Shift rod swap early to late
notchback25
notchback25 is offline
PostPosted: Wed Jul 25, 2018 6:06 am    Post subject: Shift rod swap early to late Reply with quote
Is it possible to swap out a 64 and earlier shift rod and install an 65 and later rod in the same pan? I parted out a 65 years ago with the newer style coupler (at the back) and want to use it in a 63 pan.
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Thu Jul 26, 2018 2:31 pm    Post subject: Re: Shift rod swap early to late Reply with quote
Yes,, the 65-67 shift rod and coupler will interchange and directly replace the 56-64 rod and coupler.
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Thu Jul 26, 2018 3:02 pm    Post subject: Re: Shift rod swap early to late Reply with quote
And, FYI, the shift rod/coupler changed about a quarter of the way into model year 1964.
Andy T.
I do not know how to fix this. All I can say is it all works fine for me with what I use, Firefox.
andk5591
andk5591 is online now
PostPosted: Thu Jul 26, 2018 5:27 pm    Post subject: Re: Shift rod swap early to late Reply with quote
Just did some research in this and don't remember the details. What year did the length change from 44 to 47"?
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
The Android
PostPosted: Thu Jul 26, 2018 6:46 pm    Post subject: Re: Shift rod swap early to late Reply with quote
kind of the other way around. For 1968 model year they moved the shift lever towards the rear and the shift rod got shorter at that time.
Andy T.
VOLKSWAGNUT
PostPosted: Fri Jul 27, 2018 6:07 am    Post subject: Re: Shift rod swap early to late Reply with quote
And.. it changed again after 72.. Not sure..why.. maybe for the green house glass Super Beetle implementation.
I don't fool with many past 67.. cause.. for years. I thought VW stopped building cars after that. Laughing
68-72 111-711-155F
and
73-79 111-711-155G
" From 1968 to 1972, the shift rod measures 45-1/8 inches long. In 1973, VW moved the shifter position back a small amount and from 1973 to 1979, the shift rods where 43-5/8 inches long overall (41-11/16 inches Center of cup to center of pin hole)".
No one reproduces the 65-67 or the 68-72..
Most "modify" a Universal Buggy/Rail shaft if needed.
In reality... how many really need replacement anyway ... very few..
aka Ken {o\!/o}
notchback25
PostPosted: Tue Jul 31, 2018 7:21 am    Post subject: Re: Shift rod swap early to late Reply with quote
Thanks for all of the replies. That helps me out!
