Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Wed Jul 25, 2018 11:33 am Post subject: EVC Rear Coil Spring Rate |
Does anybody have a picture of a GLS/MV rear coil spring (p/n 7D0511105) that can be compared to a EVC rear coil spring (p/n 701511105K)? I've had no luck finding any info on the spring rate of either spring, so simply comparing the resting length and/or number of spring coils might help answer whether the spring rate of the EVC spring is actually stiffer than the GLS/MV spring. (I would suspect this to be the case as it is with Vanagon springs...)
Thanks! _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Broseph Stalin Samba Member
Posted: Wed Jul 25, 2018 12:07 pm Post subject: Re: EVC Rear Coil Spring Rate |
Here's a pic of an '03 EVC spring, may help if someone has a photo of an MV spring.
_________________ '68 Bus in West Germany, 1977-1979
'67 Riviera poptop conversion in the US, 1984-1990
'95 EVC Winnie, 2018, Sold
'03 EVC Winnie, 2018, Sold |
Zeitgeist 13 Samba Member
Posted: Wed Jul 25, 2018 3:07 pm Post subject: Re: EVC Rear Coil Spring Rate |
I wonder if a Vanagon rear spring would work on an EV
These are Westfalia and Carat springs side by side
_________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
volkybus Samba Member
Joined: November 03, 2013 Posts: 481 Location: CASTLETON VT USA
Posted: Mon Feb 04, 2019 5:20 pm Post subject: Re: EVC Rear Coil Spring Rate |
R u lookin for a softer or a steefer ride? My 93 is way too steef compaired to my 76wesy. Us old folks need a softer ride.any susgestions while.sticking.to vwbuses thanks Bill Puerto Rico n Vt |
