VW Truck Samba Member
Posted: Sun Jul 08, 2018 8:54 pm Post subject: Timing question |
Today I was driving around and the engine died. It turned out that the points slipped closed. I did the best to get it going withough my glasses then limped home. Unrelated to the points slipping, I found that the crank pulley is at BDC when cylinder 1 is at TDC. I took out the bolt that attaches the pulley to the crank so see if anything was weird there (it is reinstalled now). Also, I pulled the #1 spark plug and verified it was at TDC using a mirror.
Any ideas why the crank pulley is 180° off?
_________________ My 1959 Truck |
busdaddy Samba Member
Posted: Sun Jul 08, 2018 10:17 pm Post subject: Re: Timing question |
Have you followed that wire that's over the rotor when the distributor is in that position to see what cylinder it leads to?, don't count on the notch indicating TDC unless YOU installed the drive. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jul 09, 2018 8:55 am Post subject: Re: Timing question |
busdaddy wrote: |
Have you followed that wire that's over the rotor when the distributor is in that position to see what cylinder it leads to?, don't count on the notch indicating TDC unless YOU installed the drive. |
Thanks for the reply! I did trace all spark plug wires and, when at BTDC they all go where they should.
Is it possible the distributor shaft is installed 180° off? I haven't checked the manual to see how it's installed. I'll look into that tonight. _________________ My 1959 Truck |
Posted: Mon Jul 09, 2018 9:23 am Post subject: Re: Timing question |
I don't think so, I suspect you have a Monday morning or Friday afternoon EMPI special pulley there, or maybe it's made for the Australian market?
I'd be slipping it off carefully so the engine doesn't turn and slipping another on to make sure the marks are really indicating the correct degrees, you can live with the 180 flip if you know it's there, but if the graphics are skewed as well you may damage your engine by unknowingly mistiming it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jul 09, 2018 10:09 am Post subject: Re: Timing question |
I think you are right about it being a Monday or Friday pulley. I found this on Wolfsburg International. With the key at 9 o'clock TDC is up. Mine appears to be backwards. Maybe it'll be priceless like stamps that are printed upside down!
Thanks for the help!
Posted: Mon Jul 09, 2018 7:37 pm Post subject: Re: Timing question |
So I picked up a timing gun and found the timing was about 40° BTDC. I adjusted it to 10° BTDC. That brought the idle down nicely, but when accelerating the engine seems to lose power early. It kind of flattens out if that makes sense. _________________ My 1959 Truck |
Posted: Fri Jul 20, 2018 9:42 pm Post subject: Re: Timing question |
I installed a compu fire electronic ignition that I got from Wolfgang Int. and WOW! It runs so smooth. I haven't heard any valve chatter when lugging it. I also put in a new 009 distributor, the stock sized crank pulley, new coil, spark plugs and spark plug wires. _________________ My 1959 Truck |
