SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Mon Jul 23, 2018 8:36 am Post subject: Front rotors/bearings. Did I do it right? |
I replaced the front brake pads/rotors and bearings on my 2WD van. I followed the Bently, used 10c's suggestion to tighten the bearings until the washer could be moved only by twisting a flathead screwdriver against it, and did some runs to bed in the brakes.
Everything seems fine although when I get back from driving around my front wheels are hot, presumably from braking. I measured with an IR gun and the temps are up around 270F, hot enough to be uncomfortable to touch. But is that normal anyway?
How would one know if the bearings are adjusted correctly? Just the 'ol "hands at 12 and 6 and try to wiggle the wheel/tire" method? _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Mon Jul 23, 2018 9:13 am Post subject: Re: Front rotors/bearings. Did I do it right? |
also, raise the front wheel off the ground and give it a spin. it should spin happily, with a gradual stop.
heat could be from a dragging brake caliper, tight wheel bearings, or just normal heat after braking to a stop. _________________ -dan
www.thefixitworkshop.com |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Mon Jul 23, 2018 9:14 am Post subject: Re: Front rotors/bearings. Did I do it right? |
Hi
Another cause of hot wheels is the brake pad dragging on the rotor" This is due to dirty pistons, or worn dirty piston gaskets. They sell repair kits with those gaskets. Itθs quite cheap and sell worth it if your calipers aren't toast.
It appears likely from your post that the bearings are at fault, but you never know. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Mon Jul 23, 2018 9:21 am Post subject: Re: Front rotors/bearings. Did I do it right? |
The Bentley says to use the screwdriver but NOT to twist it or pry with it when trying to move the washer with it.
Page 40.11
Mark
SCM wrote: |
..... I followed the Bently, used 10c's suggestion to tighten the bearings until the washer could be moved only by twisting a flathead screwdriver against it.....? |
riceye Samba Member
Joined: March 09, 2006 Posts: 1661 Location: Caledonia, WI
Posted: Mon Jul 23, 2018 9:24 am Post subject: Re: Front rotors/bearings. Did I do it right? |
The service procedure for adjusting wheel bearings does involve a screwdriver blade simply pushing against the washer, not twisting the screwdriver between the hub and the washer.
If you did bed-in your pads properly before noting the temperature of your rotors, that was likely the cause of the heat. Take it out for a good highway run and at the end downshift and use your hand brake to bring yourself to the final stop. The hubs and rotors will probably not be so hot. I often walk around the van at gas stops and touch a lug nut on each wheel. I've never had them be uncomfortably hot. _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
I find that things usually go well right up until the moment they don't. - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
E1 Samba Member
Joined: January 21, 2013 Posts: 6572 Location: Westfalia, Earth
Posted: Mon Jul 23, 2018 10:12 am Post subject: Re: Front rotors/bearings. Did I do it right? |
If the wheel spins freely and the 12 and 6 wiggle test reveals no looseness, I'd say it's pads bedding in -- though they shouldn't drag and not sure why yours are, if they are.
See if temps drop a little with each new drive, but make sure you smell no asbestos!
Getting the nut tension right can be tricky. I did ours a hair tighter and drove a little and checked temp by hand. No issues over 15K miles, right now there's a *tiny* amount of play (tiny!) and I personally think that's fine.
Best to re-adjust after 500 miles or so, but I was too lazy so erred on being a skosh tight to start with and checked they weren't overheating.
Or you could drive to Ennis so we can take a look together. _________________ 84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
Colin Chapman |
SCM Samba Member
Posted: Mon Jul 23, 2018 11:43 am Post subject: Re: Front rotors/bearings. Did I do it right? |
The rotors spun freely even without having the mass of the wheel/tire on them but I'll try driving a bit without much braking and if that results in hot wheels I'll slacken the bearing adjustment.
This is the thread I read where a handful of folks suggested the Bentley instructions for bearing tightening results in a wheel that's too loose.
https://www.thesamba.com/vw/forum/viewtopic.php?p=3630268
E1, unfortunately my work is about to send me to Ludlow, SD for a while so no trips to Ennis anytime soon. What are you up to there? If it's clear of snow, a drive along the Gravelly Range crest road is worth doing between town and Lyon's Bridge. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
E1 Samba Member
Posted: Mon Jul 23, 2018 12:21 pm Post subject: Re: Front rotors/bearings. Did I do it right? |
I understand the clubbing scene to be Uge in Ludlow.
Dang, maybe next time, we'll be in the general area a couple more weeks.
Putting up a website, actually. Incredible signal here, needed (!), may be "stuck" awhile! We love it here.
Yeah, Thanks, was looking at that road. A local told me there's great cell in Beaverhead Valley, too but I'm skeptical until seeing that. Great looking campground on the pass near Tate Place, too!
Gonna call Lolo and ask that very question so they can poke fun as soon as hanging up.
Happy Travels! _________________ 84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
Colin Chapman |
