodymans trick" works for you, it has always worked for me.....
Oh, and it is the same as using that special tape, which the plastic goes/slips under the rubber and you're pulling the rubber/seal up and away from the body with the tape sticky portion.. This trick is older than the special tape is. And is not expensive like the 3M tape is. The first time I saw the tape at a NACE show in the 90s, I thought what a waste of money.... |
Posted: Wed Jul 18, 2018 7:31 pm Post subject: Re: Is it a "must" to remove glass before painting? |
Yes the nylon cord is an old trick also
andk5591 wrote: |
Yeah - my body guy also mentioned the special tape |
So why not mention it? Aren't we here to help? some have never heard or seen that tape.
We used it on a 84 Pete we just had painted worked well. Didn't really want replace all the seals on a semi _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Wed Jul 18, 2018 8:06 pm Post subject: Re: Is it a "must" to remove glass before painting? |
Angus II wrote: |
Hello,
Thanks for the tip! Do you have any close up pics of it? Does the cord wrap around all the perimeter of the rubber at once? |
jinx758 Samba Member
Posted: Thu Jul 19, 2018 6:51 pm Post subject: Re: Is it a "must" to remove glass before painting? |
Mite consider this "redneck" fix I used 6yrs ago when I painted my 1994 Dodge ... L334 Glacier Blue. I did not want to mess with removing the rear window. I used a plastic putty knife & pushed 14 gauge electrical wire up under the seal. Be sure to get about a 1/4 inch from the wire to the outer edge of the seal. The paint flowed under the seal & no one was the wiser.
It " worked a treat " superbly !
Just be sure paint / clear has hardened b4 removal.
Best of luck ... jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference
You can't push a rope
VALVES (cold)
POINTS
TIMING
CARB (fully warmed engine)
SCRAPE ALL GROUNDS
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Tue Jul 31, 2018 6:53 pm Post subject: Re: Is it a "must" to remove glass before painting? |
... I have never removed any glass when painting my cars. I simply mask, the best I can and then cover the resta' the window with newspaper and shoot - so a little paint gets on the very, very edge of the rubber, in some spots - yes, okay, I can live with that - sounds like somma' you can't - you have my sympathy.
painted this in '77 with a 1/2 horse compressor and a thirty dolla' disposable gun... not bad - not perfect, but who expects perfection? Ha, left the dent in the fender to (intentionally) be imperfect.
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
